Espritmodel.com Heli Air
Old Feb 22, 2002, 06:10 PM
Doc Watson's Avatar
UK
Joined Mar 2000
Can I use the 7th channel on my RX with a 6 channel Tx
I've seen a thread similar to this but cannot locate it....so...
I've got a 6 channel TX and a 7 channel RX I want to be able to use the 7th channel.
It will controlled by using a switch which will operate when another servo starts to move (lets assume its the flaps ).
So when the flaps start moving (using a dial on my TX) a switch will be activated (its actually a computer mouse button switch) and I want it to activate a servo which will travel from full closed to full open (it will open a 'door' like an undercarriage door)
Can this be done in some way??????
(I've plugged in the 7th channel servo and it growls at its end point.)
Cheers guys
Doc
Doc Watson is offline Find More Posts by Doc Watson
Old Feb 22, 2002, 08:07 PM
St. Mary, Maryland, United States
Joined Dec 1996
No, sorry! With some fancier Tx's you can set them up to use channel 5 or 6 in a channel limited Rx with channel 7 or 8 on the Tx but if the Tx doesn't put out a signal on channel 7 you are SOL.
Chris True is offline Find More Posts by Chris True
Old Feb 22, 2002, 11:34 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Yes. You need a "Gear & Door Sequencer" such as sold by http://www.emsjomar.com/main-3.htm
This does not need a seventh channel. It is slaved off an existing gear channel.
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Discussion Can i use a synth tx module and a regular rx with crytsal? highace1 Radios 6 Sep 24, 2006 11:15 AM
Can I use a 3cell LiPo on my 2cell heli !? liteglow Micro Helis 5 Jul 31, 2005 02:22 PM
Can i use this esc on my Corona ebonicrobot Electric Heli Talk 3 Mar 12, 2005 05:14 PM
Can I turn off the Govenor on my Smile 40-6-12? CheChe156 Electric Heli Talk 4 Mar 03, 2002 01:28 PM
Tail Blades? Can I use Eco8 Blades on my V-E? CheChe156 Electric Heli Talk 4 Mar 02, 2002 12:20 AM
