Old Oct 31, 2004, 08:27 PM
vol-haut is offline
Find More Posts by vol-haut
Michael K.
vol-haut's Avatar
Canada, ON, Burlington
Speed 400 Limited Motor Run Glider?
My local glider club hosts a F5J style limited motor run glider competition for 400 speed gliders. Only bushed ferite, no brushless, colbolt or modified motors allowed. Nicads or nickle hydrides up to 8 cells. I would like to join in the fun next spring but I don't know what kind of plane to build. I don't want a "trainer", I want something to really compete. Anyone have a suggestion? Any size and any number of controls are allowed. Gearbox or direct drive allowed. Motor run is 60 seconds. Flight task is 10 minutes with landing points. What are the "trick" setups to use?
vol-haut is offline Find More Posts by vol-haut
Old Nov 01, 2004, 04:09 AM
Stan Rose is offline
Find More Posts by Stan Rose
Stan Rose's Avatar
United Kingdom, England, Nottinghamshire
Joined Dec 2003
We have a similar set of rules in the U.K. Most people use either a 1.5m or 1.8m "Simply the Best" or a 1.5m or a 1.8m "Highlight" (known as an "Omega" in other parts of the world.) Power trains for both models are usually Speed 400 4.8v and Comotec 4.5:1 gearbox turning a 12" x 8" or thereabouts on 7 x KAN 1050's or these days 7 x GP1100's. If you go for this set up you will need a ESC that can deal with about 18-20 amps. 8 cells would improve performance slightly. It always amazes me what good performance and fun can be had from these relatively small and low powered models.
Stan Rose is offline Find More Posts by Stan Rose
Old Nov 01, 2004, 05:33 AM
mihah is offline
Find More Posts by mihah
mihah's Avatar
Slovenia, Kamnik, Komenda
Joined Dec 2002
Slovenian F5J 400 scene:
http://mdm.zrcalo.si/forum/viewtopic.php?t=2738
mihah is offline Find More Posts by mihah
Old Nov 01, 2004, 07:10 AM
ken troxell is offline
Find More Posts by ken troxell
rockville maryland
Joined Aug 2000
polecat aero wind dancer wins hands down....poly version.
ken troxell is offline Find More Posts by ken troxell
Old Nov 01, 2004, 07:18 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I use my Joker (reviewed on LiftZone) for the Extreme F5J and although I'm not all that experienced, it was competitive. I had to add spoilers to the design, however.
..a
Old Nov 01, 2004, 07:29 AM
rcjunkie is offline
Find More Posts by rcjunkie
SEFF Contest Director
rcjunkie's Avatar
USA, GA, Stone Mountain
Joined Oct 2000
My koleos-e from Icare has served me very well. 3 years in a row I've come in either 2nd or 3rd at the NATS in 1/2A sailplane. I also have won twice with it in the F5J Extreme contests here on Ezone. The Sky Sergio is also very good.
Ernie S.
rcjunkie is offline Find More Posts by rcjunkie
Old Nov 01, 2004, 07:47 AM
flyingdogtwo is offline
Find More Posts by flyingdogtwo
.Denver, Co.
Joined Feb 2003
Iim banking on the poly Pulsar to be a contender.
http://www.nfmodels.com/html/poly_pulsar.html
flyingdogtwo is offline Find More Posts by flyingdogtwo
Old Nov 01, 2004, 08:15 AM
tender is offline
Find More Posts by tender
tender
tender's Avatar
Europe - Slovakia
Originally Posted by vol-haut
My local glider club hosts a F5J style limited motor run glider competition for 400 speed gliders.........I want something to really compete. Anyone have a suggestion?
I recommend you my SENSOR model.
For details about this model you can look my web-site http://www.rivamodels.sk >>> SENSOR
tender is offline Find More Posts by tender
Old Nov 01, 2004, 07:24 PM
pocket rocket is offline
Find More Posts by pocket rocket
pocket rocket's Avatar
patagonia,az
Joined Oct 2002
there seem to be 2 options
1 - Wind Dancer type about 70" span, geared, big 11-12" diameter prop.
2 - hand launch type about 60" span geared or direct drive
type 1 goes for thrust and slower speed to get a good climb
type 2 goes for higher speed with a shallow angle to get a good climb
type 1 is easier to see at altitude
type 2 disappears quicker from view
type 1 won the recent Abq ESWC, but type 2 was leading after day one
both types must be built really light for best results, really really light
older javelin launch HLGs would be candidates for type 2
use a 5v Rocket Speed 400 motor
I started flying Unlimited because Speed 400 was too difficult !!!!!!! and used too many motors
Philip
pocket rocket is offline Find More Posts by pocket rocket
Old Nov 01, 2004, 08:35 PM
.Denver, Co.
Joined Feb 2003
Ahem... I kinda remember Lenny dominating both days with his Mirage.
Old Nov 01, 2004, 09:11 PM
patagonia,az
Joined Oct 2002
you should look at the results then old chap
Philip
Old Nov 02, 2004, 08:30 AM
sierra-gold is offline
Find More Posts by sierra-gold
Joined Sep 2002
Where are they posted?
Did a Goggle on ESWC and got all kinds of unrelated stuff.
Sierra Gold
sierra-gold is offline Find More Posts by sierra-gold
Old Nov 02, 2004, 09:44 AM
.Denver, Co.
Joined Feb 2003
http://www.soarabq.org/f5j_wc_2004/f5j_main.htm
Old Nov 02, 2004, 12:24 PM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Originally Posted by Stan Rose
models are usually Speed 400 4.8v and Comotec 4.5:1 gearbox turning a 12" x 8" or thereabouts on 7 x KAN 1050's or these days 7 x GP1100's. .
stan,
How many flights can you get out of that set up? I have the same set up, without cooling hole, I almost burn mt finger on the motor. I got about 20-25 flights then the motor is done. The plane is a converted 1.8m Candy.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Nov 02, 2004, 03:44 PM
Stan Rose's Avatar
Joined Dec 2003
I have been flying mine in competitions and for fun flying for about three years now with no problems. The motor run is usually no longer than about 25 sec's. at a time and I suppose that I run the motor about three times per flight. I don't have any cooling holes. I know others that do have to replace their motors from time to time but these motors are very cheap to replace.
Limited Motor run computer program downeym Electric Sailplanes 10 Apr 19, 2005 03:26 PM
Information on Speed 400 reversed Motor Sarj Power Systems 7 Aug 22, 2003 02:17 AM
WTB: Promax Speed 400 cobalt motor tufnik Aircraft - Electric - Airplanes (FS/W) 2 May 30, 2003 12:14 PM
Wattage Speed 400 Cobalt Motor Badger B Beginner Training Area (Aircraft-Electric) 8 May 01, 2003 03:45 PM
Limited Motor Run - how limited? stuartaw High Performance 4 Mar 07, 2003 10:41 PM
