Old Oct 27, 2004, 08:32 AM
Stefan lamers is offline
Find More Posts by Stefan lamers
Groningen, The Netherlands
Joined Aug 2004
how to turn a drawing on paper into PDF file?
I have drawn the plans for my airplane on paper. Now i want to make a pdf file from it so i can post it. but first i want to add text and copy parts.
i have an A4 scanner. if i turn it into a normal pdf file i can't edit it, but if i make a bitmap first, edit it and then make a pdf again it changes the size when i print it.
what is the best way to do this?
greetings
stefan
Stefan lamers is offline Find More Posts by Stefan lamers
Old Oct 27, 2004, 08:33 AM
BobT is offline
Find More Posts by BobT
Colorado Springs Peterson, Colorado, United States
Joined Sep 2004
What software do you want to edit the plan in?
BobT is offline Find More Posts by BobT
Old Oct 27, 2004, 10:27 AM
Joined Aug 2004
Hi
I have windows paint, or paint shop pro
Old Oct 27, 2004, 10:51 AM
Bill Glover is online now
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
'Quick & dirty' - scan the paper plan into a hi-res jpeg or bmp, edit in PSP, print out at A4 size, scan print into PDF.
Should work OK if you can't find a better way.
Bill Glover is online now Find More Posts by Bill Glover
Old Oct 27, 2004, 12:15 PM
windtrader is offline
Find More Posts by windtrader
Bay Area, Ca
Joined Jul 2004
This shouldn't happen if you keep the same pixels (W x H) in and out. Whether it is A4 or not should not even come into play except to set your input scanning area. Once it is bits you should be fine. Just make sure you do not have any stretch, fill, etc settings that would distort the image.
windtrader is offline Find More Posts by windtrader
Old Oct 29, 2004, 12:57 AM
vpatron is offline
Find More Posts by vpatron
vpatron's Avatar
San Diego/Las Vegas
Joined Sep 2004
Use .tif format, or Scansoft's Paperport
Can your software write into .tif format and edit it? I believe .tif contains page size info so it should not resize incorrectly and you can edit it. Then you can convert to .pdf after adding the annotations.
I use Scansoft's Paperport. Version 9.0 scans into .pdf and allows you to add additional annotations, cut and paste portions, straighten, etc. It's a bit pricey, but is reasonable on Ebay.
Good luck,
-Vince
vpatron is offline Find More Posts by vpatron
How to download the IR thread into one file epilot Scratchbuilt Indoor and Micro Models 11 Jun 24, 2004 01:41 AM
How do I turn a rubber 150 Aerobat into electric? joeythes Sport Planes 2 Aug 20, 2003 02:40 PM
