Old Dec 15, 2004, 02:59 PM
Willie Levi is offline
Find More Posts by Willie Levi
Slow Tiger Stick Moth
Willie Levi's Avatar
Austin, Texas
Joined Oct 2003
Alright, I just got my LiPo (Etec 2 cell 1200mAh) in the mail today and will be soldering the connector on tonight.
I have a question though. When charging (using Triton), I should set a high voltage cut-off right? As I understand it, the pack will sit at 8.4v fully charged. But I remember my Triton giving readings of 10-12v sometimes when charging 8.4v NiMh packs. Will I see the same kind of voltage readings when charging the LiPo?
So, how should I make sure I don't overcharge?
Thank you!
Willie Levi is offline Find More Posts by Willie Levi
Old Dec 15, 2004, 04:46 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Lipo charge voltage should NOT exceed 4.2V/cell. The Triton will start the charge at the selected current and charge at that rate until the pack voltage reaches 4.2V/cell at which time the voltage will remain at 4.2V/cell but the current will start to drop. If the V exceeds 4.2V/cell, the pack will be damaged and perhaps burn. That has happened to modellers setting their chargers for 3 cells when charging a 2 cell pack. The charger should automatically maintain 4.2V after the constant V cycle has started if the initial settings were correct.
3.7V for 1 cell pack
7.4V for 2 cell pack
11.1V for 3 cell pack
hoppy is offline Find More Posts by hoppy
Old Dec 15, 2004, 10:25 PM
supi7 is offline
Find More Posts by supi7
supi7's Avatar
CHICAGO
Joined Feb 2004
May I suggest a li-po from TrueRC. the 2100 mah cells are very affordable. You can build your own pack CHEAP or you may also order a ready made pack with deans connector for additional $10.
http://home.comcast.net/~truerc
You can order online or just call.
Best Regards,
Dan
TrueRC
supi7 is offline Find More Posts by supi7
Old Dec 15, 2004, 10:31 PM
Austin, Texas
Joined Oct 2003
Thanks hoppy! I'm checking it for capacity as we speak.
Sorry supi7.. Balsa Products already got my business
Old Dec 15, 2004, 10:35 PM
supi7 is offline
supi7's Avatar
CHICAGO
Joined Feb 2004
Yes they have good products as well. Please consider us on your next project.
Best Wishes,
Dan
TrueRC
Old Dec 16, 2004, 07:36 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Best Regards,
Dan
TrueRC
How about a 5C discharge graph at 1 and 25 cycles?
Old Dec 16, 2004, 06:52 PM
supi7 is offline
supi7's Avatar
CHICAGO
Joined Feb 2004
as soon as I get my hand on some equipment I will post graph results. Right now all I can post are emails of Happy Costumers.
Old Dec 17, 2004, 03:10 AM
supi7 is offline
supi7's Avatar
CHICAGO
Joined Feb 2004
4130 AXi test
Tested a 4130 Axi motor (BIG MONSTER) with a 14x7 prop on a Phoenix 45 and a 4000mAh 11.1V Lipo from TrueRC
we did not have anything but a stop watch and a volt meter
we started at fully charged (week ago) 4000mah lipo and after 11 minutes of WOT the pack was still going strong and it was cool to touch. We got bored waiting for LVC and the end voltage was 11.28V.
Will test again on same setup next Thursday but at 22.2V of 4000mah
I will also make 4 2100mah packs for that plane and we will test at 22.2v as well.
Thats all for now
Thank you
Dan
TrueRC
Old Dec 17, 2004, 07:41 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
According to motocalc, the 4130-16 with that setup draws 10.5A and the 4130-20 draws 6A so we're looking at 2.6C for the 4130/16 motor and 1.5C for the 4130/20 motor.
With the 4130/16 and a 6s pack, 22.2V, motocalc is showing 28A or 7C and the 4130/20 is showing 16A or 4C.
By the way, which motor is it?
Old Dec 19, 2004, 12:53 AM
supi7 is offline
supi7's Avatar
CHICAGO
Joined Feb 2004
hoppy, its the 4130/16
next Thursday we'll be testing it again at 22.2V 4000mA setup
and at 22.2V with four 11.1V 2100mA packs
I should have some Watt Meter result for you.
Discussion My first lipo setup...can someone advise, I dont want to blow myself up! tobys550 Batteries and Chargers 13 Aug 06, 2007 09:14 AM
My first lipo problem mikeb33 Batteries and Chargers 23 Nov 13, 2004 11:52 AM
My First Lipo, Need Help, Whats with the two wires? Photo Attached for reference ontheweekend Batteries and Chargers 8 Sep 10, 2004 08:47 PM
help save my first lipo philip frank Batteries and Chargers 3 Aug 20, 2004 12:25 AM
Help! My first Lipo pack death! EABiker Batteries and Chargers 7 Apr 29, 2004 01:26 PM
