Old Feb 21, 2002, 10:04 AM
Clu is offline
Clu
Find More Posts by Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
Question
Mini-IFO, 1524 and Qualcomm 830's
Any one flying the 1524 and ARC-1 with the Qualcomm LiIons?
I'm wondering what kind of perfomance to expect with 2 and 3 cells? Vertical?
Seems like 3 cells would be around 2.8 ounces, is this too heavy for this plane? Thanks!
John
Clu is offline Find More Posts by Clu
Old Feb 21, 2002, 10:11 AM
jlk is offline
jlk
Find More Posts by jlk
jlk
Lifetime Beginner
jlk's Avatar
Chicago & Tucson
Joined Sep 2001
I fly a mini IFO with a 1717 and three of the small Tadiran (430ma) cells. They weigh 33 gms (just over one ounce). I think your plane will fly but the performance will be not up to par. Those cells would be fine on the regular IFO. I would try a small NiMh pack 6-10 cells.
Hope this helps.
Jordan
jlk is offline Find More Posts by jlk
Old Feb 21, 2002, 10:13 AM
jlk is offline
jlk
jlk
Lifetime Beginner
jlk's Avatar
Chicago & Tucson
Joined Sep 2001
Sorry, mistyped, 8-10 cells.
Jordan
Old Feb 21, 2002, 10:27 AM
Clu is offline
Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
Hi Jordan,
That was quick!
I'm currently using the NiMH 120's 8 and 10 cell packs. I haven't been getting good performance out of them, since my Super Nova keeps false peaking on them. I'm building the trickle charger here on Ezone so I can slow charge them.
I was just curious about the LiIons.
Old Feb 21, 2002, 02:53 PM
ckoerner is offline
Find More Posts by ckoerner
ckoerner's Avatar
Crest Hill,Il
Joined Oct 1999
IFO
John,
I have a DC1717, 9cell 120mah NIMH, and braun prop. I can hang on the prop at about half throttle for the first couple of minutes. After that it's about 3/4 to full throttle.
Jordan,
We are flying tonight 7-10 instead of tomorrow night. I'm hoping there won't be as many people tonight since it's on a Thursday. Maybe I will come up there tomorrow night if my IFO makes it through tonight,
Later,
Craig
Craig's Page
ckoerner is offline Find More Posts by ckoerner
Old Feb 21, 2002, 03:04 PM
Clu is offline
Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
Hi Craig,
How does the 1717 compare to the 1524 on the same number of cells?
Old Feb 21, 2002, 03:22 PM
ckoerner is offline
ckoerner's Avatar
Crest Hill,Il
Joined Oct 1999
DC1717
On Todds Models web page, he shows the DC1717 to have about 4-5 grams more thrust than the DC1524 on the same amount of cells. The DC1717 weighs 2.4 grams less then the DC1524. You should be ok with vertical performance with the DC1524. I barely ever go above 1/2 throttle when flying around.
Old Feb 21, 2002, 03:54 PM
Clu is offline
Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
Craig, how are you charging those 120's ?
I have a SuperNova, but I can never seem to get them to take more than 50-75 mAh.
I'm going to build the trickle charger here on Ezone
Also, how did you mount your 1717?
Is that a light on the front of your IFO?
Old Feb 21, 2002, 04:03 PM
ckoerner is offline
ckoerner's Avatar
Crest Hill,Il
Joined Oct 1999
charging
I use a Graupner MC Ultra Duo Plus II charger. For mounting the motor I took the motor mount from the Tiny. I then drilled a hole for the carbon rod to go through. And then you can cut some off of the mount. I then Ca'd the mount on the carbon rod. Then mount the motor with the two screws. It works great. I busted the mount before I busted where it glues on. At first I just Ca's the motor on, but it was allways coming off. Hope this helps.
Later,
Craig
P.S. I don't have my plane at work, but I could take a close up tomorrow of the motor mount if you want.
Old Feb 21, 2002, 11:20 PM
Allan Wright is offline
Find More Posts by Allan Wright
Gambler-AG DLG Designer
Allan Wright's Avatar
Lee, NH, USA
Joined Jun 2001
The 830 mAh 2 cell Qualcom pack flys my GWS-A powered Mini-IFO GREAT!
Allan Wright is offline Find More Posts by Allan Wright
Old Feb 22, 2002, 04:07 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
Originally posted by Clu
Hi Craig,
The 1717 is a hotter (higher kv) motor so it gives more rpm per volt. But it's a little less efficient than the 1524.
I use the 1524 with 28x12 prop on 9x50 nicds on my Mini IFO, and the same motor/prop on a Stubenfliege ... which needs less power so normally flies on 8x120 nicds.
For the motor mount on the Mini IFO, I cable-tied the motor to a small piece of 1/64 ply (maybe 1" x 0.5"), added triangular section balsa strip each side to give a flat base then cyano'd it to the plate on the airframe. It has never moved, and if I want to take the motor off one day I just cut the cable ties.
AUW of the Mini IFO with 9x50 is 112g.
Hope the description is OK, if not I can shoot a pic. tonight & post.
I'm still waiting for WES Technik to release their small Li Ion packs ... I checked a couple of days ago and not ready yet The delay is getting the protection circuits amended to be more suitable for r/c use (bearing mind we are using BEC!).
Bill Glover is online now Find More Posts by Bill Glover
Old Feb 22, 2002, 08:31 AM
Clu is offline
Clu
Clu
Glavin!
Clu's Avatar
Southern NJ
Joined Aug 2001
Craig: I get it. Is the the mount listed as the 1524 and 1717 motot mount on Toddmodels.com?
Bill: It sounds like I mounted mine the same way you did originally. Sort of a 'T' shaped mount. Problem is, I proke it a couple times, now it's next to impossible to keep it on, so I have to build a new mount. I like the way Craig did his.
Thanks for all the other info, you've been very helpful in my selection of components for the Mini. now, if I could just get these 120's to take a proper charge. I have a 10x50 NiCd pack comeing in the mail soon, so we'll see how that one works.
I broke down and ordered the set of 830's from Hacketts. My Dad has a Mini-IFO with the GWS-A setup and I knew they worked well, so I'm going to split them with him and I have another pland I can use them in.
Old Feb 22, 2002, 08:43 AM
ckoerner is offline
ckoerner's Avatar
Crest Hill,Il
Joined Oct 1999
Motor Mount
John,
You could download the plans for the Tiny and copy the motor mount. Yes it is the same one that Todd Shows.
Old Feb 22, 2002, 05:03 PM
Joined Nov 2000
Here's my mount, pic #1
Old Feb 22, 2002, 05:04 PM
Joined Nov 2000
And pic #2
HTH
Wanted Qualcomm 830's Jim McPherson Aircraft - Electric - Airplanes (FS/W) 8 Feb 05, 2002 08:53 PM
Qualcomm 830's in a Tiny? jamesperoulas Scratchbuilt Indoor and Micro Models 8 Jan 17, 2002 08:39 PM
Qualcomm 830's price just went up! Spaulding Parkflyers 7 Jan 16, 2002 04:01 PM
A couple of Mini IFO / 1524 questions... Clu Scratchbuilt Indoor and Micro Models 8 Jan 14, 2002 08:13 AM
mini ifo 1524 motor pinion gear Terry W Electric Plane Talk 1 Dec 23, 2001 11:18 PM
