Old Nov 05, 2004, 06:57 PM
RCElec is offline
Find More Posts by RCElec
RC Electronics, Inc.
RCElec's Avatar
USA
Joined Nov 2004
New "Watt's Up" Watt Meter Adds Case Colors, Peak Amps, Min. Volts and More
RC Electronics is pleased to announce that our “Watt’s Up” watt meter is now in stock and available for purchase in three colors - Onyx, Kryptonite and Electric Blue. The latter two are transparent colors.
Instead of just wondering, “Watt’s Up” helps you know important things like, current through your ESC and motor, battery health and actual charge.
We humbly think “Watt’s Up” offers the best balance of power analyzer features on the market.
In addition to the features you expect in a watt meter, we've added some unique features including:
  • Capture of peak amps and minimum volts over the measurement duration
  • Connecting a receiver battery to the auxiliary power input allows measurements down to 0 volts e.g. you can measure a single battery cell
  • Resolutions of 0.01 A, 0.01 V, 0.001 Ah, 0.1 W and 0.1 Wh over entire operating ranges
  • Designed to handle 3000 W (60 V x 50 A) continuously and 6000 W (100 A) for shorter durations
  • Small size – like a big pack of gum, and weight – 2.5 oz. So you can pack more gear
A picture of the Kryptonite version next to the two other available colors is attached.
The introductory price is $59.95 with FREE SHIPPING and we are giving a discount if you buy more than one.
You can get more information on the Watt's Up RC Watt Meter and buy it on-line at our website. “Watt’s Up” is also available at select dealers.
We are looking for more product reviewers. Please contact us if you are interested and have relevant experience.
Thanks for taking the time to consider "Watt's Up"!
-The RC Electronics Team
RCElec is offline Find More Posts by RCElec
Site Sponsor
Old Nov 08, 2004, 06:29 PM
flatfour is offline
Find More Posts by flatfour
Right Honorable Member
flatfour's Avatar
Chicago Midway, Illinois, United States
Joined Jul 2003
Is there a button to alternate the display mode, or is it automatic?
flatfour is offline Find More Posts by flatfour
Old Nov 09, 2004, 12:12 AM
RCElec is offline
RCElec's Avatar
USA
Joined Nov 2004
A good question that we should have addressed.
No, there is no button.
The two display screens alternate continuously every three seconds. You can tell which is which by the presence of the 'p' and 'm' suffixes indicating Amps peak and Volts minimum.
Thanks for asking.
-K
Site Sponsor
Old Nov 09, 2004, 10:37 AM
jbeanelliott is offline
Find More Posts by jbeanelliott
United States, WA, Orondo
Joined Feb 2003
What is the sampling rate of "Watt’s Up” watt meter?
Does it use a sample-and-hold circuit?
Will it capture short time duration spikes in voltage?
If so, what is the shortest time of a spike it can capture?
Thanks.
jbeanelliott is offline Find More Posts by jbeanelliott
Old Nov 09, 2004, 02:51 PM
RCElec is offline
RCElec's Avatar
USA
Joined Nov 2004
This can be a complicated subject, but I think the simple answers are appropriate, so here they are.
Yes, there is a sample-and-hold (s/h).
A sample is collected by the s/h every millisecond so the sample rate is 1000 samples/sec.
Every 400 mS (0.4 S) the display on the "Watt's Up" is updated with the average of the last 400 samples and with the peak Amps and minimum Volts captured.
A spike that occurs during a single sample (1 mS) will be captured and used for the Peak Current and Minimum Voltage. Unless the spike lasts the entire sample time, it may not be reported accurately (as it is averaged over the 1mS sample). So the simple answer is that a spike must last at least 1 mS to be accurately captured, but see the next paragraph.
A caveat all s/h circuits have is that if the signal situation is changing very rapidly the s/h value may understate the change from the prior sample. For example, if the current goes from 0 to 100 Amps for 1 mS and back to 0 Amps over a 3 mS interval, the "Watt's Up" may show a peak value less than 100 Amps. However, that's an unlikely scenerio in RC model applications.
I hope I've answered your questions.
Thanks for asking.
-K
Site Sponsor
Old Nov 12, 2004, 01:30 PM
PerfectStranger is offline
Find More Posts by PerfectStranger
one game away...
PerfectStranger's Avatar
Willoughby, Ohio
Joined Apr 2004
Just got mine in the mail today. Very happy with it so far in limited use.
matt
PerfectStranger is offline Find More Posts by PerfectStranger
Old Dec 02, 2004, 06:25 PM
sharam is offline
Find More Posts by sharam
Northern CA
Joined Apr 2003
I see that the Wattsup device has 100amp maximum; just out of curiosity, what happens if you try to measure more than 100 amps?
sharam is offline Find More Posts by sharam
Old Dec 08, 2004, 03:20 PM
RCElec is offline
RCElec's Avatar
USA
Joined Nov 2004
Another good question. You planning on building an Arc Welder? Just Kidding <g>.
The "Watt's UP" has no set maximum values on its measurement abilities.
The maximum values it can measure depend on the measurement dynamic range left after calibrating the device's components to deliver at least the guaranteed specifications. Put another way, we must sacrifice some measurement range to compensate for manufacturing tolerances in the components that make up the "Watt's Up."
So some units may measure as much as 120A, but this is not guaranteed. This is why there is no "overrange indication". We want to allow for the most your individual unit can measure beyond the guaranteed amounts in the specifications.
Keep in mind that while able to make the measurement, you may be exceeding the safe operating limits of the device. At 120 Amps, device heating is the limitation.
I hope I've answered your question and thanks for asking.
-K
Site Sponsor
Old Dec 08, 2004, 08:18 PM
California Condor is online now
Find More Posts by California Condor
Old Timer
California Condor's Avatar
CARMICHAEL, CALIFORNIA USA
Joined Apr 2001
I just received mine and it seems like a very nice device. I do not, however, like the 3 second switching of the displays. I would much prefer a button or at least a longer interval.
California Condor is online now Find More Posts by California Condor
Old Dec 09, 2004, 07:46 PM
RCElec is offline
RCElec's Avatar
USA
Joined Nov 2004
Thanks, glad you like it.
We appreciate your feedback regarding the display alternation interval. Can you tell us more about how you use it and what you would like the timing for the display screens to be?
Thanks!
-K
Site Sponsor
Old Dec 09, 2004, 08:29 PM
Old Timer
Joined Apr 2001
I fly Old Timers (SAM SOS) and it is a help in optimising power systems for maximum duration. All very low power. I much would prefer a button/switch but an interval of about 10 seconds would help.
Old Dec 10, 2004, 10:48 AM
badbill is online now
Find More Posts by badbill
Habitual Freeloader
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
It almost seems that I should have one of these :-)
Bill Davenport
AMA 28141
badbill is online now Find More Posts by badbill
Old Dec 20, 2004, 02:00 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Review is up on the Ezone main page.
BEC is offline Find More Posts by BEC
Old Jan 03, 2005, 09:14 PM
RCElec is offline
RCElec's Avatar
USA
Joined Nov 2004
Do you mean you would like 10 seconds of Amps, Volts, Watts & Ah and then 3 seconds (or some other value) of peak Amps, voltage minimum, Watts and Wh?
Thanks much for your answer and sorry for the delay replying.
-K
Site Sponsor
Old Jan 13, 2005, 09:20 PM
MDKING is offline
Find More Posts by MDKING
MDKing
MDKING's Avatar
USA, TX, Sherman
Joined Jun 2004
I got mine for Christmas, and for the first time in the 10 months I have been flying electrics, I now know what my "actual" Voltage pull, Current(I), and Power(W) truely is. I have used my Watts meter on SS running Brushless system, Unicorn, running a CC45/Mega 16/15/3, 9cell 1400AA and 11.1 Lipos, I love this thing.
BUT!!!!!
Having a button, or switch of somesort to toggle back and forth would be nice. Also the sampling rate would be nice around 200ms with averaging. Being able to download through a USB cable to an computer to graph this would also be nice, not on this hand held unit but something like it. I know there are others out there that does this, but you have sold me on your products.
Regards, and thank you.
Mark D King
Sherman TX
mvking@cableone.net
MDKING is offline Find More Posts by MDKING
Article RC Electronics Watt's Up Meter - a Quick Look BEC Electric Plane Talk 17 Jul 15, 2012 10:45 PM
Discussion Watt's Up VS AstroFlight Whatt Meter? CrazyHerb Power Systems 9 Jan 27, 2007 10:19 PM
Any difference between a "Watt's Up" meter and the Heli "Watts up" meter? xray328 Electric Plane Talk 1 Oct 17, 2005 11:23 PM
Yippee! Watt's Up Meter! Wingtips24 Batteries and Chargers 35 Jun 29, 2005 06:35 PM
Can the Hyperion E-Meter be used on board like the Watt's Up? Lynxman Power Systems 8 May 17, 2005 05:41 PM
