Old Oct 11, 2010, 03:37 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
It's definitely inspiring, if not downright intimidating.
mclarkson is offline Find More Posts by mclarkson
Old Oct 11, 2010, 03:49 PM
CRAZYDAVE is offline
Find More Posts by CRAZYDAVE
Crazy, that's how it goes
CRAZYDAVE's Avatar
Calgary, Alberta CANADA
Joined Aug 2008
If you guys haven't checked out Freddie's blog and other builds... you're missing out!
Nice work Freddie! Thanks for documenting your truely inspiring build.... it gives me so many ideas, if only I had the time!
CRAZYDAVE is offline Find More Posts by CRAZYDAVE
Old Oct 11, 2010, 04:53 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Tom Frank, aeroca, mclarkson, and CRAZYDAVE
Thanks to everyone for kind words. Inspiration, education, sharing, anything but intimidation. I love teaching, helping, and if somehow this does that, it makes me happy.
I get my favors returned by all the talanted people that post here too! I learn from all of you too! So thanks back at ya!
Fred
Freddie B is offline Find More Posts by Freddie B
Old Oct 11, 2010, 09:36 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I've decided to go with a single 9g servo for the ailerons, in the stock configuration. I decided my skills are taxed enuf just building this thing stock.
Old Oct 11, 2010, 11:20 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Fair enough, and a good choice. Wipe a little Petroleum Jelly (Vasoline) on the wire between the tubes, but don't get any on the tubes themselves. Then when you glue the tubes in the channel, you won't glue the wire to the foam. I use epoxy here, epoxy doesn't stick to anything with Vasoline on it.
Old Oct 11, 2010, 11:47 PM
Tom Frank is online now
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
You might want to consider this mod I posted quite some time ago, but it is still valid and I'll do the same when I build another moth.
http://www.rcgroups.com/forums/showp...&postcount=901
A way to gain noticeable aileron authority without the hassle of adding ailerons to the top wing... retains a semi-scale look and adds no significant weight.
Tom Frank is online now Find More Posts by Tom Frank
Old Oct 12, 2010, 08:44 AM
Pat Daily is offline
Find More Posts by Pat Daily
Pat Daily's Avatar
United States, VA, Chesterfield
Joined Mar 2001
Outstanding work on the TM 400-- I have built 6 pico moths, but never one of these. Your work inspires me--I may have to buy the kit!
Pat Daily is offline Find More Posts by Pat Daily
Old Oct 12, 2010, 09:19 AM
Lancer31 is offline
Find More Posts by Lancer31
Joined Jun 2005
Hi, Pat! I put floats on my 400, while assembling it. The first test flight was off water, and it was perfect! I never did paint that old plane, and eventually lost it in the fire. I have a new kit, now, and am going to give it the full RAF
livery.
Lancer31 is offline Find More Posts by Lancer31
Old Oct 12, 2010, 12:52 PM
Pat Daily's Avatar
Joined Mar 2001
Lancer--good to see you getting back towards a new normal--bet the new 400 TM will look pretty.
Old Oct 12, 2010, 01:30 PM
aeronca is offline
Find More Posts by aeronca
The figure "9" Specialist
aeronca's Avatar
A Barrier Island in New Jersey, USA
Joined Oct 2003
livery.
Glad to see things are normalizing a little for you, Lancer31. Good to see you "back in the hangar"!
Aeronca
aeronca is offline Find More Posts by aeronca
Old Oct 17, 2010, 03:34 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I keep moving forward.
Painting some parts.
Testing out potential pilots.
The elevator was binding and had to be shaved a bit. Anticipating this is one reason I made all my control surfaces black.
The tail assembly looks nightmarish to assemble. None of the parts are square to start with. The bottom of the vertical stab is 1/8" taller on one side - an error in mold alignment. So I'll have to sand it down which will no doubt screw up the curve of it.
Old Oct 17, 2010, 07:22 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Your Moth is looking great.
On the stab, sand the high side until it just touches the low side. Use tape on the low side as a guide that the sandpaper won't dig into.
Some gap is ok if using epoxy and pressure when mounting, Take your time, looks like you are doing a fine job indeed.
Fred
Old Oct 18, 2010, 04:04 AM
GWS CHEN is offline
Find More Posts by GWS CHEN
Taipei, Taiwan
Joined Oct 2005
Hi Mclarkson,
You'll have a cool looking TM400.
You did a good job on hinging the elevator. Make sure that you did glue the hinges firmly between them,
if not, just insert/penetrate and glue toothpicks on the hinges on both sides.
Keep up your good work on it.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Oct 18, 2010, 03:24 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Thanks, guys. I'm really nervous about getting the tail on straight. Wish me luck!
Old Oct 18, 2010, 09:41 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Well, the motor mount is way too big for the cowling, as shown. I'm guessing my move is to cut a couple of inches off the stick?
In other news, she's starting to look like an aeroplane!
Help! Can anyone point me to a good GWS Tiger Moth 400 Build with pictures? Sparkorama Electric Plane Talk 8 Feb 05, 2006 03:12 PM
Help! Can anyone point me to a good GWS Tiger Moth 400 Build with pictures? Sparkorama Parkflyers 0 Jan 23, 2006 05:39 PM
Tiger Moth 400 build "scale details added" Cruzer Parkflyers 9 Feb 20, 2005 12:50 PM
Tiger Moth 400 Build fuzzyhead Parkflyers 0 Oct 24, 2004 07:34 AM
Tiger Moth 400 Build and Maiden Flight review AirWarriorBelgy Parkflyers 180 Aug 16, 2004 02:23 PM
