Old Oct 27, 2004, 10:16 PM
bc-slowflyer is online now
Find More Posts by bc-slowflyer
Lower, Lower
bc-slowflyer's Avatar
Penticton,BC, Canada
Joined Feb 2004
JR XP8103 battery plug
Does anyone know where I could find a battery plug and leads for a JR XP8103 transmitter? I am planning to mke a higher capacity battery pack for this transmitter and keep the stock battery as a spare.
Thanks;
Rod
bc-slowflyer is online now Find More Posts by bc-slowflyer
Old Oct 27, 2004, 11:41 PM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
I got mine from MPI Maxx. I believe it is #2803. You can also find the mate there, #2810, if you want to make up a charging cord. Both come with wire pigtails in place.
GBR2 is offline Find More Posts by GBR2
Old Oct 27, 2004, 11:58 PM
kwilliby is offline
Find More Posts by kwilliby
Omaha, Nebraska, United States
Joined Aug 2002
I got a couple from RadicalRc.
kwilliby is offline Find More Posts by kwilliby
Old Oct 28, 2004, 12:40 AM
Lower, Lower
Joined Feb 2004
GBR2;
Thanks for the info but MPI won't ship to Canada for some reason. What did they chrge you for shipping?
kwilliby;
Thanks for the link. I sent Dave at Radical RC an email.
Old Oct 28, 2004, 02:43 PM
rroback is offline
Find More Posts by rroback
Convert!
rroback's Avatar
Los Angeles, CA (UCLA)
Joined Nov 2002
I finally gave up on my jr 8103 batteries, and got a duralite lithium pack. now works very well . I also just got a power duck antenna, but have not had a chance to test it.
Rhett
rroback is offline Find More Posts by rroback
Old Oct 28, 2004, 02:58 PM
jatt5abdaa is offline
Find More Posts by jatt5abdaa
Orlando, FL
Joined Jun 2004
Hi All.
I am also not happy with the NiCd's on my 8103. Very low time...
I want to go with NiMh or Lithium. Which is better & safer and how much do they cost.
TIA.
jatt5abdaa is offline Find More Posts by jatt5abdaa
Old Oct 28, 2004, 04:25 PM
kwilliby is offline
Joined Aug 2002
I bought a 1650 mah pack from radicalrc. with the little white plug i think it was about $30. works great. plus i can charge it at about 1amp at the field if i need to.
Old Oct 29, 2004, 03:57 PM
Orlando, FL
Joined Jun 2004
Is that NiMh or NiCd.
What is the advantage of using LiIon
TIA.
Old Oct 29, 2004, 04:06 PM
rroback is offline
Convert!
rroback's Avatar
Joined Nov 2002
That I believe is nimh. I use my lithium pack, because lithium has very little self discharge, in that I can leave the transmitter for months at a time with little to no chance in voltage.
Rhett
Old Oct 29, 2004, 06:12 PM
kwilliby is offline
Joined Aug 2002
Yes my pack was NIMH. Haven't tried Lithium in my transmitter yet but seems like another good option to me. The one drawback with NIMH is that they seem to discharge quite a bit if you don't use them and charge them. Over the winter I have to cycle all of my NIMH batteries to keep them up to par.
Old Oct 29, 2004, 06:25 PM
rroback is offline
Convert!
rroback's Avatar
Joined Nov 2002
ahh... so exciting to be done with winter cycling. but then... I'm basically done with winter too.. living in southern california, winter is 60 ? f .
Rhett
Old Oct 29, 2004, 06:41 PM
kwilliby is offline
Joined Aug 2002
Rhett
Well, it's 70 in Omaha, Nebraska! But in a couple months it will be about 0-20. Suppose it will be just a wee bit warmer in SC then! Someone please remind me why I live here?????
Old Nov 02, 2004, 09:09 AM
Orlando, FL
Joined Jun 2004
Hi Rhett.
Where did you get the Lithium pack and what kind of charger you need for it. The only LiPo charger I have is the Apache 2500.
TIA.
Old Nov 02, 2004, 03:19 PM
rroback is offline
Convert!
rroback's Avatar
Joined Nov 2002
http://www.duralitebatteries.com/ The apache will work. I have an orbit pro, but all you need is a charger that can charge 3 cells ( I believe you can do up to four). Depending on the connector you have installed, you can buy an adaptor from tower hobbies that goes from jst to the transmitter prong, and it works well, and is only a few bucks.
RHett
Found JR. Tx Battery Plug Broken_Arrow Aircraft - General - Radio Equipment (FS/W) 4 Aug 14, 2007 04:41 PM
WTB JR XP8103 battery plug bc-slowflyer Aircraft - General - Radio Equipment (FS/W) 2 Nov 01, 2004 06:39 PM
