Old Nov 06, 2004, 06:25 AM
agapornis is offline
Find More Posts by agapornis
agapornis
italy
Joined Jul 2004
Urgent,best Lipo Batteries For Movie Star Multiplex
Hello to everyone.
To day i have done my first fly with my new MOVIE STAR without any pay loading.
I use multiplex permax 400 motors reducted .i have used a lipo 11,1 v 1500 mah.
Do you think that it is better to use a 7,4 lipo 2000 or a 11,1 lipo 2000 0r 3000 batteries.
Also the with the reducted it seems a bit noisy.
Thank's
agapornis is offline Find More Posts by agapornis
Old Nov 06, 2004, 07:10 AM
I Crash Often
I Crash Often
Guest
n/a Posts
I have never heard of the Movie Star.
Can you give me a link to a web site that has it?
Old Nov 06, 2004, 06:45 PM
Arthur P. is offline
Find More Posts by Arthur P.
Hoofddorp, Netherlands
Joined Sep 2004
Moviestar experiences
See http://home.online.no/~la9ex/MovieStar/moviestar.htm for some pics.
See also http://www.gpsflight.com/GPSF/Users/moviestar.htm
See http://plawner.net/4/moviestar/per_tidemann/ for a brushless setup.
See http://www.multiplex-rc.de/ for the manufacturer.
There are also one or more threads in RcGroups about the MovieStar, only one of which ended on a more positive note after upgrading to two brushless motors.
I also have one and so far haven't been too happy. It's big and heavy. If you want to turn sharply at low altitude shortly after takeoff you might want to sent your camera to the Macro picture position... (luckilly I didn't have a camera in it tht time). It comes with two Speed 400 standard. I have upgraded with two gearboxes, but still find it less than optimally powered. And of course the gearboxes are a bit noisy. So far I-ve only flown on a 8.4V 1700mAh NiCad battery pack (400 grams!). I intend to upgrade this to LiPo's (11.1V 1200mAh 2 in parallel = 2400mAh at 165 grams). One of the above links is actually flying with about 4Amps of LiPo's and two brushless.
The aluminium tailboom on mine came loose twice during flights despite CA-ing and later epoxying it into the fuselage. Bit difficult to control if elevator actions just pull the whole tail in and out of the fuselage but not much more. I-ve now resorted to using polyuerthane glue (which should work Ok as the foam used is actually also polyurethane based).
I-ve already decided to go for a Depron / Fanfold RcGroups or own design for aerial photography. Should be possible to build something with a roughly similar span but at about half the weight of the MovieStar (and thus with a lot more carrying capacity if you do want to load it up). Actually, I-m thinking about modeling the ARES mars-plane () for that purpose.
Arthur P. is offline Find More Posts by Arthur P.
Old Nov 06, 2004, 06:47 PM
Joined Sep 2004
Moviestar vs Marsplane
Sorry, forget to add that in the previous re. Here's the link for the ARES mars plane: http://marsairplane.larc.nasa.gov/index.html.
Lipo Batteries for Twin Jet (Multiplex) superboss Foamies (Kits) 11 Dec 31, 2004 05:17 AM
Best LiPo Replacement for 10-Cell Sub-C pgleesonuk Batteries and Chargers 4 Dec 23, 2003 12:46 PM
Best Lipo's for 11.1 volt 22amps? flierbk Batteries and Chargers 8 Nov 25, 2003 09:48 PM
Best lipo pack for 11 amps? flierbk Electric Heli Talk 2 Nov 14, 2003 07:05 PM
Batteries for a Twin Star 7cells which capacity? NiCad/NiMh v4mpy Foamies (Kits) 6 Jul 28, 2002 09:04 AM
