This thread is privately moderated by Tony Oliver, who may elect to delete unwanted replies.
Old Nov 03, 2008, 10:35 PM
jwfinn is offline
Find More Posts by jwfinn
Free Flight rubber flyer
jwfinn's Avatar
United States, GA, Warner Robins
Joined Mar 2005
Originally Posted by Applehoney
Looked really cool climbing out with the wheels tucked back.
Don't they, though? There's nothing quite like an embryo with retracts. Then again, there's also nothing quite like seeing an embryo pointed straight up and clawing for altitude.
jwfinn is offline Find More Posts by jwfinn
Old Nov 04, 2008, 06:06 AM
flight999 is offline
Find More Posts by flight999
flight999
England
Joined Dec 2002
Just love those 'spats'.
Going to make another one sometime?
flight999 is offline Find More Posts by flight999
Old Nov 04, 2008, 08:25 AM
Applehoney is offline
Find More Posts by Applehoney
Ajax, Ontario, Canada
No thought to do so at this time, Flight
Applehoney is offline Find More Posts by Applehoney
Old Nov 04, 2008, 03:46 PM
Applehoney 220
Old Nov 04, 2008, 05:28 PM
flight999
England
Joined Dec 2002
That aint never going to warp,
that's for sure!!!
Old Nov 05, 2008, 12:09 AM
Chas is offline
Find More Posts by Chas
Voices through wires? Ha!
Chas's Avatar
Joined Feb 2003
The old "Union Jack" seemed the most rigid - I remember building a "Pheobus" by W. Barret from an Aeromodeller plan, with Barnes Wallis type wing rib arrangement, and although it was a lovely flier the washout was there whether you wanted it or not! Jim I see you have two spars on the bottom (?), well forward - was it a rigid arrangement on your 220?
C
Chas is offline Find More Posts by Chas
Old Nov 05, 2008, 08:40 AM
Chas, the spars were on the upper surface. The whole structure was absolutely rigid, I never even bothered to pin down panels when shrinking and doping the surfaces.
This airplane was an exercise in building light - a smaller model than the usual 240's and intended for short-engine-run flyoffs. Tapered spars with some CF, light 1/32" ribs (1/64" in fin), no metal case on timer ... engine was a Kustomised TD049 with Nelson head and plug, chromed shaft, shimmed cylinder, etc. with mounting lugs removed in favour of a backplate radial and running 60% nitro from a pacifier. Dry weight ready to fly was 4.7 ounces.
It trimmed out in three flights. Acceleration was vivid, on 4-5 seconds it was as high - or higher - as the 220's on 7. Then sadly the DT failed and the thing was lost into the Ontario forest; no tracker then ... A shortlived one-off venture .. I could build two 240's in less time than it took to produce this one
Old Nov 14, 2008, 11:44 PM
kevin matthews is offline
Find More Posts by kevin matthews
carbondale il
Joined Jan 2007
The 220, Applehoney, is a very handsome plane. It's my first time seeing the diagonal design you used.
Kevin
kevin matthews is offline Find More Posts by kevin matthews
Old Nov 28, 2008, 02:24 PM
Guizzo 17 is offline
Find More Posts by Guizzo 17
Guizzo 17's Avatar
Joined Sep 2007
I want to shear same photos of my Aviette I build a couple of years ago.
I have being a modeler since 1960 when I was 9 years old, but I started building small rubber models three years ago when a friend of mine lent me the complete collection of books written by Bill Hannan.
My model weights 4 grams, including the pilot I carved from roofmate foam.
Due to the short nose, I made the propeller from a cottage cheese can and I used, a small ball bearing as trust bearing.
Unluckily nobody here fly FF models and this is the reason why I seldom fly my rubber models and my learning curve is quite flat !
Anyway, considering that the Aviette is my first Peanut and the distance from the motor hook and rear hook is only 5 inches, I deem satisfactory flights of 20 -25 seconds.
Guizzo 17 is offline Find More Posts by Guizzo 17
Old Nov 28, 2008, 03:27 PM
Congratulations! Exceptionally fine building, carving and finishing !
Old Nov 28, 2008, 03:34 PM
zl3vml is offline
Find More Posts by zl3vml
Sir Jasper
zl3vml's Avatar
Christchurch - New Zealand
Joined Jan 2003
Wow - absolutely incredible detail for that size.
Well done. Don't lose it
zl3vml is offline Find More Posts by zl3vml
Old Nov 28, 2008, 06:26 PM
dcloin is offline
Find More Posts by dcloin
more balsa please!
dcloin's Avatar
Princeton, In
Joined Jul 2007
Guizzo,
Absolutely beautiful. You have done a wonderful job finishing and with the details. I understand about not having anyone else to fly indoor with. It does make it difficult. I often feel that if there was someone with experience around, it would save hours. At least we have RCGroups.
Darvin
dcloin is offline Find More Posts by dcloin
Old Nov 29, 2008, 05:54 AM
flight999
England
Joined Dec 2002
Lovely little model. quite a flying
performance too.
Pity having to be a lone hand, it
deserves a larger audience. Thank
you for posting the photos.
Old Nov 29, 2008, 08:07 AM
Guizzo 17's Avatar
Joined Sep 2007
Tanks all for your encouragements! I will post more pics of my few F/F models in the near future.
My new F/F winter effort is the COMET "Piper Cub".
I just use the plans provided with the kit to set the dimensions of the model but the way I build it is the one I am more comfortable with.
I wander if the prop supplied in the box is the right size for this model and how much down and right trust the model needs.
Anyone who may give me hints is welcome.
Old Nov 29, 2008, 12:59 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Guizzo,
Superb craftmanship on both your models. Fantastic!
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
post your gws slowflyer pics here! buffpants24 Parkflyers 0 Jul 02, 2003 12:38 AM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 09:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
