Old Nov 03, 2004, 11:54 AM
meatbomber is offline
Find More Posts by meatbomber
Square-rigger
meatbomber's Avatar
Klatovy, Czech Republic
Joined Mar 2004
Slightly OT but i need help for a scratch built heli fuselage
Hello fellow modellers!
i say slightly OT because i need help not building an airplane but rather building a Fuselage for a Micro Helicopter Tandem.
The Fuselage in question would be a CH47 Chinook. The model is a Dragonfly Tandem Heli, AUW 640g so far. The Fuselage shouldn't weigh a lot more than 100g finished.
it's about 400mm long, 250mm wide and 150mm high...
Now to the problematic part...
I have no idea about scratch building such a Fuselage out of foam...
The Fuselage cross section is quite constant between the 2 pylons, so that might be made with the usual bulkhead and then using thin depron to cover the sides... but other i really have no idea how to go about it.
Any pointers ?
Cheers
MB
meatbomber is offline Find More Posts by meatbomber
Old Nov 04, 2004, 07:01 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
no one ?
Old Nov 04, 2004, 07:11 AM
spacemanspiff is offline
Find More Posts by spacemanspiff
Joined Aug 2004
MB,
I am not sure that depron would work. Do you know how much spare lift do you have on the heli over its own weigth? Is it enough to lift the depron fuse? The lightest fuse would be a thin plastic vacuformed one such as most RC helis fly with. You can make a foam plug for the fuse and use it a template for the vacuformed one.
Cheers,
J
spacemanspiff is offline Find More Posts by spacemanspiff
Old Nov 04, 2004, 09:58 AM
Square-rigger
meatbomber's Avatar
Joined Mar 2004
Well there is a guy who flies his at around 900g AUW... but it's performance margin is VERY slim then..
Every gramm weight that can be saved is important.. i feel that the heli should be flying fine to about 800g, that leaves about 160g for the fuselage.
Old Nov 04, 2004, 10:53 AM
Joat is offline
Find More Posts by Joat
Look at my little red dot
On the Snap on truck
Joined May 2004
why not use soda bottles,make what you want,use plaster make a mold and go from there?
Joat is offline Find More Posts by Joat
Discussion im building a custom exhaust for my .91 engine but need help*****PICS**** spitfire123 Fuel Plane Talk 29 Aug 20, 2006 04:54 AM
Question Need help with a scratch built foamie n003lb Power Systems 4 Aug 10, 2005 11:54 PM
Need help for scratch building parts (canopy) stumpy0_0 Scale Kit/Scratch Built 0 May 05, 2005 11:35 PM
I am Ready for an Outrunner but I Need Help Boss248 Power Systems 19 May 03, 2004 10:12 AM
Idea for a scratch built Grumman Hawkeye, but no time. ChrisP Scale Kit/Scratch Built 1 Jan 21, 2004 09:18 AM
