This thread is privately moderated by Tony Oliver, who may elect to delete unwanted replies.
Old Jul 14, 2012, 01:51 AM
zl3vml is offline
Find More Posts by zl3vml
Sir Jasper
zl3vml's Avatar
Christchurch - New Zealand
Joined Jan 2003
Originally Posted by Applehoney View Post
"Hazey" decently dressed
36" span, 14" prop, 58 gms (less tracker)
Good luck Jim, looks good.What is the weight of the motor? (rubber)
Mark
zl3vml is offline Find More Posts by zl3vml
Old Jul 14, 2012, 03:08 AM
flight999 is offline
Find More Posts by flight999
flight999
England
Joined Dec 2002
She does look better dressed Jim. Good luck with your trip.
Thermals all the way.
flight999 is offline Find More Posts by flight999
Old Jul 14, 2012, 06:09 AM
oldpilot is offline
Find More Posts by oldpilot
oldpilot's Avatar
Australia, NSW, Mona Vale
Joined May 2002
Good luck at Genesco Jim.
And that is a really nice crisp version Pat.
oldpilot is offline Find More Posts by oldpilot
Old Jul 14, 2012, 09:06 AM
Applehoney is offline
Find More Posts by Applehoney
Ajax, Ontario, Canada
Dunno yet. Will try 30gms for a start... maybe move to 35 depending upon how it shapes up
Applehoney is offline Find More Posts by Applehoney
Old Jul 14, 2012, 02:18 PM
DuPageJoe is offline
Find More Posts by DuPageJoe
USA, IL, Wheaton
Joined Oct 2010
Comet Phantom Fury
Just finished Comet Phantom Fury from a Comet Kit. It has 32 inch wing span and about 100 square inches wing area. It weighs 45 grams with 5 grams of rubber and 2 grams of clay in the nose. Seems to fly best with CG at 50% chord. Checked it after adding clay by holding up the wing tips. Has a stab of about 27 square inches pushing the center of lift back a bit. Stuck pretty close to box color scheme.
Joe
DuPageJoe is offline Find More Posts by DuPageJoe
Old Jul 14, 2012, 03:28 PM
ECBoehm is offline
Find More Posts by ECBoehm
1:1 scale is fun!
ECBoehm's Avatar
United States, NJ, Midland Park
Joined Feb 2009
Nice Phantom Fury! A real classic.
ECBoehm is offline Find More Posts by ECBoehm
Old Jul 16, 2012, 11:14 AM
USA, IL, Wheaton
Joined Oct 2010
First Flights - Phantom Fury
Thanks for the compliment. Now to get it to fly as good as it looks.
Took it to an old timer contest in Wisconsin yesterday. The 5 gram motor (4 strands 1/8 inch Tan Sport from FAI Supply 13 inches long) was enough at 500-600 turns to get a little starting height into about 5 mph winds. After that, got a quick left turn and a relatively straight 50 feet or so down wind, followed by a Dutch roll to inverted and a fairly short trip to the ground. Had better times with my Delta Dart. Have seen posts that say fins on these old planes were a bit too large, but I think small warps in the stab were probably to blame.
A bit of a handfull to wind with the tail joint, and need a better cradle for the front section on my stooge. May also make a new stab with some diagonals so it'll stay flat. Hooks made of pins to anchor wing and landing gear elastic bands worked OK. More rubber may get me up out of turbulence.
The Gollywocks were catching thermals and going way high.
Fly and learn
Joe
Old Jul 16, 2012, 02:25 PM
flight999
England
Joined Dec 2002
Not a patch on yours, mine used to be worth about
40 seconds. No funnies, it flew well. Did have a decent
hand carved balsa prop which may have helped..... and,
though I didn't know it then, good T56 rubber motor. Probably
4 strands of 1/4". A lot more than 5gms. and no weight in the
nose. Could be heavy wood wheels instead.
Old Jul 17, 2012, 04:04 PM
scrubs is offline
Find More Posts by scrubs
scrubs's Avatar
United States, NM, Rio Rancho
Joined Dec 2004
Mini Mojo from plans in the "A few FF plans added" thread blown up to 18". Added a bit of incidence on the wing and tail since there was none on the original plan. Also reduced LE & TE sizes a hair but otherwise stock.
scrubs
scrubs is offline Find More Posts by scrubs
Old Jul 17, 2012, 10:58 PM
kevin matthews is offline
Find More Posts by kevin matthews
carbondale il
Joined Jan 2007
Very sharp, scrubs.
kevin matthews is offline Find More Posts by kevin matthews
Old Jul 18, 2012, 04:17 AM
flight999
England
Joined Dec 2002
Bet it would make a nice indoor
flier, particularly with the lighter
wood sizes.
Old Jul 23, 2012, 03:05 PM
USA, IL, Wheaton
Joined Oct 2010
Anna Jr. Embryo from kit by BMJR
I built this Anna Jr. Embryo from a kit by BMJR to perhaps beat my venerable Peck Prairie Bird. It turned out a bit heavier than the instructions say at about 25 grams with a 3 gram motor (12.5 inches X 4 strands 3/32 inch wide Tan Sport). With 540 turns on it in a confined field I got about 25 seconds duration. The instructions give an outdoor setup of 14 inches X 4 strands 1/8 wide Tan rubber, which is roughly 5 grams, and say to wind to 875 turns. There is an adjustable rudder trim tab made from windshield acetate, as per instructions.
It is a pretty flyer. They say it can be flown indoors, but looks like the venue had better be fairly big.
Joe
Old Jul 23, 2012, 03:12 PM
scrubs is offline
scrubs's Avatar
Joined Dec 2004
Looks good Joe. IIRC it's a Thomas Lee design from the small flying arts site. At less than a 10% motor with the 3/32 I'm sure there's a lot more to come.
scrubs
Old Jul 23, 2012, 03:20 PM
USA, IL, Wheaton
Joined Oct 2010
Thanks Scrubs
What's the weight on your Mini Mojo? Do you think it could be built to Bostonian rules? the fuselage looks pretty deep. You'd have no trouble getting some "Charisma" points,
Joe
Old Jul 23, 2012, 05:10 PM
scrubs is offline
scrubs's Avatar
Joined Dec 2004
The Mini Mojo came out at 20 gms less rubber and ballast. But that is making no effort to save weight. I used 3/32 for the fuse and you wouldn't do that on a Bostonian. You'd also cut the LE & TE stock way down. I'd also build a flat stab and add wing incedence.
You'd have to cut the chord down a bit to fit Bostonian rules and add landing gear. My 18" job is a bit under 16" long so you would probably want to lengthen the tail moment as much as possible at Bostonial size.
It would look cool cruising the hall at Racine if you do the Bong indoors.
scrubs
post your gws slowflyer pics here! buffpants24 Parkflyers 0 Jul 02, 2003 12:38 AM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 09:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
