Old Feb 22, 2002, 08:02 PM
semmyroundel is offline
Find More Posts by semmyroundel
Hanworth, Middlesex, U.K.
Joined Feb 2002
Twin Star motor & paint questions
I bought a Twin Star, thinking of painting it with enamels/oil based paint, white & red(to pilatus colour scheme). Naturally, extra weight would need to be accounted for.
Ineed to know: 1:would MPX gearboxes be sufficient?, was thinking of in-line like Speedgear 400s to enhance appearance. Been told that very good, ubiquitous, Gunther props could be improved upon.
2:Method of applying paint, I was informed that if the enamel tub of paint was sitting in a pot of boiling water, that the brushmarks would disappear when it dries. Anyone comment? Would this paint be too heavy? would it need gears?
Please help!
semmyroundel is offline Find More Posts by semmyroundel
Old Feb 22, 2002, 08:58 PM
big-john-48 is offline
Find More Posts by big-john-48
big-john-48's Avatar
Tyler,Texas
Joined Nov 2001
eeeeeek!!!!!! DON'T use enamel on foam it will melt.
use water base paint . you can find some spray paint like formula - U that will work on foam.
-John-
big-john-48 is offline Find More Posts by big-john-48
Old Feb 23, 2002, 04:15 AM
SJ is offline
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
I painted mine with HUMBROL Eneaml paint which is normaly used with plastic models. If your not sure about the paint, just paint a little bit under the canopy or somewhere you dont see. And see what happens.
I havn`t tried gears, but 8 2400 cells and the stock sp400 flys great. Loops from level flight. Gunther props are great. (the stock white ones.)
SJ
SJ is offline Find More Posts by SJ
Old Feb 23, 2002, 06:14 AM
Stuart Warne is offline
Find More Posts by Stuart Warne
Durafly Brand Manager
Stuart Warne's Avatar
Hong Kong, Hong Kong Island, Central And Western District
Joined May 2001
I used sea grey for the upper surfaces and gloss white for the lower (RAF Coastal Command ww2) acrilic paints applied with a brush. The white needed about 3 good coats, grey only needing one. The weight didn't seem to be a problem as it flys fine on a 7cell pack of 2400's Nicads.
I can post some pictures soon if you like. semmyroundel
Stuart Warne is offline Find More Posts by Stuart Warne
Site Sponsor
Old Feb 23, 2002, 07:13 AM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
Water based paint would be best. I used oil based spray paint on top of brushed on water based varnish. The trick is to let the spray go on lightly without building up too wet, several thin coats instead a heavy ones. If it gets soaked, the solvent is going to work it's way through to the foam and melt it.
Get some prop adapters and try other brands on the S400. I'm happy with Master Airscrew 6x3.5.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Feb 23, 2002, 02:46 PM
dommi is offline
Find More Posts by dommi
Oxfordshire, UK.
Joined Nov 1999
Hi, semmyroundel,
Painted my Twinstar with water based radiator enamel by International paints (white) from B&Q etc. no problems.
Mike.
dommi is offline Find More Posts by dommi
For Sale CC Griffin 55, Super Star motor, & GP C50 Mac8 Aircraft - Electric - Power Systems (FS/W) 0 Jun 07, 2006 02:39 PM
E-Flite Ultimate - motor & gearbox questions CyberPilot Power Systems 3 May 14, 2005 11:08 AM
Battery & motor amp draw questions soundman Batteries and Chargers 6 Oct 06, 2003 02:45 PM
Twin Star Motor & painting question semmyroundel Foamies (Kits) 8 Feb 25, 2002 06:27 PM
twin star motor upgrade (once again...) oded mazor Foamies (Kits) 4 Jun 02, 2001 07:41 PM
