This thread is privately moderated by Tony Oliver, who may elect to delete unwanted replies.
Old Aug 24, 2009, 03:24 PM
GerbilEssences is offline
Find More Posts by GerbilEssences
depron convert
GerbilEssences's Avatar
Coventry, England
Joined Jan 2009
Originally Posted by Pat Daily
Jerry Paisley's Buffalo
Buffalo Buffalo Buffalo!
GerbilEssences is offline Find More Posts by GerbilEssences
Old Aug 24, 2009, 10:21 PM
Tom Nied is offline
Find More Posts by Tom Nied
Joined Sep 2006
pburress, thanks for the kind words. With a P-Nut, you have to be careful how you add weight. I was recently looking at the original N6016D http://cdn-www.airliners.net/aviatio.../9/0897934.jpg and wished I made the oleo strut more compressed. But at least I made an attempt at it.
Tom Nied is offline Find More Posts by Tom Nied
Old Aug 25, 2009, 01:11 PM
IndoorFlyerABQ is offline
Find More Posts by IndoorFlyerABQ
Closed Account
Joined Jul 2009
Originally Posted by Tom Nied
My Piper Tri-Pacer built from Mooney plans. 5.3 grams
That's a real looker! Did you use the Walt M Piper Colt plan as a starting point? Your model is very realistic, and having the photo documentation in your link shows a very close resemblance. Nice job.
Could you provide some details about your covering job and trim color application. Thanks!
IndoorFlyerABQ is offline Find More Posts by IndoorFlyerABQ
Old Aug 27, 2009, 04:09 PM
Tom Nied is offline
Joined Sep 2006
IndoorFlyerABQ, thanks. Yes I did use Walt Mooney's Piper P.A. 22-108 Colt Peanut plan, dated 3-15-70. Looks like I added the rear windows.
The covering is Gampi tissue applied dry using the butyrate dope method. Two coats of Sig Litecoat diluted 50/50 with thinner is applied to the frame edges. Sanded lightly after it has dried. Then when the tissue is placed on the frame, with a small brush, thinner is brushed over the tissue only where the tissue touches the frame. The thinner soaks through and softens the dried dope, making it sticky and the tissue is pushed down on the part. Sometimes a small dab of dope is needed to get the tissue to stick, but most of the time it sticks. Once I'm happy the tissue is adhered and the excess has been trimmed, the tissue is very gently misted with Isopropyl alcohol. I usually spray into the air above the part and let the particles just gently fall onto the part. The shrinking of the tissue has to be done very carefully, warps can easily sneak in. I like to do opposing sides simultaneously if I can. For color the tissue was gently sprayed with an air brush with artists latex paint that I thin out with water to almost the consistency of milk. I buy that paint at craft stores like Michaels. It's fairly inexpensive compared to hobby shop prices for paint and dries water insoluble. Masking has to be done very carefully. Sometimes just cut paper with rubber cement. I'm sure I used some of that blue painters masking tape, but do yourself a favor, experiment on either a test structure or old airplane. This far into the construction is a bad time to screw things up. When I start a model like this, I like to make what I call some warm-up frames. Its a little extra work but it kind of gets you up to speed when you really have to get things right on the model. Some carefully placed ink lines help it as well. But a small airbrush really allows one to get the paint on thin. You have to make every effort in a Peanut to get it light. Hope that helps.
Old Aug 28, 2009, 12:13 AM
Closed Account
Joined Jul 2009
Thanks! That's very good info--the use of artists' latex really opens up the color palette. I'll have to give that a try.
Old Aug 28, 2009, 07:35 AM
Tom Nied is offline
Joined Sep 2006
I meant to say artists acrylic paints like these. http://www.michaels.com/art/online/d...ductNum=cp0294 And yes, that opens a wide palette for color. They mix well if you need a special color and clean up is with soap and water.
Old Aug 28, 2009, 09:17 AM
Closed Account
Joined Jul 2009
That's really funny--in my reply, I typed acrylics, then went back and edited my post after rereading your description. I guess I thought you said acrylics the first time. Anyway, YES, it's acrylics, and I have some on hand that I will have to experiment with...
Old Aug 28, 2009, 06:23 PM
Tom Nied is offline
Joined Sep 2006
I was re reading my reply and had the horror thought that some guy was going to open a gallon of paint he had left over from painting the living room. Ha! Those paints might work, but we don't have to go that cheap. Only if you want to know the difference follow this link http://dundean.com/tips_what_is_latex_paint.shtml When I buy Artists acrylic, it usually comes in those bottles like you saw in my earlier post for just over $2. Funny in my brain while I was typing latex = acrylic, but there are some significant differences.
Now one more idea. I once knew a guy who colored his tissue with chalk. I asked him how he kept it on the tissue and I remember him saying he guessed gravity was holding it.
When I was airbrushing with artists acrylic, I would spray very fine almost transparant coats. Letting them dry and then applying more light coats until I got to the opacity I could live with. Less is more. It dries so quick, you can pause and watch it dry. Always enjoyed that.
I noticed Harbor Freight has a pretty economical brush.
http://www.harborfreight.com/cpi/cta...emnumber=47791 or
http://www.harborfreight.com/cpi/cta...emnumber=95810
They're probably not the best, but I bet they work just fine for our purposes, just add an air source.
I apologize, I'll stop my yapping. Email me for any further question. I didn't mean to hijack this forum.
Old Aug 28, 2009, 06:36 PM
oldpilot is offline
Find More Posts by oldpilot
oldpilot's Avatar
Australia, NSW, Mona Vale
Joined May 2002
Eleven posts of OT chatter and no pics.
oldpilot is offline Find More Posts by oldpilot
Old Aug 31, 2009, 04:11 AM
gossie is offline
Find More Posts by gossie
Gold Coast Australia.
Joined Jan 2005
Veron ducted fan SABRE.
Just finished the Veron SABRE.
Cox TD 049 power with a Veron fan. 280g/under 10oz ready to fly.
It's modeled 'loosely' on the magnificent RAAF Sabre just restored at Temora Museum NSW. (Do a Google and check it out)
I was fortunate enough to be able to see it some time ago being restored.
gossie is offline Find More Posts by gossie
Old Sep 05, 2009, 04:45 AM
Gluehand is online now
Find More Posts by Gluehand
Gluehand's Avatar
The windy west coast of Sweden
Joined Sep 2008
Swedish Championship Oldtimer F/F 090822
Unfortunately I was unable to go there myself this year, but here are links to a VIDEO ...and to some PHOTOS
Enjoy !
Gluehand is online now Find More Posts by Gluehand
Old Sep 05, 2009, 08:39 AM
Applehoney is offline
Find More Posts by Applehoney
Ajax, Ontario, Canada
Enjoy I did! Good photos and an above-average movie; obviously superb conditions and a good flying site.
Also enjoyed seeing long time friends (over 40 years) Sven-Olov Linden and Sten Persson; please say 'Hi' for me if you meet or are in touch. Also Gunnar Wivardsson.
JM
Applehoney is offline Find More Posts by Applehoney
Old Sep 05, 2009, 11:07 AM
kevin matthews is offline
Find More Posts by kevin matthews
carbondale il
Joined Jan 2007
What a great movie. I'm getting exposed to new free flight stuff and learning a lot. That's a large field there. The largest field I've been going to isn't near that size. My comment about it being big enough for any free flight awhile back wouldn't hold water for those long high flights!
Kev
kevin matthews is offline Find More Posts by kevin matthews
Old Sep 05, 2009, 05:15 PM
gossie is offline
Joined Jan 2005
Thanks for sharing. All my sort of models. Good field. Good weather too.
Old Sep 09, 2009, 04:43 PM
Trisquire is online now
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
My father built this rubber powered Focke-Wulf Fw.56 Stößer in Germany in the '30s:
Trisquire is online now Find More Posts by Trisquire
post your gws slowflyer pics here! buffpants24 Parkflyers 0 Jul 02, 2003 12:38 AM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 09:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
