Old Oct 26, 2004, 11:18 AM
e-geezer is offline
Find More Posts by e-geezer
Up faster, higher, longer
e-geezer's Avatar
County Sligo, Ireland
Joined Sep 2003
You could get more thrust and less speed by using (a prop with less pitch) and/or (a lower voltage battery with perhaps a slightly higher pitch prop to bring the current back up).
e-geezer is offline Find More Posts by e-geezer
Old Oct 26, 2004, 05:55 PM
Dave T is offline
Find More Posts by Dave T
Burlington Intl, Vermont, United States
Joined Apr 2004
cd power
I think that I have the lowest pith prop I can buy. Sorry I din't tell the amps The Double 22.7mm motor draws 12amps at 11 volts with the 10x3.8 prop
I think I will have to rewind the motor with a smaller gadge wire mabee 26gwire and more winds mabee 20 turns then check amps and posibly go with a 11x3.8 or 11x4.7 prop. I will try to do that in the next week and post the results. Thanks
Dave T is offline Find More Posts by Dave T
Old Oct 27, 2004, 04:55 AM
e-geezer is offline
e-geezer's Avatar
Joined Sep 2003
I meant to say:
You could get more thrust and less speed by using (a prop with less pitch) and/or (a lower voltage battery with perhaps a slightly higher diameter prop to bring the current back up).
Also, using more turns of thinner wire will take less power for the same battery. You'd then need an even bigger prop for the same power. I'd just go for a larger diameter, lower pitch prop. Keep increasing the prop diameter until the current is too high then go back a size.
Old Sep 21, 2014, 03:32 AM
The Hung is offline
Find More Posts by The Hung
Joined Sep 2014
Velineon 380 overheating.
I tried to mod may J3 cub by using a velineon 380 with an 8040 prop. it was very powerful, but didn't last long d/t overheating. Can anyone help me solve this problem. Should I change the battery (current 11.1v 2200) or the prop?
The Hung is offline Find More Posts by The Hung
Idea Successful Power Systems jrb Power Systems 584 Yesterday 09:10 PM
Successful Power Systems sandburr Power Systems 0 Jul 31, 2005 06:57 PM
Successful Power Systems II superflyX Power Systems 0 May 18, 2005 11:47 PM
Another question from Successful Power Systems helisfreak Power Systems 1 Apr 16, 2004 10:28 AM
Discussion removed from Successful Power Systems thread SharksTooth Power Systems 4 Apr 15, 2004 11:45 AM
