Well, I'm stumped without being able to witness it myself. One thought is that your power system is generating much more noise than on your other planes, so that a well-tested receiver will still misbehave.
Have a person hold your wing and start working the throttle up and down while you walk away with the antenna down. See how far you get before the holder sees a "bounce" in the elevons. Does the bounce only occur with throttle applied? Is this a brushed or brushless motor. If brushed, you may need to add some capacitors to the case of the motor to reduce noise. Another option is to install a "choke" between the receiver and ESC plug. Is there a carbon-rod on your wing? Make sure your antenna does not run parallel to it. I'm out of ideas from here. |
At one time I experimented with the motor's thrust angle on my wing.
Normal mounting for my wing is to follow the airfoil (prop pointing slightly downward). If I raised it to more horizontal, the wing would tip-stall quite easily and come spiraling in without warning. I left well enough alone and she flies great now. |
| Thread Tools | |
| TwinJet death spiral!! | Mike_Then | Foamies (Kits) | 20 | Apr 17, 2002 10:54 AM |
| Zagi Death Spiral seen on a mpg | rparigoris | Foamies (Kits) | 4 | Mar 06, 2002 04:26 PM |
| What is a Zagi death spiral? | rparigoris | Foamies (Kits) | 1 | Feb 18, 2002 11:33 PM |
| Zagi - How to get out of death spiral | Clifford B | Electric Plane Talk | 6 | Oct 14, 2001 02:24 PM |
| Sporty Death Spiral | Shawn Davis | Parkflyers | 10 | Jul 18, 2001 05:42 AM |
