Sam,
I've already experimented with foam floats for my tiger moth, it's just that this whole balsa former and CF stringer method struck me as neat, so I figured this project would give me some experience before I do a whole kit that way ![]() Phil, during the second world war, the Japanese wanted to have a fighter capable of operating off islands where no fixed airstrips had yet or could be build, hence water operation. At the time, Mitsubishi was too busy producing the more common land/carrier based zeros, so Nakajima was licensed to build float equipped A6M2 fighters, which the Allied Forces nicknamed "Rufe". There were only about 367 of them built, and due to their freedom from airstrips and carriers were usually the first in and the last out. The large central float only shaved 10 mph off their top speed compared to traditional zeroes, and with fuel stored in the float, their range was considerably longer. Their maneuverability remained quite decent, and with the same armament as normal zeroes, ie: two machineguns mounted in front of the cockpit, and two 20mm cannons in the wings, they packed a surprising punch for unwary foes. Of course, the A6M2-Ns were still relatively early comers and their maneuverability was in part due to the lack of armour and self-sealing fuel tanks. Needless to say, as Allied tactics improved (ie: hit and run), the Rufes became quickly outclassed. All in all however, a nimble and very beautiful bird, in my mind, even more so than their land/carrier based sisters (although technically they would be considered brothers as Japanese fighter types were given male nicknames by the Allies!)All clear Phil? ![]() Kitty |
wagging tails
Hey guys,
Have been putting some more thought in the project, namely on the subject of how much I'm actually going to be flying it off land (ie: with LG) once I get this conversion done.. I knew about the A6M2-Ns having increased rudder area due the effects of the floats on the aircraft's aerodynamics, but I figured if I was going to be converting back and forth between zero and rufe modes, I'd simply leave the rudder as is, but it might be interesting to modify the tail so that it wags, as shown in the screenshots I took from Ubisoft's Pacific Fighters. I'll just chop the tail end off and extend the rudder so that it extends all the way down. I'm also toying with the idea of adding a water rudder to help taxi.. The easiest way in terms of linkage to do this would be to have a servo mounted in the float connected to the rudder channel with a Y-connector, and then having the pushrod extend out through the rear of the float through a watertight seal of some sort... Anyhoo, it's food for thought! And I think I will double the number of formers as well. At the size I'm building it, I think I'll need to extra strength... K |
near Twin Cities
Joined Jan 2004
Rufe, Rufe.
Hey kitty,
I just finished one of these, hope you can go a couple steps farther. I have not put a water rudder on yet. Still thinking of the way to operate it effectively. I built my floats from foam, took me part of an afternoon to carve them and prime them. I built the struts from ply sandwhiched between balsa and then sanded for the rounded contours. Dont have electric equipment in it yet but plan on flying it off the snow in a while. Help you out if I can at all. Seems you have the will and the way, but wanted to offer. Kyle. |
Always appreciated Kyle! ^_^ That is one BEAUTIFUL Rufe you've got there!
Did you mod the rudder at all? And how did you attach the tip floats? I was thinking of using the stock landing gear attachment pieces to hold the wires for the tip floats myself! I'm going to "assemble" my 3D formers and keels in A-Cad, draw myself some key stringers using splines and work out how big and what shape my additional formers need to be My little Guillows kit uses 5 formers for the main float, I'm thinking an additional 4 should keep the skin nice and tough, also this is all total guesswork for me as I've never tried this method of construction before! For all I know, the CF stringers will do trick nicely without the additional reinforcement!Kitty |
| Thread Tools | |
| I have lost my way! Its not fun anymore | Dandi6065 | Parkflyers | 34 | May 06, 2009 06:03 PM |
| Discussion Clubs in Fla. (Wasi28 moving my way.) | mad mike | Electric Plane Talk | 3 | Oct 16, 2003 12:04 PM |
| Thinking of doing a Micro for my first plane... | djv | Indoor and Micro Models | 13 | Mar 11, 2002 10:47 PM |
