Old Nov 09, 2004, 10:53 AM
Warbird Brian is offline
Find More Posts by Warbird Brian
Styrofoam Bird
Plainsboro, New Jersey, United States
Joined Sep 2004
Will the GWS 4-blade prop be OK for this setup ?
I am going to build another P-51, and was wondering if the 4-blade prop will be ok with this setup I have... ie: Will I burn up the engine or anything ?
(I believe the GWS 4-blade prop measurements are 254mm x 203mm or 10in x 7.9in)
Himax 2025-4200
Cobri 20
Tanic 3s 1550
Though I have been flying for a while now, I still don't know the "rules" regarding prop size, and have always gone with what was recommended by the manufacturer.
Any advice will be greatly appreciated.
Thanks, Brian
Warbird Brian is offline Find More Posts by Warbird Brian
Old Nov 09, 2004, 12:25 PM
Steve990 is offline
Find More Posts by Steve990
Birmingham Intl, Great Britain (UK)
Joined Jul 2004
Using a 6.6:1 gearbox, Motocalc estimates 15.5A so you should be within the 10-12C rating. Static thrust is estimated at 893g so you'll be well overpowered!
Steve990 is offline Find More Posts by Steve990
Old Nov 09, 2004, 12:32 PM
Styrofoam Bird
Joined Sep 2004
Thank you Steve.
Is Motocalc something I can buy and download ? I'd like to figure out these things for myself if I could
Thanks again, Brian
Old Nov 10, 2004, 03:06 AM
Steve990 is offline
Joined Jul 2004
Brian, try MotoCalc. I'm a newcomer to electric flight, about 8 months now, and found it a pretty steep learning curve. After other recommendations I got MotoCalc which enables you to run various scenarios through to try to pick a motor/propellor/speed controller/battery setup. Its certainly no replacement for experience, speaking to some long term electric flyers they can quote a prop for a given motor/battery combination without ever actually having measured volts/amps.
I've also bought an electric flight meter which reads motor volts and amps up to 100A which can confirm setups. I used MotoCalc to find a better setup for a Mosquito I have. I was using direct drive 480BB motors with 6x4 props which was pulling over 30A but thrust was disappointing. I ran scenarios through and added 3.33:1 gearboxes plus 10x8 Graupner Cam folding props. For a 2Kg model it now flys well with a lower current. I've used it to predict thrust & current draw for an HVP Beaufighter I've just finished. MotoCalc got the current draw & prop rpm spot on.
For Sale NIP APC 10x5 E prop GWS 4 blade prop electric-flyer Aircraft - General - Miscellaneous (FS/W) 5 Sep 09, 2006 05:45 PM
Gws 4 Blade Prop Question Chris Nicastro Parkflyers 18 Aug 19, 2004 10:37 AM
GWS 4 blade prop info please The Blue Max Parkflyers 2 Sep 28, 2002 11:10 PM
GWS 4 blade prop Bob Reynolds Parkflyers 1 Mar 08, 2002 03:55 PM
Will CP 1300 cells be ok for this? Steve H. Power Systems 15 Jul 17, 2001 09:01 AM
