Old Nov 01, 2004, 10:20 AM
Danny Troy is offline
Find More Posts by Danny Troy
Danny Troy's Avatar
Westchester County, NY, USA
Joined Jun 2000
How to convert from 4-in-1 to separates?
I decided in the long run I'll be better off going separates than fixing or replacing my Esky 4-in-1 unit. I have the Esky 3D heli and I'm wondering if it's more complicated since it has 3 servos instead of the usual 2 on the FP model. I already have a spare 4-channel GWS receiver, and a Pixie-7 ESC.
What else do I need for this conversion and how do I hook it all up.
I'm assumming I need another ESC since it has a tail motor, and a Gyro.
Danny
Danny Troy is offline Find More Posts by Danny Troy
Old Nov 01, 2004, 11:32 AM
thewz is offline
Find More Posts by thewz
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
You will need a 6 channel Rx (or a 5 if you don't use a gyro with remote gain). 2 ESCís (1 for the main 1 for the tail). An HH gyro or a new Tx with mixing capabilities or a separate mixer.
thewz is offline Find More Posts by thewz
Old Nov 01, 2004, 11:46 AM
LittleBird is offline
Find More Posts by LittleBird
Madison Truax Fld, Wisconsin, United States
Joined May 2004
http://www.helihobby.com/html/separate_electronics.html
LittleBird is offline Find More Posts by LittleBird
Old Nov 01, 2004, 02:07 PM
Danny Troy's Avatar
Joined Jun 2000
Thanks guys. That schematic at helihobby really is what I was looking for. I'll print it out for reference.
Danny
Old Nov 01, 2004, 02:30 PM
Danny Troy's Avatar
Joined Jun 2000
Ok, contacted Helihobby and they have everything I need.
One more question. Since I have the Esky with CP and the Esky included transmitter is 6-channel, shouldn't I be able to use this transmitter?
Old Nov 01, 2004, 03:20 PM
Skycat is offline
Find More Posts by Skycat
Los Angeles, CA
The schematic at helihobby is for FP heli only. Since your E-Sky 3D is CP which uses CCPM radio. It's totally different than the one on helihobby. I hope you haven't ordered anything from them yet?
Skycat is offline Find More Posts by Skycat
Old Nov 01, 2004, 03:35 PM
Joined May 2004
Skycat...why would the schematic be any different. Just add one more servo and a 5-6 ch recever and the rest is the same....Or am i missing something? I have a cphb and that is how mine is done. I use a 6ch recever for my 401....JP
Old Nov 01, 2004, 04:02 PM
Danny Troy's Avatar
Joined Jun 2000
Please elaborate Skycat. I was about to order a 6-channel rx, the GWS gyro, and two ESC's. I thought that would work. I already have 3 servos on the E-sky.
Old Nov 02, 2004, 08:30 AM
thewz is offline
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
The Tx is already a CCPM mixer so you can use it. If it doesn't have REVO mix you will need an HH gyro or a new Tx with REVO mix and a cheap "rate" gyro.
Old Nov 02, 2004, 08:32 AM
thewz is offline
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
The schematic is basically the same for a CP ship...just 1 more servo.
Be sure that your Tx can do REVO mix BEFORE you order a cheap GWS gyro.
Old Nov 02, 2004, 10:39 AM
Danny Troy's Avatar
Joined Jun 2000
I wound up ordering a GWS 6-ch rx, a GWS gyro, GWS ICS-300 esc, GWS-50 esc, and a crystal to match the E-sky transmitter, and another crystal to match my 8-channel Futaba digital tx. If the E-sky doesn't work out I'll use my Futaba. I'm pretty sure the Futaba can handle the heli.
Danny
Old Nov 02, 2004, 12:39 PM
thewz is offline
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Danny
You will need a heli Tx if you are using the rate gyro from GWS otherwise you will have a spinning top rather than a heli.
Is the Futaba Tx an actual Heli Tx? If it isn't then it will not have the programming capabilities needed for CCPM or REVO Mix.
Old Nov 02, 2004, 01:57 PM
OzzieFlyer is offline
Find More Posts by OzzieFlyer
Melbourne Australia
Joined May 2003
Thewz...are you sure this will work ?
I "thought" the stock ESKY 3D tx was just a dumb tx and the ccpm was handled by the 4-in-1. I could be very wrong about this, but that's just what I had assumed. So if this is the case, then to go seperates you would need a proper heli capable radio for the CCPM.
The reason I ask this is that I just bought the ESKY 3D and set it up last night with seperates. It takes a lot of mucking around with servo trims, CCPM, mix percentages...etc (even with a HH Gyro) and I didn't think the stock TX could do this. Once again..just my assumption, not based on any real experience with the stock tx.
Anyway.....just curious if you knew for sure.
And Danny, it might be worth asking J-Ken or posting a question in one of the ESKY threads if this is possible. I haven't heard of it being done yet, which doesn't mean it can't be done of course...just want you to be sure before spending big $$.
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Nov 02, 2004, 02:11 PM
Danny Troy's Avatar
Joined Jun 2000
I have the Futaba 8UAF. On page 72 of the manual they describe the "revo mix" operation. There's three settings: Normal, Idle-up1 and Idle-up2.
Here's a couple of links to Futaba's site describing this tx:
http://www.futaba-rc.com/discontinued/futj80.html
http://www.futaba-rc.com/manuals/notes-8u.html
The E-sky looks to me like a standard 4-channel tx, although it says 6 channel on the face, so there must be internal mixing or where would the other two channels be on the tx. That's my guess anyway.
Old Nov 02, 2004, 02:33 PM
Skycat is offline
Los Angeles, CA
I thought the ccpm mixing was done by the 4-in-1 box? Can anyone confirm that it's done by the Tx?
Discussion CX2 Positive Power Lead Loose From 4-in-1 klondikes Coaxial Helicopters 3 May 11, 2007 07:24 AM
Discussion Can I just unplug the stuff from the 4-in-1 on the honey bee 2 fp? slo123 Micro Helis 9 Mar 16, 2007 10:32 AM
Question How Do I Hack 4 In 1 Ch.3 Blade Cp jacksflying Micro Helis 12 Mar 07, 2007 09:08 AM
Discussion 4 in 1 and separates weight question..... jettvolks Micro Helis 4 Sep 15, 2006 05:47 PM
Discussion BCX - How do I externalize the 4-in-1 LED RowdyRoger Coaxial Helicopters 2 Jan 12, 2006 03:43 PM
