Old Nov 09, 2004, 12:26 AM
Boss248
Boss248
Guest
n/a Posts
Need Help with Sluggish Ailerons...!
As yyou can see by the pictures below I have plenty of aileron surface and throw but the plane is slow to begin rolling but once rolling it does great. The servo is a Pico BB Nero @ 12-15 in. oz. of thrust. Most of my flying is very slow with lots of K/E work(I am trying to get as good as Josh ) and when I am in K.E I like to snap it fast back to same K/E but with the sluggish strart at the roll beginning I am just not comfortable about it. This plane does the easiest K/E of any flat foamie I have ever built and the K/E elevators are a thing of beauty and the hover and TR's are almost effortless...this plane does everthing so damn good but the sluggish start at the roll has really got me scratching my poor old bald head. I have 2HS 55's that I could do a 1 ea. on the ailerons and I also have a JR 281 digital that does not fade out under load like the Picos do...I am thinking this may be my problem but any light shed my way would be nice...
Boss
Old Nov 09, 2004, 07:29 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I use two HS55 servos on alerons on any 3D plane over 250 sq.in. or 8 oz.
at
http://fancyfoam.com/
uses dual 55s on all of his models. If they are good enough for him,well.
Charles
Old Nov 09, 2004, 08:17 AM
Brutus is offline
Find More Posts by Brutus
Glue can fix that.
Brutus's Avatar
Sunny Miami
Joined May 2004
It may be possible that under load the outside half of the ailerons is not deflecting, ie, the aileron is warping. This means until the plane starts to roll only the inside of the aileron is effective.
solutions:
1 move control horn more lateral on the aileron.
2 stiffen the aileron.
Brutus is offline Find More Posts by Brutus
Old Nov 09, 2004, 11:44 AM
hybris is offline
Find More Posts by hybris
hybris's Avatar
Houston, TX
Joined May 2003
Those ailerons may be too small. If you look on the Aftershock or Shock Flyer, they're almost 50% of the wing cord.
hybris is offline Find More Posts by hybris
Old Nov 09, 2004, 01:42 PM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
The ailerons could be twisting the wing in flight too.
RobinBennett is offline Find More Posts by RobinBennett
Old Nov 09, 2004, 04:54 PM
KillerAir is offline
Find More Posts by KillerAir
Plane dodger
KillerAir's Avatar
Stratford Sikorsky, Connecticut, United States
Joined Dec 2001
I would go with two servos and move them out from center. This will increase deflection speed and reduce any twisting that may be present.
Killer
KillerAir is offline Find More Posts by KillerAir
Old Nov 09, 2004, 05:04 PM
j_z_123 is offline
Find More Posts by j_z_123
BOSS
j_z_123's Avatar
New Jersey (excl EWR), United States
Joined Apr 2002
Have you thought about prop torque? The roll to the left should be noticeably better than rolling to the right. IMO... Which way are you having trouble rolling?
Jon
j_z_123 is offline Find More Posts by j_z_123
Old Nov 09, 2004, 05:27 PM
larsy87 is offline
Find More Posts by larsy87
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
Your servo might also be twisting in it's mount. It appears to be just glued in, maybe some balsa rails to spread the load out?
larsy87 is offline Find More Posts by larsy87
Old Nov 09, 2004, 06:24 PM
Boss248
Boss248
Guest
n/a Posts
Thanks for all the ideas...I think the easiest and probably the actual fix is 1 servo per aileron...will give this a try and post results. I am probably over taxing the Pico trying to drive 2 ailerons this size anyaway and it's only 9 grams more with 2 servos.
I may make the ailerons bigger as well as add some boost tabs to the aileron tips...this plane is as close to being perfect as any plane I have built yet and if I could get the roll crisper at the beginning this plane will be fantastic.
I will try to get some video this weekend of the K/E elevators/slides.
Boss
Old Nov 09, 2004, 07:22 PM
RMihara is offline
Find More Posts by RMihara
Aerial Shutterbug
RMihara's Avatar
San Mateo, California, United States
Joined Nov 2001
Too much wing area and not enough control surface.
One thing you can do to increase the roll rate is to taper the leading edges of the wing itself, similar to a CAP or extra...
-Roger
RMihara is offline Find More Posts by RMihara
Old Nov 09, 2004, 07:40 PM
Flyboypaul is offline
Find More Posts by Flyboypaul
Paul Anderson
United States, CA, Lake Elsinore
Joined Feb 2004
I agree with rodger. it apears that you have quite a bit of area out at the tip. If you were to take 1-2" off the tip L.E. and taper the cut to the root your roll rate would greatly increase. Plus it should make it lock on a little better in harrier(less wing rock). This mod should not affect the KE and hover charecteristics that you enjoy.
Paul
Flyboypaul is offline Find More Posts by Flyboypaul
Old Nov 09, 2004, 10:00 PM
Sean G. is offline
Find More Posts by Sean G.
Sean G.'s Avatar
Albuquerque Intl, New Mexico, United States
Joined Nov 2003
I disagree LE taper makes wing rock worse. IMO
Sean G. is offline Find More Posts by Sean G.
Old Nov 10, 2004, 01:09 AM
Boss248
Boss248
Guest
n/a Posts
I agree after looking at the pics and comparing them to what we see today mine are about 30% shy...easy mod tho...
Boss
Old Dec 02, 2004, 11:00 PM
Slowroll90 is offline
Find More Posts by Slowroll90
Joined Nov 2004
Thats a neet looking plane Boss
Slowroll90 is offline Find More Posts by Slowroll90
Discussion Need help with Eclipse 7 programming - Acro/Glid and Thottle/Ailerons jbachman Electric Sailplanes 2 Jan 29, 2007 12:33 PM
Need help with ailerons! KMKAZE Electric Plane Talk 11 Jul 19, 2001 12:34 AM
I need help with motor timing. jtthebiggafigga Electric Plane Talk 3 Jun 09, 2001 11:12 PM
Need help with 400 for park flyer Cpietro Electric Plane Talk 2 May 21, 2001 01:35 AM
