Old Nov 08, 2004, 07:39 PM
Joined Feb 2004
motor for a shock flyer or similar planes.
I have an AXI 2208-34 on a shock flyer and it works great with 3 Lipolys in series and a phoenix 10 ESC. The motor and ESC stay cool. I can fly for 15 to 20 minutes (ususally at 1/4 to 1/2 throttle) on a 700 mah 3-S lipoly. I am still learning alot about electrics having started with them only 4 months ago. I like to build planes out of blue cor, however I don't know what engine, thrust, engine weight, and current draw ESC is best. I have an AXI 2212-34 with a phoenix 25 on 3-lipolys from an old Southern X2 however it seems too heavy for my 30 inch ultimate bipe I built from Tim Hart's design. I would like to try some of the PJS motors on 3S lipolys and use them in a shock flyer or the 30 inch ultimate bipe. Can anyone tell me which PJS will work well with plenty of thrust (equivalent to the AXI 2208-34)and similar weight and what ESC it needs. Thanks. Sagan
Isernhagen is offline Find More Posts by Isernhagen
Old Nov 08, 2004, 09:19 PM
No Dear its not a new one
hotairflyer's Avatar
Joined Nov 2001
Your 2212-34 is exactly the same weight as the 350c brushed motor the Ultimate was originally powered by! Try it with a GWS 11x4.7 and 3s 1200mah and I bet its enough power to make you happy.
hotairflyer is offline Find More Posts by hotairflyer
Old Nov 08, 2004, 09:38 PM
Joined Feb 2004
Thanks hotairflyer. I am going to be building an edge 540 design similar to the shock flyer out of blue cor but I have increased the wingspan from 32 inches to 36 inches and the fuse and tail are also larger by about 10 to 15%. Can anyone suggest a motor set up for this ship. Is the 2212-34 with the phoenix 25 and 3S lipo a good match or do I need more. Sagan
Old Nov 08, 2004, 10:18 PM
adamg's Avatar
Saskatoon, Canada
Joined Feb 2004
An Axi 2212 and Phx25 on 3s can pull over 20oz.
adamg is offline Find More Posts by adamg
Old Nov 08, 2004, 11:18 PM
Joined Nov 2001
http://foamyfactory.com/
Go to the bottom of the page and you will see many links to Ultimate and 3DX which is similar to the planes you want to build, all originally powered by the GWS 350C motor. The 2212-34 will have lots more power and last longer so I think you are good to go.
Inexpensive motor for Shock Flyer? SteveO 3D Flying 9 Aug 13, 2005 05:05 AM
CD Rom motor for Shock flyer Mac8 3D Flying 13 Oct 27, 2004 06:41 AM
FS: Inexpensive motor for HV Logo10 (or similar size/gearing) pwkpete Aircraft - Electric - Helis (FS/W) 0 Jun 28, 2004 09:57 AM
Question Mini Max motor for Shock Flyer ? Arthur 3D Flying 0 Mar 12, 2004 07:27 AM
Question Whats the preferred bushless motor for the Shock Flyer, AXI or Micro 6? EdMan 3D Flying 48 Feb 09, 2004 04:57 PM
