Old Nov 04, 2004, 09:39 AM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
Which airfoil is most commonly used on 3D planes?
Any idea which airfoil is used on 3D, even more specific, on 3D/Pattern planes?
Tumbler is offline Find More Posts by Tumbler
Old Nov 04, 2004, 12:04 PM
gouda is offline
Find More Posts by gouda
Is it summer yet?
gouda's Avatar
Flight Level 46 X 92
Joined Feb 2002
If you're talking about the typical e-powered flat fuse/wing designs that are everywhere nowdays, the wing section on about 90+% is just a flat plate. About .25" thick by the chord width. I.E., there is no airfoil. The plane flies (anyone can chime in here to correct me if I'm wrong) in flat and level flight by the positive incidence of the wing as related to the thrust line. And of course by brute power through most 3D aerobatics.
If you are talking about slimers, that's another whole story. You may have more luck in gas power section of RC Groups.
gouda is offline Find More Posts by gouda
Old Nov 04, 2004, 12:06 PM
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
no, i need an actual airfoil, not flat foam. thanks
Old Nov 04, 2004, 12:53 PM
A Monell is offline
Find More Posts by A Monell
Gloucester Ma
Joined Dec 2002
search for sx2 (3d foil) sx3 (more pattern like) narrow your sarch to posts by the designer Y Sekai (SP)
A Monell is offline Find More Posts by A Monell
Old Nov 04, 2004, 12:59 PM
flybike is offline
Find More Posts by flybike
Lance Armstrong- 7 times!
flybike's Avatar
Madison, Wisconsin
Joined Sep 2001
If you search for a build thread for a balsa plane, such as the StevensAero Groove 480 or Mountain Models Tantrum, you can often see nice pictures of the wing ribs. Just about anything with a nice round leading edge(not sharp) and about 15 % thick will work.
-Hans
flybike is offline Find More Posts by flybike
Old Nov 04, 2004, 01:54 PM
Salto is offline
Find More Posts by Salto
Australia, NSW, Sydney
Joined Feb 2003
I've used a modified Eppler 479 on the Toccata. This airfoil is great for 3D. It developes a reasonable lift co-efficient, yet stalls abruptly when you want to slow the model down in a hurry. http://www.rcgroups.com/forums/showt...hlight=toccata
Graham.
Salto is offline Find More Posts by Salto
Old Nov 04, 2004, 04:07 PM
rcmodelbuilder is offline
Find More Posts by rcmodelbuilder
Joined Mar 2004
airfoil
I have use NACA 20%
rcmodelbuilder is offline Find More Posts by rcmodelbuilder
Old Nov 04, 2004, 04:52 PM
Mad Scientist is offline
Find More Posts by Mad Scientist
USA, MA, Framingham
Joined Feb 2003
We could write a book on just this question and still not cover everything. Airfoils are specific to Reynolds numbers (area x speed) in addition to flying style.
What exactly are you trying to do or figure out? Do you have a specific size plane/motor combo in mind?
Mad Scientist is offline Find More Posts by Mad Scientist
Old Nov 04, 2004, 05:03 PM
fatboywings is offline
Find More Posts by fatboywings
fatboywings's Avatar
Newcastle Australia
Joined Nov 2002
I use a range of Naca 0010 through to 0020
have fun
fatboywings is offline Find More Posts by fatboywings
Discussion Most Commonly Used Camera for Raptor .50 Size Helicopter IamLegend Aerial Photography 4 Sep 21, 2006 11:05 AM
Which Loctite can be used on Plastic? localbuyer Power Systems 1 May 23, 2005 12:15 AM
Opinion needed on 3D airfoil rcmann 3D Flying 5 Oct 29, 2004 02:06 AM
Can the SIG Koverall material be used on foam planes? Leafy GWS (Grand Wing Servo) 1 Oct 06, 2004 08:25 AM
what is the most commonly used foam, and where to buy? rockerfly Foamies (Kits) 4 Aug 15, 2004 03:18 AM
