Feb 23, 2002, 08:45 PM
Seaford, DE
Joined Jan 2002
Cutting ribs
This works great:
Cut a rectangular blank for each rib, and spot glue them together with thick CA to form a stack (don't use much glue). Cut out a template of the rib out of paper, and glue it to the top of the stack with glue stick. Using a jigsaw, cut around the template. For the lightening holes, drill a starter hole, and remove the jigsaw blade and thread it through the hole, and put the blade back in the jigsaw and cut the internal hole. Take the whole stack and finish sand it on a belt sander (You could skip the jigsaw and just sand away the whole profile on the belt sander, but you need the jigsaw for the spar notches and lightening holes). Now carefully break the ribs apart. Makes perfect ribs fast!
Dan
