ITC Bladerunner FAQ Summary
The ITC Bladerunner thread is now reaching epic proportions in terms of the numbers of posts. This is a daunting task to peruse for someone looking for some quick answers. At the suggestion of Dave Wulff I've started this thread to summarize solutions and Frequently Asked Questions. This helps aleviate the need to start a new Bladerunner thread every time someone wants to ask a question.
As usual in these summary threads this thread is not the place to discuss things. We want to keep it short. I'll go through periodically and delete posts that are not summarizing a technique or answering a commonly asked question. So, if you have a technique or tip worth adding, please post away in this thread to help others. I've also started a "Bladerunner Part 2" thread and closed the original. discussion of techniques and experiences should now be posted in this thread. Gordon |
I'll start by repeating ssling (Dale In Singapore)'s post #559 from the big Bladerunner thread. He provides links to documents on his web site that summarize a lot of the Bladerunner thread.
================ SSLING's POST ================== Hello all, I live in an area (SE ASIA) where the bladerunner is not yet available, but I have been following the thread. It is getting difficult to keep up with all the posts. For what it is worth, I have tried to the best of my ability to create a document that contains all the modifications and suggestions that I could cull from these pages. I have revised it, and sent it to Petter for his revisions and additions. I will post it on my website (the link is provided below) and I will try to update it daily. If it is possible to post a sticky to keep this at the top of the thread, that would be nice, but I do not know much about forums and how they operate. I can't figure out how to contact the moderator, for example. However, for what it is worth, here is a place where you can get a reasonably complete and up-to-date list of modifications and changes. I am no rc expert, so some the modifications may not go into the same depth as the thread. Modifications and suggestions are always welcome. I am experimenting with MS Word and Adobe formats. The link is: http://theclassroom.50megs.com/Blade...nformation.doc OR http://theclassroom.50megs.com/Blade...nformation.pdf Hope this helps, especially new people to the thread. Like me! Happy Hunting, Dale in Singapore |
does charger charge @ 145mah or less¿?
a Question about the charger on Qvc models. I under stand the new batt. is 300Mah 4.2 V Lith-Poly takes 20+/- min charge and has VOLT cut off.
But @ what Mah does it charge.? Will it charge down to a 145mah 4.2 Volt Lith-poly pack. If sooo i can get some of these small batts and throw them in a ZipzaP. http://www.rcgroups.com/forums/showthread.php?t=294497 maybee there is a way to switch the current and cut it in half.? |
Maryland, USA
Joined May 2004
http://www.rcgroups.com/forums/showp...&postcount=499 I think a better option is to build your own. There are plans in the DIY forum, only a small number of parts and probably under $10. |
| Thread Tools | |
| ITC Bladerunner Part 3 | Gordon Johnson | Indoor and Micro Models | 913 | Sep 10, 2009 08:41 PM |
| Alert BladeRunner FAQ | Fotta | BladeRunner Heli | 45 | Aug 18, 2008 10:21 AM |
| ITC Bladerunner Part 2 | Gordon Johnson | Indoor and Micro Models | 1013 | Jan 05, 2005 01:29 PM |
| ITC Bladerunner for less than $35. | bobandris | Indoor and Micro Models | 5 | Jan 04, 2005 01:52 PM |
| itc bladerunner | codyp | Indoor and Micro Models | 935 | Nov 03, 2004 01:44 PM |
