Old Oct 26, 2004, 11:51 PM
Hutch is offline
Find More Posts by Hutch
Slopeaholic
Hutch's Avatar
Roseville, California, United States
Joined Mar 2001
Build Log
Homebrew Mini DLG Build
Well folks, I have been watching this place for about three years now and am finally becoming a participant. I have been dying for something small and portable that I could have fun with. There are many great planes out there but in my opinion nothing beats the satisfaction of heaving your own bird into the great wide open. That being said, if it weren't for the wealth of information and contributions of others in these forums I may not have given this a whirl. My yet unnamed bird's rough specifications are as follows:
Wing Span: 36"
Wing Area: 171 Sq"
Root Chord: 5.5"
Tip Chord 4"
Airfoil: AG-03
More to come assuming I can get the photo posting figured out....
Hutch is offline Find More Posts by Hutch
Old Oct 27, 2004, 01:27 AM
Hutch is offline
Slopeaholic
Hutch's Avatar
Joined Mar 2001
For the vertical and horizontal stabilizer I used 1/32 balsa with carbon tow reinforcement, and light fiberglass. The drawings show two vertical tails. I drew the tall one first, but after reading about Denny's reasons for the new XP-4 tail surfaces, I went with the lower aspect ratio version. I used the poor mans "bagging" method to apply the fiberglass after sanding the balsa to shape. This was my first time using this technique, and the results weren't too bad. Pretty neat idea for those of us who haven't made that coveted next step towards total vacuum bagged sailplane nirvana.
Details on the technique are here.... http://www.sjsf.org/waxpaper/waxpaper.htm
Old Oct 27, 2004, 02:59 AM
sloppytypist is offline
Find More Posts by sloppytypist
shoreline, washington
Joined Sep 2002
nice work.
if yor tail servos are in the back of the fuse, you may want to consider a longer nose for balace, but it looks like you have 4 x 270mah batteries up front. it will be close.
i built a 48" span and have 2 servos, rx and 4x110mah in the nose, before the wing and it just balances.
sloppytypist is offline Find More Posts by sloppytypist
Old Oct 27, 2004, 10:14 AM
Hutch is offline
Slopeaholic
Hutch's Avatar
Joined Mar 2001
I am a little worried about having to add weight to the nose. The components that I drew the plane around are as follows:
Battery : SR Batteries SR-190 flight pack (1.3 Oz)
Servos : 4 Ea. Cirrus CS-4.4 (Total .76 Oz)
Receiver : Berg 5*DSPII W/ Case Removed (.34 Oz)
That doesn't leave me much room for error in creating a light airframe. I am trying to keep the wing loading under 6oz/Sq'.
Old Oct 27, 2004, 07:01 PM
Joined Sep 2002
heres a pic of the nose of a 48" dlg.
1.96 sq. ft. wing area
7.4 oz auw
3.78oz/ft.
rudder elevator only
nose 7.25" from leading edge
Old Oct 27, 2004, 11:08 PM
Hutch is offline
Slopeaholic
Hutch's Avatar
Joined Mar 2001
With the tail parts complete, I moved to the wing. Les Horvath cut some great cores for me. The wing is sheeted with light 1/32" balsa. I reinforced this with a 3/4" wide strip of carbon fiber fabric along the top and bottom. Then I mixed up some epoxy and sandwiched everything up. The carbon may have been overkill, but my thinking was that with a discus launch I would want some sort of pseudo spar to tie the wing together. I wasn't too sure if the balsa alone would have been strong enough.
Old Oct 27, 2004, 11:14 PM
Hutch is offline
Slopeaholic
Hutch's Avatar
Joined Mar 2001
The next morning I pulled the weights off, and pulled the cores out of the beds. A little sanding and shaping and I'll have a shiny new set of wings!
Old Oct 28, 2004, 09:12 PM
Hutch is offline
Slopeaholic
Hutch's Avatar
Joined Mar 2001
With the leading edges attached, the tips cut and tip blocks installed it was time for some good old fashioned sanding. Once that was complete I glued a carbon fiber reinforcement for the launch peg to the top and bottom of the left tip. This also served to tie the joint between the tip block and the foam core together. Once that was dry and lightly sanded I trimmed some ultra light fiberglass to the shape of the wing. Finally I wetted out the fiberglass with some epoxy and blotted the excess with reckless abandon. Time to do something else while the wing cures.
Old Oct 28, 2004, 09:16 PM
Hutch is offline
Slopeaholic
Hutch's Avatar
Joined Mar 2001
Rudder and elevator cut away from their respective tail surfaces.
Old Oct 29, 2004, 01:47 AM
dustn is offline
Find More Posts by dustn
cranium accessories
dustn's Avatar
Raleigh, NC
Joined May 2004
wow hutch! looks nice!
i'm looking forward to a flight report!
dustn is offline Find More Posts by dustn
Old Oct 29, 2004, 02:49 AM
mr_wood is offline
Find More Posts by mr_wood
London Heathrow, Great Britain (UK)
Joined Sep 2001
with cf spars, wood and glass - won't the wings be a little heavy ?
mr_wood is offline Find More Posts by mr_wood
Old Oct 29, 2004, 04:10 AM
yorbenator is offline
Find More Posts by yorbenator
fly-crash and resurect
yorbenator's Avatar
Joined Jun 2004
how could i get in touch with the guy that cuts your cores??
and how are you gonna do the fuse???
yorbenator is offline Find More Posts by yorbenator
Old Oct 29, 2004, 10:25 AM
Hutch is offline
Slopeaholic
Hutch's Avatar
Joined Mar 2001
Dustin: Thank you! I'm looking forward to seeing if it flies too.
Mr Wood.: I am definitely going to be out of the 3-4 oz/sq' range unfortunately, but that is one of the reasons I ordered two sets of cores. This was definitely a "lets see how everything ends up if I do it this way" run. Unfortunately I am used to building slope planes so I still have build it too strong and build it too heavy stuck in my head. I am trying very hard to suppress that instinct in this build. I am borrowing a scale this weekend so I will be able to get an accurate idea of the weights of my components.
Yorbenator: He has a website http://www.compufoamcore.com/ His e-mail is on the website. Just let him know what you are looking for, and he'll give you a quote. Before you know it you are opening a box with some very well done cores just begging to be turned into a sailplane.
Old Oct 29, 2004, 01:46 PM
windsox is offline
Find More Posts by windsox
windsox's Avatar
Rochester New York
Joined Feb 2004
It is not a loss. It sounds like your first design was a bit overbuilt. but assuming it fly's well it will still make a sweet light lift sloper!
windsox is offline Find More Posts by windsox
Old Oct 29, 2004, 02:47 PM
Rain City Flyer is offline
Find More Posts by Rain City Flyer
Good thing balsa floats!
Rain City Flyer's Avatar
Seattle
Joined Sep 2001
Looking Good
Hutch - Looks like a scratch-built (and improved) version of the Art Hobby Colibri.
As mentioned above, watch your fuselage length as it appears to be very short. A longer nose and a lighter battery will go a long ways towards a lighter AUW.
Keep those photos coming!
Scratchbuilding Rules!
Chris in Seattle
Rain City Flyer is offline Find More Posts by Rain City Flyer
Mini Telemaster build No Step Parkflyers 136 Mar 19, 2016 01:37 PM
Mini Blade build Mechanic Slope 152 Feb 27, 2008 12:10 PM
Mini ifo build tips soundman Parkflyers 10 Dec 02, 2002 07:49 PM
Mini Tornado Build Questions HavingFun2002 Foamies (Kits) 4 Apr 08, 2002 11:16 PM
Mini Tornado build question Crashmaster Foamies (Kits) 1 Mar 26, 2002 07:38 PM
