Old Oct 27, 2004, 05:58 PM
radcast2 is offline
Find More Posts by radcast2
just another $$$ hobby
Rustburg, Virginia, United States
Joined Aug 2004
Biulding Estarter need conversion chart
Does anyone know where I can get a conversion chart so that I can tak ethose mm measurments and convert them to inches, 1/16", 1/8" so on??
radcast2 is offline Find More Posts by radcast2
Old Oct 27, 2004, 06:29 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
http://www.onlineconversion.com/length_common.htm
http://www.ilpi.com/msds/ref/distanceunits.html
Basketcase is offline Find More Posts by Basketcase
Old Oct 27, 2004, 07:09 PM
Jimbo45cn is offline
Find More Posts by Jimbo45cn
Jimbo45cn's Avatar
Southwest Florida
Joined Mar 2004
You are probably going to run into this time and time again. Best thing to do is get a ruler that has both inches and mm, centimeters. I use both sides all the time.
Jimbo45cn is offline Find More Posts by Jimbo45cn
Old Oct 27, 2004, 09:52 PM
JDCochran is offline
Find More Posts by JDCochran
LiPo Suction Specialist
JDCochran's Avatar
Atlanta Hartsfield, Georgia, United States
Joined Apr 2002
1" = 25.4 mm = 2.54 cm
That's all you gotta need to know.
JDCochran is offline Find More Posts by JDCochran
Old Oct 28, 2004, 01:11 AM
KillerWatt is offline
Find More Posts by KillerWatt
Colonial Heights, Virginia, USA
Joined Mar 2001
Just get a decent ruler (the're available everywhere for about 50 cents and up) that has BOTH metric and your 1/16 stuff markings.......It's easier to just directly "read" the mm scale without introducing a likely math error (happens all the time with crummy fitting results) once you get used to the fact that a lot of popular planes ARE off-shore designed and the plans or instructions are likely to be mm's......Just do it and forget the calculator...I'm a S Side Va. anti-metric guy from way back but life forces changes sometimes....... kw
KillerWatt is offline Find More Posts by KillerWatt
Old Oct 28, 2004, 01:18 AM
shams42 is offline
Find More Posts by shams42
shams42's Avatar
Athens, GA
Joined Jan 2004
You can use google. It will do unit conversions. The syntax is:
X unit to unit.
Example: 55 mm to in
It's awesome!
Matt
shams42 is offline Find More Posts by shams42
Old Oct 28, 2004, 06:33 AM
radcast2 is offline
Joined Aug 2004
You just type it in the search box...I typed in the searchbox 23.5cm and it told me 9.25" that is sweet
actually I typed in convert 23.5cm to inch
Gas to electric conversion chart? hawknips Power Systems 31 Oct 25, 2009 09:00 PM
Discussion UNIT CONVERSION CHART FOR Ohio ENGINEERS Don Sims Humor 1 Jun 07, 2005 08:27 PM
eStarter...need alternative cowling source millerhill Parkflyers 3 Apr 02, 2005 03:42 PM
cutting aileron for the Estarter need help radcast2 Electric Plane Talk 11 Mar 25, 2005 07:54 PM
Need good chart for max discharge rates KenP Batteries and Chargers 2 Jun 19, 2003 08:49 AM
