Old Nov 02, 2004, 12:11 PM
Mannes is offline
Find More Posts by Mannes
Upstream Racing
Montreal, Canada
Wing surface area to weight ratio?
Hey folks, is there a wing surface area to weight ratio to go by for a novice scratch builder?
Thanks -Mannes
Mannes is offline Find More Posts by Mannes
Old Nov 02, 2004, 01:02 PM
Ledbetter is offline
Find More Posts by Ledbetter
Central California
Joined Aug 2003
It's called "wing loading" and is expressed in pounds (or ounces) per square inch of wing area.
Ledbetter is offline Find More Posts by Ledbetter
Old Nov 02, 2004, 01:41 PM
Mannes is offline
Upstream Racing
Montreal, Canada
Great!!
-thanks Ledbetter... now to the calculator
Old Nov 02, 2004, 07:52 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Well, for a sailplane, try to get under 10oz/sq'. HL gliders are often in the 4oz/sq' range, but electric powered sailplanes do well to get under 10..
..a
Old Nov 03, 2004, 01:42 AM
Fredrik W is offline
Find More Posts by Fredrik W
Fredrik W's Avatar
Stockholm, Sweden
Joined Jul 2002
If you see a kit from european manufacturers you will most likely see the wingloading expressed in g/dm2 (grams per square decimeter), to transform g/dm2 => oz/sq.ft, just multiply g/dm2 with 3,04.
// Fredrik Wergeland
Sweden
www.flyingmodels.org
The Great Electric Motor Test
Fredrik W is offline Find More Posts by Fredrik W
Old Nov 06, 2004, 03:28 AM
Peytr is offline
Find More Posts by Peytr
Peytr's Avatar
The Netherlands
Joined Sep 2004
Hi Fredrik,
I think you made a mistake. It's g/dm2 / 3.04 > Oz/sq.ft. Correct me if I'm wrong .
My scratch built E soarer is in the range of 22g/dm2 (7.2 Oz/sq.ft) and is all composite. By using Lipo's it will be lowered to 19g/dm2 (6.25 oz/sq.ft). These numbers are a kind of ambitious but possible. Work with a weight budget for the whole frame and all separate parts. With the weight budget at one end of the workbench and a precision scales on the other you can get down to 6 oz/sq.ft if you reject enough heavy stuff .
Select wood, select your RC gear, select covering. For short: Select everything on it's weight and do a balancing act before fitting the battery etc. You'll save ballasting weight this way as well.
Peytr is offline Find More Posts by Peytr
Old Nov 06, 2004, 01:59 PM
Fredrik W's Avatar
Stockholm, Sweden
Joined Jul 2002
I stand corrected! Thanks.
Sweden
Help! Request for twisty wing plane span and aspect ratio (or wing area) data Sled Driver Slope 17 Oct 28, 2006 11:44 AM
power to weight ratio/ wing loading to ROW barn buster 50 Parkflyers 1 Jun 21, 2003 03:12 AM
wing loading/ power to weight ratio to ROW barn buster 50 Electric Plane Talk 0 Jun 20, 2003 10:52 PM
Wing area, weight, for EDF50?? Michael in Toronto Electric Ducted Fan Jet Talk 2 Mar 12, 2002 04:47 PM
400 speed Wing surface area/loading ? Feodosia Flyer Electric Plane Talk 3 Jun 06, 2001 12:10 AM
