Old May 05, 2001, 08:29 PM
clchen is offline
Find More Posts by clchen
Lafayette IN, USA
Joined Apr 2001
For 9.6V 1600ma NIMH battary what is the charge rate and charge time?
is there a general rule that I can use for the NIMH battary?
I know for the Ni-cad I can alway use the auto mode on the charger
clchen is offline Find More Posts by clchen
Old May 05, 2001, 08:34 PM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
I charge mine at 2C max in field and at home 1/3rd c.
So far so good.
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old May 05, 2001, 10:29 PM
clchen is offline
Lafayette IN, USA
Joined Apr 2001
What is 2C, 3C? I am a new so I don't know all these terms....please explain
Old May 06, 2001, 02:15 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
clchen: Welcome to Ezone! You gots questions, we gots dumb looks for ya.
2C is twice capacity of the cell. 2C of a 1600=3.2 amps but with the AA Nimhs, common knowlege is no more than a 2 amp charge. They won't like much more than that and will overheat. I charge all my NiMh packs at ~1.25C and have had good luck with them at that rate. What kind of charger are you using?
mw
Mark Wood is offline Find More Posts by Mark Wood
Old May 06, 2001, 09:43 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
The recommended maximum charge rate from the manufacturers is 1C...1600mah = 1.6A.
See the following for all the poop...
http://data.energizer.com/
Goto application manuals...then Nickle metal hydride.
Good Luck
hoppy
hoppy is offline Find More Posts by hoppy
Old May 06, 2001, 11:55 AM
clchen is offline
Lafayette IN, USA
Joined Apr 2001
I have the FMA SuperNova.
For all the above charge rate you recommand how many hours did you charge your battary?
Old May 06, 2001, 05:01 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
If set at 1.6 amps with an empty pack, you should have a charged pack in about an hour or less. The charger should automatically shut off when the pack is fully charged.
mw
Old May 06, 2001, 09:06 PM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
I charge my Sanyo 1600 8 cell packs at 2C (about 3 amps) and have not had any problems. These things go and go on my Speed 400 planes.
sf_247 is offline Find More Posts by sf_247
Discussion What Amp Rate To charge Swic Batteries and Chargers 1 Dec 15, 2006 12:56 PM
Found Looking for a 9.6v NiMh/NiCd Transmitter battery SFS75 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 28, 2006 11:43 AM
480 7.2v brushed using a 9.6v 3000mAh nimh...what props? kaiser_solsay Beginner Training Area (Aircraft-Electric) 0 Aug 25, 2005 05:38 PM
For 9.6V 1600ma NIMH battary what is the best charge rate and charge time?(more) clchen Parkflyers 1 May 06, 2001 04:23 AM
RS 1600 NiMH 9.6v packs a joke or what? hardlock Electric Plane Talk 14 May 01, 2001 09:51 PM
