THERMALING 4 BEGINNERS-Help Area_PART 2!
Hello everyone!
Welcome to Part 2 of the very succesful 'THERMALING 4 BEGINNERS--Help area' thread! Part 1 of this thread can be found here. I'd like to say thanks to everyone who helped me and the other thermaling newbies through out the thread to help us become succesful TD sailplane pilots! ![]() Your help and great advies made it so much easyer and faster! Lets keep all that in Part 2 and maybe even PART 3!
LI, New York, USA
Joined Mar 2003
You can change the shape of the airfoil on a plane by moving the flaps and ailerons. I do this on my full house sailplanes, though I am not an expert by any stretch of the imagination. This is refered to as changing the camber of the wing when you move them together, or at least in coordination. You are reshaping the arifoil, in the air. The number of servos you have in the wing and the way your radio can contol them will determine how much flexability you have in shaping the airfoil.
Here is an interesting article on the subject. It is a translation from Danish, I believe. I found it a bit tough to follow due to the language, but work with it a bit and it becomes clear. Lots of good information. There are photos, which are small, but if you double click on them they will expand. http://www.gliders.dk/triming_and_se...der_wi_eng.htm It takes a higher end radio to do what he describes. My Futaba 9C can do most of it, but I am not sure it can do all he describes. An Airtronics Stylus, Multiplex Royal Evo, A JR 10X and the like should be able to do all he talks about. These radios can handle 4 servos in the wing, each on its own channel and each individually controlled. The radio can mix them together to create the shapes and compensation combinations he describes. Some midrange sport radios can do some of this. The Hitec Optic 6, Futaba 7C, JR 6102 for example. But they don't have specific capabilites for 4 servo wings. Typically they have to operate the flaps together so you can't have one go up and one go down. Also,they many not have all the compensation mixes he describes. Some radios, and we are talking big bucks, can handle a 6 servo wing, but that is real high end stuff. Not something I am ever likely to need. If you are not familiar with computer radios and the terms assciated with them, this article may be helpful before you read the one above. Computer Radios http://www.rcezine.com/cms/article.php?cat=&id=65 |
LI, New York, USA
Joined Mar 2003
Charger at Tower Hobbies:
http://www2.towerhobbies.com/cgi-bin...?&I=LXLX84&P=7 They also have an adapter that will let you use your peak charger: http://www2.towerhobbies.com/cgi-bin...?&I=LXWV16&P=7 does the battery come out of the radio? If you want to use your peak charger, I find it better charge it outside the radio BIG Caution about the peak charger - the TX and RX batteries are specified for 10 hours at 1/10 C charger rate. That means that if the battery is 600 mah, the battery is supposed to be charged at 1/10 of that or 60 mah for 10 hours. I would not recommend charging higher than 1/4C at any time, or 150 mah in this case. that would take up to 4 hours. Last note. Many peak chargers assume you are charging motor batteries and will turn off automatically after 1-2 hours so if you do use your peak charger and it seems to turn off too soon. Reset it and charge again. If the battery is full, it will shut off automatically after 5 minutes or so. Hope this helps. |
USA, CA, Redondo Beach
Joined Aug 2003
Just a guess..... Jeff Did you know Berea has a web site... ![]() http://www.berea.com/ Berea, KY Current Weather and Forecast Berea, KY Weather Forecast 3:50 AM EST TUE NOV 2 2004 TODAY - Cloudy with a chance of showers - then showers with a slight chance of thunderstorms after noon. TONIGHT - Showers and a slight chance of thunderstorms. WEDNESDAY - Showers likely and a slight chance of thunderstorms. WEDNESDAY NIGHT - Showers likely and a slight chance of thunderstorms. THURSDAY - Cloudy with a 60 percent chance of showers. Highs around 60. West winds 10 to 15 mph. THURSDAY NIGHT - Mostly cloudy. |
| Thread Tools | |
| Discussion THERMALING 4 BEGINNERS--Help area | Mchone, Jake | Thermal | 502 | Oct 26, 2004 07:05 PM |
| Help selecting 3 or 4 bladed prop to replace 2 blades | Harley | Power Systems | 3 | Jun 24, 2004 09:32 AM |
| Varioprop 4 Blades Or Normal 2 Blades Props? Help!!! | CESARNOGUEIRA | Power Systems | 1 | Dec 14, 2002 01:25 AM |
| Hooking up a Jeti Brushless Speed Control to a Jeti Pashor 15/4 motor. HELP!!! | Rob R | Power Systems | 3 | Jan 10, 2002 06:37 PM |
| Try a 4-Channel Chubby Lady 2 | rscamp | Foamies (Kits) | 0 | Jun 10, 2001 01:56 PM |
