Old Oct 31, 2004, 10:01 PM
peterjaw is offline
Find More Posts by peterjaw
Taiwan
Joined Oct 2003
Why my P-51D slow on rolling rate?
Hi pilots,
My GWS P-51D had a minor accident on last weekend.
Only some scratch on the wings and a broken prop.
After changing a new prop. I found that the rolling rate
drop tremendously, from about 1 roll per second to 1 roll per
3 seconds, and drop a lot altitude.
The throw of the aileron remain the same but just don't
know what could be wrong.
Can anyone explain this or tell me what to do with this?
Thanks a lot.
peterjaw is offline Find More Posts by peterjaw
Old Oct 31, 2004, 10:19 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
I am assuming that when you replaced the Propeller that you replaced it with the same identical size/pitch as that from the one that broke?
Ailerons work with the function of air speed (Prop Pitch) so, you can have lots of deflection at the ailerons but, if you don't have air speed they will be ineffective.
Therefore, I suspect that the new prop pitch maybe different (Less Pitch) than the one you replaced.
Carlos
guapoman2000 is offline Find More Posts by guapoman2000
Old Oct 31, 2004, 10:29 PM
Snake Charmer is offline
Find More Posts by Snake Charmer
Never enough planes
Snake Charmer's Avatar
Kitsap Co WA
Joined Apr 2004
Does it roll slow both directions as compared to prior to prop change?
Is it the new prop the same diameter and pitch as the prior prop?
Check and make sure the stick mount didn't change and affect the thrust angle...
check and make sure your CG is the same....
check the motor shaft... if it is bent you won't get the speed therefore reduce the roll rate.
At least that is what I would check first.....for what it's worth.
Snake Charmer is offline Find More Posts by Snake Charmer
Old Oct 31, 2004, 11:04 PM
TheAddler is offline
Find More Posts by TheAddler
Moderated. Severely.
TheAddler's Avatar
Sonoma County, California
Joined Apr 2002
Another odd thought.... GENTLY try to hold the aileron as you give it some left/right from the control box. See if you have a stripped/damaged servo. I had one that had a very slight crash, but the super light-weight gws servo had a stripped arm on it. It looked like it was working, but I think the pressure of the wind when flying was enough to effect it. Vs on the ground where it "looked" fine.
TheAddler is offline Find More Posts by TheAddler
Old Oct 31, 2004, 11:25 PM
peterjaw is offline
Taiwan
Joined Oct 2003
Thanks guys.
I replaced exactly the same prop.
I guess may by the air speed is the problem. Because the head part
of the plane is a little bit bended to right hand side, and this may
cause the thrust angle to right.
Where can i buy a new cockpit/canopy for my P-51D? TheLost GWS (Grand Wing Servo) 1 Dec 23, 2004 02:47 PM
why is my lithium charger slow? jeff262 Batteries and Chargers 5 Nov 22, 2003 08:05 PM
Why did GWS use silver for background of stars and bars on P-51D? thunder1 Parkflyers 2 Jan 07, 2003 07:37 PM
R/C Plane KYOSHO P-51D "MUSTANG" ARF $169 As seen on my EBAY Auction countmonk Aircraft - Electric - Airplanes (FS/W) 0 Dec 29, 2002 04:50 PM
My P-51D Mustang from MEC is Compleated Lv2Fly Foamies (Kits) 11 Dec 27, 2001 06:00 PM
