Old Feb 18, 2012, 08:29 PM
DL8698 is offline
Find More Posts by DL8698
DL8698's Avatar
Singapore
Joined Mar 2008
Originally Posted by jfacky View Post
I would use some machinest dye on the piston and "run" it up and down the liner a few times. It will show you the high spot by being rubbed off. Then use a jewlers file or emery board to take down the high spots
HTH
Jim
I have taken out the liner and piston. I find that there may be a very slight high spot in 2 places which i am working on now to remove.
I have a question, regarding the piston diameter. Does the bottom edge of the piston skirt have identical size as the top of the piston? I seem to see the top of the piston go into the liner very easily and smoothly, while the bottom of the skirt at about 3-4 mm from the bottom edge starts to get a bit of friction.
I'm not sure if this is due solely to the high spots which I will try to remove, or is the piston meant to have a bit of interference near the bottom edge, for crankcase compression, maybe?
Should I keep working on the high spots till the piston slide in smoothly, just as it does with the upper part of the piston, or should I stop once I've removed the high spots. BTW, the piston seems to be a real soft material, cos I'm causing quite a bit of scoring marks with my jeweller file and 600 emery paper.
DL8698 is offline Find More Posts by DL8698
Old Feb 19, 2012, 01:21 AM
jfacky is offline
Find More Posts by jfacky
What goes up must come down
jfacky's Avatar
USA, GA, Snellville
Joined Oct 2005
on glow motors, The liner is tapered towards the top and the piston is the same diameter top to bottom. on larger displacement engines (automotive ect) the piston is tapered larger at the top and narrower at the skirt.
It's ok t remove a little bit more than needed to stop the piston from rubbing as long as its not from the top sides, just the bottom of the skirt.
And yes it could do much more damage to the liner than is already there.
HTH
Jim
jfacky is offline Find More Posts by jfacky
Old Feb 19, 2012, 09:54 PM
DL8698 is offline
DL8698's Avatar
Singapore
Joined Mar 2008
I managed to start the engine after just a few turns, but this time I had the glow nice and lighted although not really all that bright. But as I was trying it out on my front yard and probably waking up my late sleeping neighbours, I only ran her for a few seconds, just to see if she will even fire up at all, with my 20+ years old methanol.
Later I will go the flying field and give her a good, real rich run in to seat the piston properly again.
Thanks for everyone's help and advice.
Need a little tuning help with an old Fuji 25-S Cycletherapy Engines 9 Jan 10, 2005 12:33 PM
Question Need help with an old Playtron gas buggy iamplanecrazy2 Nitro and Glow Power Cars 1 Nov 20, 2004 04:29 PM
I Need Help With An ACE Micropro 8000 RazorB Power Systems 5 Mar 08, 2002 10:19 PM
