This thread is privately moderated by Tony Oliver, who may elect to delete unwanted replies.
Old Nov 05, 2011, 04:25 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Bo Weevil
Nothing fancy, but the first FF model I have built in more than 20 years
Actually started it more than 30 years ago, about time I completed it
Held the camera in one hand, threw the model then took the pictures.
And not a picture, but here is a video:
CIMG0759 (0 min 43 sec)
Next up - a rubber model of some kind.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Nov 05, 2011, 04:57 PM
flight999 is offline
Find More Posts by flight999
flight999
England
Joined Dec 2002
Nicely trimmed out. How about some
more detail?
flight999 is offline Find More Posts by flight999
Old Nov 05, 2011, 05:12 PM
pmackenzie's Avatar
Joined Dec 2002
You can buy the kit from Campbell's, or the plans can be found on here:
http://www.rcgroups.com/forums/showp...postcount=6262
And the article as well:
http://www.rcgroups.com/forums/showp...postcount=6270
(I asked in that thread since I had long since lost my original copy)
Weight came out close to the article, 37 grams versus the suggested 1.25 ounces = 35.4 grams. Finish is 3 coats of Minwax Polycrylic, put on then wiped off with a blue lintfree "shop" towel.
Much nicer to deal with than dope, but seals so well it makes it a bit harder to do the "breathe on it and twist" method of making adjustments.
You make an adjustment and then over the course of a few flights it would go back to neutral. I ended up having to make little cuts in the surfaces and glue the adjustment in.
The model trimmed out very easily, I was surprised that I could still throw it and get it trimmed. .
I do think it might be a bit nose heavy as it tends to want to loop in the throw, but the transition is very predictable as it is set right now.
The weather that day was perfect, almost no drift and the thermals were not so strong as to cause it to fly away.
Longest flight was 3:20, a couple just over 2: and a few more at ~1:30. Then a whole bunch at 30 - 45 seconds depending on how well the throw and transition went.
Sort of neat to watch in a thermal, the plane kind of rolls a bit from side to side when it is in lift, probably from the turbulence.
Pat MacKenzie
Old Nov 05, 2011, 07:16 PM
gossie is online now
Find More Posts by gossie
Gold Coast Australia.
Joined Jan 2005
Good chucking.
gossie is online now Find More Posts by gossie
Old Nov 05, 2011, 07:22 PM
pmackenzie's Avatar
Joined Dec 2002
Originally Posted by gossie View Post
Good chucking.
Spent most of the day doing it, even though I had a few high$ sailplanes sitting in the pits.
I was sore for a week after all that chucking!
Now the weather has gone bad and I might not get anther chance till spring
Pat MacKenzie
Old Nov 05, 2011, 08:45 PM
ColinNZ is offline
Find More Posts by ColinNZ
ColinNZ's Avatar
Auckland New Zealand
Joined Aug 2004
Nice flight , really enjoyed that.
ColinNZ is offline Find More Posts by ColinNZ
Old Nov 08, 2011, 08:10 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
Originally Posted by colinnz View Post
nice flight , really enjoyed that.
ditto!!
aeronca52 is offline Find More Posts by aeronca52
Old Dec 07, 2011, 09:04 PM
Joined Jan 2005
Freeflight power model.
Freeflight power model after 3 or 4 months of work.
65in span, Rossi 15 on hard tank pressure, flood off and brake to stop it. Carbon prop.
Auto rudder and variable incidence tailplane and DT activated by Seelig timer.
Pics tell the best story I guess.
Old Dec 08, 2011, 12:58 AM
perttime is offline
Find More Posts by perttime
perttime's Avatar
Finland
Joined Nov 2004
We also need to know if it is already trimmed so that it is safe to get out of the house...
perttime is offline Find More Posts by perttime
Old Dec 08, 2011, 03:31 AM
flight999
England
Joined Dec 2002
Nice looking model Gossie.
Errr....... Your flower pots look like they could use some T.L.C.
Old Dec 08, 2011, 03:00 PM
Joined Jan 2005
Just relax "perttime". Mine don't crash, they are built to fly. I truly have never crashed one like this. They are easy to trim, and beautiful to fly.
"flight99". Your right re. the flower pots. "The Boss" just ripped some old stuff out a couple of days ago. New pretty things going in on the weekend she tells me.
Old Dec 08, 2011, 09:41 PM
colibriguitars is offline
Find More Posts by colibriguitars
Joined Mar 2011
Hi! My scamp first flight
Frog Scamp free flight rubber Flight one (0 min 14 sec)
The second one!
Frog Scamp Free flight rubber fligth 2 (0 min 16 sec)
colibriguitars is offline Find More Posts by colibriguitars
Old Dec 09, 2011, 04:12 AM
perttime is offline
perttime's Avatar
Finland
Joined Nov 2004
Whew...
I've never actually seen one fly. But, somehow, I've gathered that the results can be spectacular if the wrong things go wrong with a power model.
Old Dec 10, 2011, 09:46 AM
jwfinn is offline
Find More Posts by jwfinn
Free Flight rubber flyer
jwfinn's Avatar
United States, GA, Warner Robins
Joined Mar 2005
Originally Posted by perttime View Post
Whew...
I've seen a few go off track and get quite scary, but most locked-down models like Gossie's masterpiece there are quite predictable. Worst I've seen a locked-down do is fold a wing and tumble into the ground. Scary moments do happen, but fortunately aren't that common.
I've seen a lot of RC models get into trouble. Compared to them, FF is quite safe, even in F1C where you're right on the edge.
jwfinn is offline Find More Posts by jwfinn
Old Dec 10, 2011, 06:51 PM
Joined Jan 2005
Thanks for the compliment Josh, but this power model of mine is not really locked down as such.
Locked down to me means wing and tail and fin/rudder do not move. We often lock down the stab. in a flyoff so the DT does not work so as the flight goes as long as possible.
This model has a moving rudder about 1/2 the area of the fin that is pretty much straight as the model is climbing vertically under power, then as the engine is shut off via the timer using flood off and a brake, the rudder at the same time moves about 3/16th to the right kicking the model off from the vertical.
A couple of seconds later the stab. raises about 1/8th at the rear to put the model into glide mode. The down stab. keeps the model stable on climb.
Everything is adjustable via small screws to trim the model for best performance.
I should add this new model of mine is very old style as such......very '70s/'80s, as that's how we made them back then. The latest and greatest are far more complicated and far beyond my capabilities.
post your gws slowflyer pics here! buffpants24 Parkflyers 0 Jul 02, 2003 12:38 AM
Post your Viper Twin Pics Here! Zagi-Extreme Foamies (Kits) 3 Mar 30, 2003 09:04 PM
Post Your Zagi 400X Pics Here HavingFun2002 Foamies (Kits) 63 Feb 02, 2003 01:21 AM
Post your Aeroflakes meet pics here Jgardner Scratchbuilt Indoor and Micro Models 38 Jan 24, 2003 03:44 PM
Post your fun fly pics here. Paul Susbauer 3D / Fun Fly Fuel Planes 8 Jan 23, 2003 03:11 AM
