Old Nov 07, 2004, 09:27 PM
DennisRB is offline
Find More Posts by DennisRB
Sand it round!
DennisRB's Avatar
Brisbane Australia
Building EPP flying wings from scratch
I think I want to get setup to make my own EPP wings from scratch. I tried to do a search on foam cutting and got some ideas and a lot of conflicting information, so I'm still not sure what I need and where I can get it.
I was thinking of using the "bow" method, but I'm not sure where I can get suitable high resistance wire and what type of power supply is the best (cheapest )
Also where is the best place to get EPP and how expensive is it?
Cheers
DennisRB is offline Find More Posts by DennisRB
Old Nov 07, 2004, 09:35 PM
steve wenban is offline
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Dennis I use 2 12volt deep cycle car batteries through 032" stainless lire I have found this to be the best combo for my cutting this one of my small bows which works great.
steve wenban is offline Find More Posts by steve wenban
Old Nov 07, 2004, 09:37 PM
Joined Dec 2003
PS you dont want high resisitance wire you want something with the lowest resistance you can get
Old Nov 07, 2004, 10:31 PM
DennisRB is offline
Sand it round!
DennisRB's Avatar
Brisbane Australia
I was worried about shorting the power supply out, but I suppose once it heats up the resistance will increase enough to limit the current (sounds scary though)
Are you just, hooking 2x12 to make 24V, do you use any form of resistors? Where do you get the wire and foam?
Cheers
Old Nov 07, 2004, 10:37 PM
Joined Dec 2003
the EPP from Kye of Wowings fame and the EPS you can get just about anywhere no resistors if Iam cutting hot I'll use the batteries wired in series to give me 24volts but normal cutting just parrallel 12 volts
Old Nov 07, 2004, 10:38 PM
Joined Dec 2003
PS fishing stores carry stainless trace with out the nylon covering
Old Nov 07, 2004, 10:42 PM
DennisRB is offline
Sand it round!
DennisRB's Avatar
Brisbane Australia
Thanks. How long of a span of EPP would one 12V battery cut?
Old Nov 07, 2004, 10:44 PM
Mick Molloy is offline
Find More Posts by Mick Molloy
MINE!
Mick Molloy's Avatar
Australia, VIC, Point Cook
Joined Jul 2003
I have plenty ok .020 lockwire Dennis, also a friend will cut wings as required on his CNC cutter, I think about $20 you supply the EPP for a wing.
A 12v battery and a light dimmer switch work well
Mick Molloy is offline Find More Posts by Mick Molloy
Old Nov 07, 2004, 10:47 PM
DennisRB is offline
Sand it round!
DennisRB's Avatar
Brisbane Australia
Thanks, $20! Thats alright. Is that per section or what?
Old Nov 07, 2004, 11:08 PM
Joined Dec 2003
there ya go Dennis problem solved
Old Nov 07, 2004, 11:11 PM
DennisRB is offline
Sand it round!
DennisRB's Avatar
Brisbane Australia
Maybe I would still like my own cutter though, but the CNC sounds like it would do a better job.
Old Nov 07, 2004, 11:16 PM
Joined Dec 2003
only worth the effort if you are going to cut heaps of wings takes up alot of room on your bench so if your only cutting the occasional set its not worth the cost and effort to det up the cnc machine
Old Nov 07, 2004, 11:25 PM
AntonL is offline
Find More Posts by AntonL
antipodean recalcitrant
AntonL's Avatar
Melbourne, Victoria, Australia
Joined Feb 2004
Steve, I think Mick was saying that his friend would cut them to order.
Mick - OOI, roughly how much does your friend charge for labour to cut a set of cores?
AntonL is offline Find More Posts by AntonL
MINE!
Joined Jul 2003
I second that its a lot of effort you could have made 100 wings in the time it takes to setup a cnc.
Old Nov 07, 2004, 11:31 PM
Joined Dec 2003
yep but dennis was still keen to have a go at cutting his own as well just thought I throw in the setup time and value for a cnc machine
Discussion Sport Flyers Wild Wing EPP Flying Wing from hobby people FRAMEDNLVS Flying Wings 1154 Jan 23, 2014 03:28 PM
Building an RC Boat from scratch gamer_dave Dock Talk 9 Mar 01, 2005 11:10 PM
Move Flying Wings From General AC Topics To Airplanes - Electric Bob_Smith Site Chat 1 Aug 09, 2004 08:28 PM
WTB: Direct 280 EPP flying wing from Hobby Lobby uabass Aircraft - Electric - Airplanes (FS/W) 3 Jul 08, 2004 10:59 AM
Building a Flying wing from scratch LyndonC Foamies (Kits) 2 Jun 29, 2001 08:15 PM
