Old Nov 03, 2004, 02:48 PM
D-Rock is online now
Find More Posts by D-Rock
D-Rock's Avatar
Phoenix, AZ
Fw-190D9?
Can anyone tell me if there are any plans for a Fw-190D9 (Long nose but regular wing). I'm looking in the 30-35" rage for a GWS drive. I know there are a lot of Ta-152s and short nose 190s, but I've been unable to find a D9 set. It could even be a Free flight set that I could modify. THe guillows looks a bit small for what I want, and its the short nose.
D-Rock is online now Find More Posts by D-Rock
Old Nov 03, 2004, 04:29 PM
JohnBlankenship is offline
Find More Posts by JohnBlankenship
Crossville Memorial, Tennesse, United States
Joined Jul 2003
FW-190D plan
D-Rock
There was a 1/12 scale (34.5 inch span) gas powered RC FW-190D published in Model Aviation a few years ago. The article can be downloaded from the AMA web site, and the plan is also available from AMA plans service.
There was also a smaller 1/24 scale rubber powered FW-190D published in Flying Models a good many years ago. The model was by Pres Bruning, and the plan is still available from Flying Models.
Let me know if you want more info on these.
John
JohnBlankenship is offline Find More Posts by JohnBlankenship
Old Nov 03, 2004, 05:11 PM
stacker is offline
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
D-Rock, there was a version of the TA152 with a short wing like the D-9, it was the TA152C. I've been thinking of taking the Diel planes and taking then up to 1/16th and clipping the wing to look like the C version. I too like the D9 the best.
Cheers---Stacker
stacker is offline Find More Posts by stacker
Old Nov 03, 2004, 05:14 PM
scififlyer is offline
Find More Posts by scififlyer
Registered Useless
scififlyer's Avatar
United States, TN, Knoxville
Joined Feb 2003
Peruse the kits & plans page at www.rccombat.com for planes in that size range. Or, get a Ta-152 from www.jkaerotech.com and clip the wings to '190 size. If you build lightly and don't detail it out, you'll have it flying in a week.
scififlyer is offline Find More Posts by scififlyer
Old Nov 04, 2004, 07:50 AM
wespe is offline
Find More Posts by wespe
wespe's Avatar
Owensboro, Kentucky, United States
Joined Oct 2002
Stacker,
FYI, just in case you didn't know the Ta152C was a short nosed focke wulf. Radial engined, I don't know the particulars course I could be preachin to the choir and not know it. I'm thinkin it had 190 wings not sure though.
Tracy
wespe is offline Find More Posts by wespe
Old Nov 04, 2004, 08:33 AM
wespe is offline
wespe's Avatar
Joined Oct 2002
Ok I win the idjit award today not radial but DB603 engined vice jumo power. Oldtimers disease strikes again.
Plastic kit page;
http://www.kitparade.com/features00/ta152cbg_2.htm
Old Nov 04, 2004, 08:48 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
How about just using the FW-190 plans and adding the longer cowl yourself? From what I can tell the longer nose is circular, just a little smaller in dia than the short nose. Hard part would be the transition area to the smaller dia (pink foam is your friend ).
There are a lot of good photos out there on the Ta152 you can use for reference.
charlie
portablevcb is offline Find More Posts by portablevcb
Old Nov 04, 2004, 11:21 PM
Dave K is offline
Find More Posts by Dave K
Dave K's Avatar
Sebastopol, Ca
Joined Jun 2004
This site www.aalmps.com has a cool laser cut TA-152 that you could cut the wing down on. The link seams to be hit and miss, sometimes it works and some times it does not.
Dave
Dave K is offline Find More Posts by Dave K
Old Nov 05, 2004, 05:13 AM
murola is offline
Find More Posts by murola
Helsinki Vantaa, Finland
Joined Feb 2002
Fw 190
I recall english RCME had a 190d free plan (long nose, regular wing) sometime in 80-85. Flew ok with a 15.
Mauri
murola is offline Find More Posts by murola
Old Nov 05, 2004, 09:04 AM
D-Rock's Avatar
Phoenix, AZ
Thanks for the info guys. I do have the Lidberg Ta-152 plans, but it would be a large task to modify those plans to a D9. One interesting thing about the different versions, when they went to the D9, they added an extension to the rear of the plane, right before the verticals leading edge, of about 2 feet. (not exact on that mesurement). When they went to the 152, it was a new wing and they added another section to the tail making it longer and improving the over all moment. The D9 was a stop gap between the short nose and the 152! Murola, I'm not familure with RCME mag, could you tell me more. John B, about those free flight plans you mentioned, can you tell me more. A free flight structure is kinda what I've been looking for, simply because they tend to be lighter.
Thanks again to those who posted.
D-Rock a.k.a. Derek
Old Nov 05, 2004, 11:30 AM
Joined Jul 2003
Flying Models FW-190D plan
You can order the plan from the Flying Models Magazine web site:
http://www.flying-models.com/
The construction article was published in May 1973. Span of the model was 17.25 inches, so double size would give you what you want. I can send you a 3rd generation copy of the article if you want it.
Here is a scan of the plan from the magazine:
Old Nov 05, 2004, 06:54 PM
D-Rock's Avatar
Phoenix, AZ
Thanks John, that is exactly what I was looking for. I'll have to order a set.
D-Rock
Alert Alfa Fw-190D9 Is Out Airplane boy Electric Warbirds 16 Apr 16, 2007 11:53 AM
Discussion NEW Alfa FW-190D9 R&D Airplane boy Electric Warbirds 72 Feb 09, 2007 04:05 PM
My kingdom for a decent fw-190d9 tho98027 Electric Warbirds 33 Jun 28, 2006 09:08 AM
Wanted Wanted: Top Flight 1/7 Gold Edition Focke Wulf FW-190D9 fireguy01 Aircraft - General - Miscellaneous (FS/W) 0 May 15, 2006 09:06 PM
fw-190d9 plans Bako Fuel Warbirds 4 Sep 24, 2004 07:22 AM
