Old Oct 29, 2004, 10:41 AM
ShaverR6 is offline
Find More Posts by ShaverR6
4th Generation
ShaverR6's Avatar
Canada, SK, Division No. 7
Joined Sep 2004
Billing boats Dragon (Dragen)
Hello, I am new to sailing but not new to R/C. I have been looking around for sailboats and pretty much all of them have been made of ABS and all look the same. I am really looking for a wooden hulled sailboat that looks so good that it could be put on display when not in the water. I came accross the Billing boats Dragon and it seems perfect, except for one thing. The Dragon is supposed to be a display model only, but i have heard that it can be converted to R/C. I was wondering, what type of modifications would be needed to acheive this? One thing that i noticed was that the keel was rather short and doesnt seem to have any ballast. Would this make the boat unstable? I would apprecieate any info that could be provided. Thanks!
Patrick
ShaverR6 is offline Find More Posts by ShaverR6
Old Oct 29, 2004, 08:37 PM
Chris P is offline
Find More Posts by Chris P
Portland, Oregon, USA
Joined Apr 2001
Had this kit quite a while ago(I built it probably 20 yrs ago from a 30? yr old kit, so take this info with quite a few grains of salt). The kit came with a solid lead keel. As I remember mine sat a little below the designed waterline with the rc set in it and would dip the rail easily but wouldn't heel over much more. I don't recall exactly how I set up the RC. I think I just had the main on a long arm servo in front of the mast. Also I fiberglassed and painted the hull as I did a poor job on the planking. It couldn't have been too hard as it was my first sailboat and I was fairly young and dumb. It's a beautiful boat and was fun to sail.
By the way, welcome to the forum, I'm new myself.
Chris
Chris P is offline Find More Posts by Chris P
Old Oct 30, 2004, 01:51 AM
ShaverR6 is offline
4th Generation
ShaverR6's Avatar
Joined Sep 2004
Thank you very much Chris. I am looking forward to tackling this project this winter, it will be a nice break from building airplanes all the time!
Pat
Old Oct 30, 2004, 06:40 PM
Chris P is offline
Joined Apr 2001
Good luck and let us know how it turns out. I would like do do that one again sometime.
Old Mar 18, 2005, 02:30 AM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Dragon
Hi Shaver,
How did the conversion go? I have just started my Dragon and I want to make it RC. Did you glass your hull?
Don
MILLERTIME is offline Find More Posts by MILLERTIME
Old Mar 18, 2005, 01:19 PM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Hi Shaver,
As stated above the Dragen was designed as a display model, making it RC requires a lightweight hull, or a scaled up one, to get the extra bouyancy for the RC components.
@Don: If you haven't started planking yet, take out the Dremel and reduce the amount of wood in the frame by at least 50% (more is even better), the hull will be stable enough if you add a thin (outside) layer of glasscloth and epoxy resin.
You'll need to build as light as possible, as it's a relative small boat.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Mar 21, 2005, 01:43 AM
MILLERTIME's Avatar
Joined Apr 2004
Jan,
Thanks for the advice; I will use most of it. I am not looking for speed, I have 3 other sailboats. I have a Pro Boat Sunrise 24 The Dragon is bigger. I think it looks to good to just be setting on a shelf.
Don
Old Mar 26, 2005, 12:43 AM
MILLERTIME's Avatar
Joined Apr 2004
Started the planking, slow work to get it right.
Old Apr 01, 2005, 12:11 PM
MILLERTIME's Avatar
Joined Apr 2004
More planking.
Old Apr 01, 2005, 06:25 PM
ShaverR6 is offline
4th Generation
ShaverR6's Avatar
Joined Sep 2004
Wow guys, they look great.
I'm sad to say that i never got around to build the boat. I have been to busy with work and my airplane models. I still want to build this boat in the future though, especially after seeing your boats! Keep up the good work....and keep posting pictures.
Pat
Old Apr 06, 2005, 02:22 AM
MILLERTIME's Avatar
Joined Apr 2004
Planking is done.
Old Apr 06, 2005, 12:11 PM
ShaverR6 is offline
4th Generation
ShaverR6's Avatar
Joined Sep 2004
MPO11, looks great man!
Is there any weight to the keel? (lead) How stable is this boat going to be with such a shallow keel?
Pat
Old Apr 06, 2005, 11:36 PM
MILLERTIME's Avatar
Joined Apr 2004
Thanks Pat,
There is a brass keel that attaches to the wood keel; I will make it as heavy as needed to get the water line right. Im not looking for speed I have other boats for speed.
I think it looks to good to be left sitting on a shelf.
Don
Old May 26, 2005, 05:42 PM
MILLERTIME's Avatar
Joined Apr 2004
New skipper Blue, checking out the mast.
Old May 30, 2005, 09:28 AM
ShaverR6 is offline
4th Generation
ShaverR6's Avatar
Joined Sep 2004
Looking Good Don, any words on your progress?
Pat
Calypso Billing Boats WiltP Scale Boats 1444 Feb 04, 2016 04:40 AM
Billing Boats Smit Rotterdam. yngwie Scale Boats 52 Dec 28, 2012 01:59 PM
Discussion Billing Boats Dragen suirendoujin Sailboats 17 Jan 13, 2010 11:44 AM
Billing Boats mindbender_tm Dock Talk 2 Jul 31, 2005 07:31 AM
billing boats kits. thething84 Scale Boats 0 Apr 03, 2005 05:56 AM
