This thread is privately moderated by Tony Oliver, who may elect to delete unwanted replies.
Old Aug 03, 2012, 10:33 PM
kpriddle is offline
Find More Posts by kpriddle
Slow 'n Steady...Grease 'r In
kpriddle's Avatar
Maine
Joined Oct 2008
Hello, everyone:
I hope I'm not butting in too much here, but I was just wondering if anyone has been working on any CO2 designs lately.
Kyle
kpriddle is offline Find More Posts by kpriddle
Old Aug 08, 2012, 03:47 PM
kevin matthews is offline
Find More Posts by kevin matthews
carbondale il
Joined Jan 2007
This is my latest, a messed up Westland Whirlwind from Easy built Models. I changed the wing dihedral break and added dihedral. I shortened the fuselage by one bay. I enlarged the stab and lengthened the nacelles. The elevators are operational. The props are heavy Guillow's kit props for the needed nose ballast. The dope is Deft semi-gloss over Easy Lite tissue. The graphics are Tissuecals.
Kev
kevin matthews is offline Find More Posts by kevin matthews
Old Aug 08, 2012, 08:51 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
Looks neat. Did you try flying it yet?
aeronca52 is offline Find More Posts by aeronca52
Old Aug 08, 2012, 10:00 PM
carbondale il
Joined Jan 2007
No, not yet. It isn't very heavy and it balances just about right without any added weight. I'm going to try it out with just a single loop of 3/16" for each prop to start. It's been so darn hot here. This one was a real bear to build. To hold the props in place after winding I've attached an aluminum tube underneath each nacelle to hold a wire which will stick out beyond each prop. I'll tie a string to the wires and then pull them both away at once.
Kev
Old Aug 09, 2012, 12:35 PM
draganbt is offline
Find More Posts by draganbt
yes, its a flying lamb :)
draganbt's Avatar
Bitola, Republic of Macedonia
Joined Apr 2009
That's a great looking plane Kev.
You need to post more pictures man I'm trying to learn how to build like that!
draganbt is offline Find More Posts by draganbt
Old Aug 09, 2012, 05:12 PM
carbondale il
Joined Jan 2007
I had to pick this up today, mostly out of curiosity. It's 20" and extremely heavy. The rubber is 4 loops of 1/8" supplied with the kit. The instructions call for 200 winds which gives the motor run about 5 seconds of unwinding. Both props turn with a complicated system which is what is weighing so much. The props lock while a ratchet type winder at the nose is turned by a removable handle. Then the lever unlocking the props is switched and the props unwind.
Kev
Old Aug 09, 2012, 05:23 PM
carbondale il
Joined Jan 2007
Thanks draganbt. Next time I'll post a build log. I'm pretty good at problem solving in building airplanes. Sometimes the kit plan leaves out information which needs to be thought through and problems solved. I have a lot of experience and that helps. I'm not happy with the Deft brand lacquer for dope. The blue tissue underneath has a lot of blushing and finger nail polish remover doesn't work to remove that like it does with Sig brand dope. I think I've said this before but use the dope made for model airplanes.
Kev
Old Aug 09, 2012, 08:17 PM
Culper Junior
eastern pa
Joined Feb 2007
Kevin,
You need to build a twin pusher for the 'twin' experience.
http://www.antiquemodeler.org/sam_ne...l_wightman.htm
I have seen some people launch twins by holding a large piece of soft foam (chair cushion) up against the bottom of the model to still the props. Just pull the foam away and launch.
Course you still have to hold one prop still while winding the other.
Old Aug 17, 2012, 04:49 PM
Megowcoupe is offline
Find More Posts by Megowcoupe
Balsa Flies Better!
Stamford, CT
Joined Oct 2000
Kev
What I've been doing is holding the left prop tip in my mouth and the right prop with my left hand. As long as you don't get too hungry and bite off a blade, this actually works quite well- it's comparable to a single prop launch.
Sam
Megowcoupe is offline Find More Posts by Megowcoupe
Old Aug 17, 2012, 06:33 PM
maxxnut is offline
Find More Posts by maxxnut
Hoarding balsa is a sickness
smokey point, wash.
Joined Dec 2003
I hold the smaller props in my mouth while I wind the motor, then when the motor breaks, I get snapped in the bottom of the nose...arrgghhhh
maxxnut is offline Find More Posts by maxxnut
Old Sep 03, 2012, 01:07 AM
Eratix 3D is offline
Find More Posts by Eratix 3D
Am I a Registered user?
Eratix 3D's Avatar
United States, CO, Grand Junction
Joined Feb 2012
My planes arent verry good compared to all those nice planes, I have a Sterling Diamant sailplane, Sterling Stuka N.I.B. in the plastic, Sterling F-4-U1 N.I.B. , plastic wraped, Easy Build Models Ritz, Guillows Mosquito, Heavy Guillows Fock wulf, And many, Many more. The complete ones fly like rocks, any tips on flying?
Eratix 3D is offline Find More Posts by Eratix 3D
Old Sep 03, 2012, 08:56 AM
Culper Junior
eastern pa
Joined Feb 2007
Eratix,
The kits you are referring to mostly had heavier than needed balsa. Try the Ritz or this http://www.easybuiltmodels.com/ff12lc.htm
Most of the EB kits now have very nice light balsa and the designs fly well. The best way is to keep at it, building, covering and flying. Practice, practice, practice. We all started somewhere.
Old Sep 09, 2012, 05:54 AM
Dustbin is offline
Find More Posts by Dustbin
Dustbin's Avatar
Roedermark, Germany
Joined Mar 2002
Latest two from my board. A peanut T-Tail RIVETS fro a plan by Mark Drela, and a FROG Senior Series "Heron".
The RIVETS has been test glided, but the Heron has suffered the "cluttered backyard syndrom", and has to wait till I get to the flying patch.
Dustbin is offline Find More Posts by Dustbin
Old Sep 10, 2012, 01:19 AM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
Beauty planes Dustbin. I especially like the looks of the FROG Heron!
Dave-
foamdave is offline Find More Posts by foamdave
Old Sep 10, 2012, 02:47 PM
Guizzo 17 is online now
Find More Posts by Guizzo 17
Guizzo 17's Avatar
Joined Sep 2007
I second Foamdave. The Heron is on my building list since a long time!
Guizzo 17 is online now Find More Posts by Guizzo 17
post your gws slowflyer pics here! buffpants24 Parkflyers 0 Jul 02, 2003 12:38 AM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 09:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
