Old Nov 04, 2004, 02:24 AM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
DIY IR Rx PCB's
After posting in another thread just recently, I had a number of phone calls. One was from a kind gentleman who offered to make some DIY IR pcb's. This is what we have so far. Picture is of 12mm x 12mm IR Rx pcb, gold plated. These boards are not home made.
Dave
david_dewit is offline Find More Posts by david_dewit
Old Nov 04, 2004, 02:28 AM
Australia
Joined Sep 2001
126 Rx pcb's to a sheet
Old Nov 04, 2004, 02:38 AM
andramalech is offline
Find More Posts by andramalech
St. Petersburg, Florida
Joined Apr 2003
pcb
are these are for the lt charge pump . how are you going to price them?
andramalech is offline Find More Posts by andramalech
Old Nov 04, 2004, 02:46 AM
Australia
Joined Sep 2001
Boards are for the LTC charge pump. Texas Instruments have a pin for pin substitute available as free sample, it is suitable though it has a lower current rating. Price will be cheap, this is non profit, should be able to let you know exaclty how much tomorrow.
Dave
Old Nov 04, 2004, 03:15 AM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Nice boards.
Stewart mentioned something about the TI charge pumps new data sheets specify a higher current rating than what Digikey specifys. Wonder if Digikey's
stock is up to specs with the new specs. All you need is 50ma for the coils and 10ma or so to be safe for the fet, pic and sensor. I forget the exact current consumption but remembered that 60ma would cover it. I think that is what the new data sheet specifys. I'm bad for posting without looking stuff up so I will go look it up now.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Nov 04, 2004, 03:47 AM
Joined Nov 2002
PIC12c5xx < 2ma at 5VDC 4MHZ
12c5xx uses more curent than 12f6xx
Panasonic sensors are 3ma max 2.4ma typical
I dont see the current consumption for the IRLM2502 but suspect its in uA
Digikey's lists the 60ma versions REG71055DDCT but has no in stock information.
They do have the 30ma REG710s in stock those would be fine I think for throttle rudder planes. TI does have samples available for the 60ma REG710s.
I ordered some will test them out when they get here.
Dont you hate that burnt flux taste you get in the back of your throat.
Billy
Old Nov 04, 2004, 04:05 AM
Joined Nov 2002
Nice boards
Old Nov 04, 2004, 04:10 AM
Australia
Joined Sep 2001
Thanks Billy,
I have some TI samples here. Packet says REG710NA-5/250. 5v 30mA
I have tested this component with the 3ch IR without problems.
PS Tx and Tx module pcb's coming soon.
Other components for IR also available.
Dave
Old Nov 04, 2004, 04:24 AM
clipclop is offline
Find More Posts by clipclop
QLD, Australia
Joined Sep 2003
Billy,
The TI chargepump is , REG71050NA --- sot23-6 package .
the REG71055DDCT is a 5.5 volt version!
Nominal continuous current is 30mA , short cct current listed as 100mA but a later fact sheet than the data sheet says they lifted the short cct cut out to 125mA.
Stewart
Edited-added part No & voltage chart. Note its only the 5Volt versions we are interested in .
clipclop is offline Find More Posts by clipclop
Old Nov 04, 2004, 05:09 AM
Joined Nov 2002
Stewart
Didnt realize there was a 5.5 V version.
Thought the ones listed for 60ma at Digikey were the 50s can be confusing with all the part numbers.
Dave
Glad to know the REG710NA-5/250 work. Now we are not stuck ordering samples.
Billy
Old Nov 04, 2004, 07:27 AM
Dave Wulff is offline
Find More Posts by Dave Wulff
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
Billy,
Which Panasonic sensor are you refering to? Digikey lists one the works on 3V.
Dave
Dave Wulff is offline Find More Posts by Dave Wulff
Old Nov 04, 2004, 05:12 PM
Joined Nov 2002
Dave W.
PNA4611M Series.
Billy
Yippee! How to make low-current vias for DIY 2-sided PCB's! KreAture DIY Electronics 22 Jan 08, 2007 07:10 PM
Discussion CPTfrazz's DIY IR/RF radio wiki! Post your progress and ideas! Cheesehead Scratchbuilt Indoor and Micro Models 4 Aug 09, 2006 11:55 AM
IR RX PCB joint venture epilot Scratchbuilt Indoor and Micro Models 97 Jan 16, 2005 11:20 PM
questions on diy ir rx jonathan8388 Scratchbuilt Indoor and Micro Models 29 Jan 11, 2005 10:44 AM
Hitec/RCD feather RX f/s ERGO60SX Aircraft - Electric - Airplanes (FS/W) 0 Jan 06, 2002 11:57 AM
