Old Feb 22, 2002, 10:52 AM
fritts is offline
Find More Posts by fritts
Markle, In. US
Joined Oct 2000
RFS-100 Wire Diagram
Hey guys,
I'm finishing up one of my planes for the RFS-100 system and as it seems have lost my instruction sheet with the wiring diagram. Could somone look up on theirs and post it here so I can get this thing wired up.
Ryan Fritts
fritts is offline Find More Posts by fritts
Old Feb 22, 2002, 11:51 AM
dhurd is offline
Find More Posts by dhurd
dhurd's Avatar
Buffalo, New York
Joined Jan 2002
Fritts,
Look REAL close on the circuit board and it should have thing printed on it that gives you the clue. With the four connectors that are right next to each other you'll see an 'E' and an 'R' for elevator and rudder. You will also see a '+' and a '-' for the battery connections (REAL important that you plug the batteries only into these receptacles and in the postive in the postive and the negative in the negative) The other two on the parameter of the circuit board are for your motor. Just plug the motor in and see if it turns the right way. If not switch the wire around. The receptacly in the center is for the atenna. Hope this helps.
Dan
If you feel you still need the diagram I will email it to you when I get home. Just send me a reminder to dhurd@adelphia.net
dhurd is offline Find More Posts by dhurd
has anyone seen a "Y" harness wire diagram? daveoner Batteries and Chargers 11 Feb 23, 2004 08:57 PM
RFS-100 receiver channel bps Scratchbuilt Indoor and Micro Models 1 Dec 13, 2002 09:46 PM
14" Tomahawk RFS-100 Inari Scratchbuilt Indoor and Micro Models 15 Jul 03, 2002 07:55 AM
CR-2 lithiums with RFS-100 fritts Scratchbuilt Indoor and Micro Models 6 Mar 19, 2002 11:35 AM
RFS-100 isn't working for me? Crasher Scratchbuilt Indoor and Micro Models 29 Mar 14, 2002 12:01 AM
