Old Oct 31, 2004, 03:10 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
Alert
AIR BOSS by HERR ENGINEERING
My buddy and co-worker that lives in Titusville, Florida and test flyer for Tom Herr when he had his modeling business there gave me a Prototype Airboss that was built by Tom Herr himself, of course these were the days before SIG Manufactoring bought out HERR.
Here's the spec's from the SIG WEB SITE:
guapoman2000 is offline Find More Posts by guapoman2000
Old Oct 31, 2004, 03:14 PM
Account closed
Joined Oct 2002
Of course this is the High Wing Version of the Mini-Sport, for the mini-sport go to:
http://www.rcgroups.com/forums/showthread.php?t=150944
The Airboss will be powered by an ASTRO FLIGHT 010, 14-turn and in the GWS EPS-300C "A" gearing (3.75:1 ratio) swinging an APC "Slow Flyer" 8 X 6 prop and using the First Generation ETec 1200mAH, Li-POLYs.
Carlos
Old Oct 31, 2004, 03:20 PM
wattsup_kz is offline
Find More Posts by wattsup_kz
Frequent Flyer
wattsup_kz's Avatar
Kalamazoo, MI USA
Joined Aug 2003
Very nice, Carlos!
Is that as easy to build as it looks?
Brian
wattsup_kz is offline Find More Posts by wattsup_kz
Old Oct 31, 2004, 03:25 PM
Account closed
Joined Oct 2002
Originally Posted by wattsup_kz
Very nice, Carlos!
Brian
Brian,
It is a super easy build. Herr Engineering always have been known for their easy LASER CUT parts such that you shake the box and the wing ribs come lose!
The FUSE is interlocking which Herr Engineering pretty much was one of the first companies to offer this kind of build.
I Love my Mini-Sport which is the low wing version of the Air Boss and it flys just SUPER!
Carlos
Old Nov 01, 2004, 05:04 PM
Account closed
Joined Oct 2002
Oh, yes, this model sports a tricycle landing gear arrangement but, I think it will be a tail dragger instead. Unless of course I can think of a way to have a torque rod from the rudder all the way to the front nose gear?
Anyone has any ideas?
Thanks!
Carlos
Old Nov 01, 2004, 07:14 PM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
That looks big enough - use a separate servo for the nose wheel plugged into an aileron splitter plugged into the rudder channel.
LenBFP is offline Find More Posts by LenBFP
Old Nov 02, 2004, 07:23 AM
Account closed
Joined Oct 2002
Thanks! Wow, the Aileron spitter cable is a great suggestion, no need to deal with heavy push rod piano wires!
Carlos
Old Nov 02, 2004, 08:43 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
Thanks!
Carlos
Use the small cable - it makes routing very easy....
Old Nov 02, 2004, 12:40 PM
Account closed
Joined Oct 2002
mike,
You mean servo extension cable? If so, I always buy the Regular servo extension cable 3 inch instead of the heavy duty that comes in a higher gage wiring and it's heavy.
Thanks!
Carlos
Old Nov 02, 2004, 12:47 PM
simano is offline
Find More Posts by simano
Jungmeister 55
simano's Avatar
Orlando Herndon, Florida, United States
Joined Sep 2002
Carlos,
Nice project. I would personally go tail dragger...I would even put a couple wheel pants on this one!!...and don't forget to enlarge the rudder/elevator slightly for the kind of wonderful snap rolls and spins I used to get out of my Mini Sport.
Just my two cents worth...
Gerry.
simano is offline Find More Posts by simano
Old Nov 02, 2004, 01:02 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
mike,
Thanks!
Carlos
Nope I am talking about the flexible pushrod type cable. Like this:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFU94&P=7
Makes servo position and routing very very easy. That cable is very flexible and will bend very easily. Some use them for parkflier aileron connections as well. They are perfect for nose gear steering.
Old Nov 03, 2004, 01:49 PM
Account closed
Joined Oct 2002
Gerry (SIMANO),
I just may consider the tail dragger option to keep her light as possible, hum...
Thanks!
Carlos
Old Feb 06, 2005, 01:17 PM
Account closed
Joined Oct 2002
Update!
Okay, after having this poor bare bones model up on the PVC pipe shelving, I have decided to go with a tail dragger arrangement and I just purchased the Ultracote by Hanger-9 (Real Light stuff, and low temp) covering "Cub Yellow" and plan to use bright shinny black stripes for the leading edge of the wing and side pin stripes along the FUSE.
However, first, I am going to sheet the leading edge of the wing since the Airboss does not come with the twin stringers as the mini-Sport wing comes with. (mini-Sport has the same wing).
Carlos
Old Jul 07, 2007, 12:22 AM
willin is offline
Find More Posts by willin
willin's Avatar
In my Blu heaven! near Lincoln NE
Joined Mar 2003
Any further info on this or any other Air Boss's?
Looks like a great model to be sure!
Robert
willin is offline Find More Posts by willin
Old Jul 07, 2007, 09:07 PM
willin is offline
willin's Avatar
Joined Mar 2003
I was thinking of using a 12mm brushless motor and gearbox instead of the 280 DD. Would this be a good option?
Is there any interest in the Air Boss anymore?
Robert
For Sale Rubber Powered Kits by Herr Engineering tailskid2 Aircraft - Fuel - Airplanes (FS/W) 5 Mar 05, 2007 08:43 PM
P-51D Mustang by Herr Engineering guapoman2000 Parkflyers 20 Mar 31, 2006 10:19 AM
MINI SPORT by HERR ENGINEERING (Guapoman2000) guapoman2000 Parkflyers 146 Mar 29, 2005 10:09 PM
Question Herr Engineering Air Boss flyinredneck Parkflyers 5 Feb 06, 2005 01:12 PM
HELIO COURIER (30 inch) by HERR ENGINEERING guapoman2000 Parkflyers 2 Nov 01, 2004 08:09 AM
