Old Nov 01, 2004, 09:55 PM
On one again is offline
Find More Posts by On one again
antioch ca.
Joined Jul 2004
ok can any one tell me about a bauchmann?
any one know anything about this bike. Is it a 1/8 scale? any good or bad info about this bike would be nice thanks
On one again is offline Find More Posts by On one again
Old Nov 01, 2004, 10:26 PM
mollycbr123 is offline
Find More Posts by mollycbr123
STeve B in NC
mollycbr123's Avatar
North Carolina, USA
Joined Sep 2003
It's 1/5th scale. If you have seen a Royal, then you've seen a Bachmann. Produced thru the 1980's --early '90's I think. Molded plastic bodywork/frame, low end electrics. Steers by swinging the battery pack back and forth. Entertaining, but not a hobby grade bike. I have one Royal, and one Bachmann on my display shelf. The Royal was bought new by me many years ago, the Bachmann was NIB off of e-bay.
STeve B in NC
mollycbr123 is offline Find More Posts by mollycbr123
Old Nov 01, 2004, 10:36 PM
antioch ca.
Joined Jul 2004
thanks steve so just a show peice then
Old Nov 01, 2004, 10:40 PM
STeve B in NC
North Carolina, USA
Joined Sep 2003
Compared to the current 1/5 bikes they are. They are still fun, but I haven't run either of mine in maybe 2 years. Don't know where I'd get parts if I broke one!
Old Nov 02, 2004, 02:06 PM
grymg is offline
Find More Posts by grymg
RCMCC.tripod.com
grymg's Avatar
Fremont, CA
Joined Sep 2003
Mike, sorry I couldn't respond quick to your PM. Had a 20K service on my car this morning.
Anyways, a bit of R/C bike history: this was my first R/C bike back in 2000 after seeing in a LHS – I was very curious!! Back then it was called the Bachmann Cyclone RTR, nicknamed the "gentle giant" by many. There are many similarities between that and the Royal and Graupner; for these discussions they are virtually the same. It has been around since the old Kyosho days, in fact many races back then consisted of both the Bachmann and the Kyosho 1/8th because that’s all we had.
The electronics are a built-in circuit board Rx and ESC (I don’t remember if it even had crystals!) in the tail, a 400ish size closed endbell motor, and a standard servo but with a larger non-standard casing. Transmitter is a 2-stick. The steering is standard Kyosho swivel method, but the battery tray and battery also swiveled along with it to shift the weight over quicker. However by our standards steering is a bit sluggish. The rider, body, chassis, forks, and almost everything is made of pretty hard plastic, painted on the outside. The crash bars are removable and have a roller at the end of each. Comes in a nice carrying case.
After learning how to “ride” I soon got bored with the speed and wrenched on the chassis to learn that it doesn’t like being opened up! Really the way it goes together is not easy I remember. The mount for the motor on the Bachmann ONLY fits 400 motors, so much work had to be done to get in a 27T (Royal and Graupner however accept 540 cans). Gears are standard plastic so they break easily, and rear wheel is belt driven. I also tried putting regular electronics in it, which was easy except for the servo because I had to make new mounts. Anyways still couldn’t mod it enough to put the 540can in anyway, so I gave it away. But conlusion after looking back on it is that it was the easiest bike I’ve ever driven.
Heres a pic of one (or a Royal or Graupner). If you take a look at the front forks they’re non-USDs but they do have a lower fork brace above the mudguard which is nice.
Ian
grymg is offline Find More Posts by grymg
Old Nov 02, 2004, 02:23 PM
ZIGZAG is offline
Find More Posts by ZIGZAG
FL
Joined Jul 2004
Hi
An ok toy
ZIGZAG
ZIGZAG is offline Find More Posts by ZIGZAG
Old May 14, 2008, 10:48 AM
beltlogger is offline
Find More Posts by beltlogger
Joined May 2008
I had one of these a few years ago and someone stole it,I finally found a site that sells them and i just ordered a new one.
beltlogger is offline Find More Posts by beltlogger
Can any one tell me how to make a homemade gas powered jet turbine jet engine? Zupo Fuel Jet Talk 44 May 11, 2008 04:10 PM
Discussion GWS,can some one tell me what gear box fits LPS Ball Bearing (GW/LPS-2A) steve ypsi mi GWS (Grand Wing Servo) 7 Sep 11, 2006 01:08 AM
Help! can any one give me XP-4 pod pics? eitanro Hand Launch 4 May 30, 2006 02:51 PM
Question can some one tell me what kind of truck this is and buggy? crx_ef8 Off-road Cars 1 Nov 29, 2003 01:53 AM
can some one tell me? Jeff7 Foamies (Kits) 5 Jul 14, 2002 01:02 AM
