Old Oct 28, 2004, 07:39 AM
DsWright is offline
Find More Posts by DsWright
ProBro #1889
DsWright's Avatar
United States, OH, Amelia
Joined Aug 2004
Mountain Models Dandy Sport build problems....
I started building my MM Dandy Sport a few days ago, and have hit a major snag.
When i ws building the wing, i mistakenly put the thicker balsa ribs in the wrong spots.... I noticed this only after i glued them in... Now im also noticing a signifigant "twist" warp in them, not sure if this is from improper build or if the balsa was slightly warped....
Will CA Debonder allow me to dissassemble the wing and fix the problem? Or will it ruin it further and force me to buy another wing which puts a dent in my budget to get this thing airborne....
Also after assembling the fuselage and ailerons without a problem i tried to assemble the landing gear and failed miserably at bending the wire.... it's beyond use now..... Is this plane a good belly lander? all i have for a runway is grass anyway.... If it belly lands well does it break props often from belly landing like my E-starter does?
thanks for your help.
And i must add, Despite my mistake with the wing (my first balsa build), i want to make CLEAR that this kit appears to me to be of superb quality, and im in no way trying to bash the product because of my building errors.
DsWright is offline Find More Posts by DsWright
Old Oct 28, 2004, 08:12 AM
JR in Cinci is offline
Find More Posts by JR in Cinci
Cincinnati, OH
Joined Mar 2003
Can't help you with the building question (but someone here will).
But on the belly landing question, I took the landing gear off my Dandy Sport a couple months ago, and it lands great in the grass. No broken props (yet).
Good Luck,
JR in Cinci
JR in Cinci is offline Find More Posts by JR in Cinci
Old Oct 28, 2004, 08:18 AM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
DsWright,
Drop Matthew an email (matthew @ mountainmodels.com) and he an fix you up with whatever you need to fix the plane. We want to see you successful.
Doug
CoClimber is offline Find More Posts by CoClimber
Old Oct 28, 2004, 01:16 PM
DoomsDay is offline
Find More Posts by DoomsDay
DoomsDay's Avatar
Charlotte Douglas, NC
Joined Sep 2003
I did the exact same thing with my wings. Didnt notice the thickness difference till it was to late. I was unable to get the debonder to work on mine , although after the entire build I did use almost an entire ounce of ca on that plane, so maybe it wasnt surprising I couldnt get the debonder to work.
DD
DoomsDay is offline Find More Posts by DoomsDay
Old Oct 28, 2004, 01:44 PM
Tom Korn is offline
Find More Posts by Tom Korn
30 seconds until re-kit
Casselberry, Florida
Joined Dec 2002
Mountain Models is amazing. Even if you mess up, they will replace the stuff for you if you ax them. They really do care about making sure you are successful.
Doug, did you get the photo's from SEFF that I mailed to you? Are you coming back in 2005? I'll work up some new heckles!
Oh yeah, you can buy the right size wire at the local hardware really cheap, and have lots of practice bending landing gear.
Tom Korn is offline Find More Posts by Tom Korn
Last edited by Tom Korn; Oct 28, 2004 at 01:45 PM. Reason: stupid fingers can't spell!
Old Oct 28, 2004, 01:56 PM
DsWright is offline
ProBro #1889
DsWright's Avatar
Joined Aug 2004
I emailed them earlier, thier customer service is fantastic..... way above and beyond the call of duty.
I did the same thing with alot of CA on mine.... So i doubt i will get them to debond... But a new wing is on the way.
Needless to say my next plane after this will also be a MM plane.
Old Oct 28, 2004, 05:11 PM
Hangar-Flyer is offline
Find More Posts by Hangar-Flyer
Hangar-Flyer's Avatar
tucson az
Joined Sep 2003
<snip>
I tried to assemble the landing gear and failed miserably at bending the wire.... it's beyond use now.....
See the attached pic of my Dandy Sport using a "double strut" style landing gear. Rubber bands and dowels hold the gear against the bottom of the fuselage.
This takes much of the stress off the fuselage in hard landings and the smaller gauge wire is easier to bend.
Just an idea from a "completely unappreciated genius model builder" (:})
Hangar-Flyer is offline Find More Posts by Hangar-Flyer
Old Oct 28, 2004, 05:31 PM
bobbygee is offline
Find More Posts by bobbygee
bobbygee's Avatar
Round Rock, Texas
Joined Feb 2004
Real man of genius!
Here's to you, Mr. Completely Unappreciated Genius Model Builder!
That mod looks great for the Dandy! It spreads the load out on the fuse and will pop rubber bands before it pops the fuse formers!
Well done!
BobbyG
bobbygee is offline Find More Posts by bobbygee
Old Oct 28, 2004, 06:28 PM
DsWright is offline
ProBro #1889
DsWright's Avatar
Joined Aug 2004
Agreed, ingenious mod.
May try that myself
Old Oct 28, 2004, 08:07 PM
tucson az
Joined Sep 2003
May try that myself
Well...since you pilots seem interested, here are a couple of extra picture that show more detail.
The channels for the wire are optional..just depends on how hard landings are on what kind of surface..grass, gravel, etc.
Both wires go thru the wheel hub...one just sits there...the other has a holder on it.
For you experimenters...the whole shebang comes off easily...just remove the rubber bands and it's easy to try some other sort of configuration.
Old Nov 13, 2004, 08:31 AM
WebWolf is offline
Find More Posts by WebWolf
Wind is my sworn enemy
WebWolf's Avatar
Gothenburg Saeve, Sweden
Joined Sep 2004
I'm gonna build this landing gear on my Dandy tonight. I'm an engineer and my knowledge says that it will work great.
WebWolf is offline Find More Posts by WebWolf
Old Nov 13, 2004, 12:51 PM
peterv is offline
Find More Posts by peterv
Senior Member
peterv's Avatar
USA, IL, Barrington
Joined Feb 2001
Elegant yet simple! Nice engineering!!
Pete
peterv is offline Find More Posts by peterv
Old Nov 13, 2004, 03:02 PM
SlowRider is offline
Find More Posts by SlowRider
It's the last plane honey
SlowRider's Avatar
Granite Bay, CA USA
Joined Jul 2003
The DS is a great belly lander! The high wing design with the aileron servo on top is especially suited for belly landings. After over 100 belly landings with my first DS it finally came to its demise after I flew it into a light pole...sigh...
I promptly ordered a second one that's currently queued behind a Mini Speedwing and a G-Ride, hope to have it finished by the new year.
I've never broken a prop (GWS 11x8) landing the DS on the grass; I primarily fly in parks and soccer fields and grass is the predominate surface.
Andy
SlowRider is offline Find More Posts by SlowRider
Old Nov 13, 2004, 03:15 PM
SlowRider's Avatar
Granite Bay, CA USA
Joined Jul 2003
Here's some pics of my DS in-flight; just my bias, but I prefer the lines without gear... The orange prop has been colored black with a Sharpie.
Andy
Discussion Mountain Models Dandy Sport build...Want one? mr_frogdude Parkflyers 39 Jan 22, 2006 06:38 AM
Mountain Models dandy sport question rcplanecrasher Electric Plane Talk 1 Nov 07, 2005 01:07 AM
Question Whats the deal with Balsa and the Mountain Models Dandy Sport? thatchf137 Parkflyers 45 Feb 02, 2004 07:10 PM
Question Pros and cons of the Mountain Models Dandy Sport? thatchf137 Parkflyers 14 Dec 08, 2003 04:29 PM
Having trouble with Mountain Models Dandy Sport construction Skawrpion Parkflyers 64 Sep 19, 2003 06:57 PM
