colorado @ 5500feet
Joined Sep 2001
Voltage reducing diode??
I ordered a plane locator from tower hobbies that only works with 4.8volts, the problem is most of my gliders use a 5 cell 6v system (longer flights). Can I use a voltage reducer (diode) to put in between the locator and reciever to drop the volts between 5 and 10 volts. it doesn't need to be be that high of an amp rating as it is only for the reciever.
Or has anyone used the "Hobbico Air Alert Flight Pack Monitor " does it work with 6v ok or will it burn out? http://www2.towerhobbies.com/cgi-bin...1&I=LXSZ87&P=0[/URL] Can anyone help with this, I live in Colorado and the slopes are huge (average 1000-3000ft vert. drop) so it can be a huge pain to find my planes (lost one last sping )Vince |
Space Coast
Joined Oct 2000
Re: Voltage reducing diode??
No, a diode will not reduce the voltage of a DC current. It's either full voltage or in reverse, 0V. A diode will cut AC about in 1/2 because it only lets 1/2 the current thru. Conducts on 1/2 the AC cycle and blocks the other 1/2 of the cycle.
hoppy Quote:
DNA is right.
A diode is like a check valve is for fluid or air. It lets current through in one direction but not the other. The difference is that a diode drops .6 to .7 volts across it in the forward biased mode. This is because it is not a perfect check valve. This is for a silicon diode, germanium is about .3 volts but no power diode will be germanium. The problem with this is that if you are pulling 1 amp in your plane locator you will be dropping 1A * .7V = .7 Watts of power in the diode. This is a fairly serious device Somthing in a TO-220 or SMD-220 package would work well. I don't know what your plane locator is pulling for current but be carefull. |
Folsom,Ca,USA
Joined Apr 2001
Hi,
I also doubt that 5 cells = longer flight times. Stronger faster servo movement yes, longer duration, I doubt it. If you want longer times, use larger ( more mah) batteries. 4 larger ones may weigh the same as 5 small ones and will give you a lot greater flight time. Info on .6 V drop of Silicon power diodes is correct. Thats what it takes to make them conduct. I once built a 6 cell electric hydroplane boat. I used four 5amp diodes in series right off the pack to run the reciever and servos. Worked great! No problems for entire year I ran it. Dave |
We also use diodes for running two receiverbatteries in one plane. This is usually done in large planes having a big number of strong servos for safety and the currents there are sometimes higher then in a small Speed 400 plane. Choosing the right diodes you will have no problems. Especially as there is no further electronic stuff but the diodes this version is very reliable.
If you just want to reduce the voltage for the plane locator just solder the diode into the + cable going to the locator. You do not have to reduce the voltage of the whole RC-system. Eike |
From what I can tell, they designed their tests to be biased towards the way a wild stunt pilot would fly. It is true, if you took a high torque standard servo and a similar digital, then flew like a crazed banshee, their servos would both consume similar current. From what I can see, both high torque designs draw about the same current when the control arms are moving rapidly. However, if you fly like a typical sport or scale flyer, then there is a substantial difference in current draw. For example, my standard servos have an idle current (stick not moving) of under 15mA. However, my JR digital servos idle at about 180mA (their motors are always being driven). Slow stick movement current is still well under 100mA on the standard servo (still less than the idle current of my digitals). A model with four digital servos could realize a current draw of more than a .6 amp just sitting on the runway (versus 0.05A for standard servos). In my brief test, the only time I saw that the two had similar currents is if I threw the sticks around like a madman. Being a sport heli flyer, the impact of using digitals is real. But, nothing a bigger NiCd pack can't fix -- the precision of a digital is worth the trouble. |
colorado @ 5500feet
Joined Sep 2001
6 volts
I also use the 6volts to balance (no dead weight) and to increase torque to the servos. But it is mostly for CG on my bigger gliders.
my flying abilities take away from any real time increases but I can imagine a day when I a get to fly for 5 hours straight and do the insane tricks back to back and not have to chase my dog down when she wanders off on the slope and my neck can handle the strain of 5 hours of looking up. That will be the day!8-) |
The servo still buzzes like a mad bee (that is the sound of the motor being driven). The control arm is static. The current varies slightly, but it is well above 100mA. I can sometimes see 200mA flash by. My wimpy standard Hitec was drawing 4mA under the same conditions. From my observation, the digitals all seem to buzz while at "idle." The buzz is the sound of the motor being driven at a high rate, even though the servo's control arm position does not indicate any movement. Last summer I saw a CAP232 with Futaba digitals that sounded like a crazed hornets nest (yes, the engine was off). I wonder if other folks have noticed the same noise? But, no doubt there are digital servos that are better behaved. Especially since you measured only 15mA on yours. What servo did you measure and what radio was it on? Can you please repeat the experiment to confirm your measurement? I am sorry to have gone off-topic. Perhaps a new thread should be created if there is much interest in more digital servo dialog. I don't mind getting my arm chair science debunked, especially if others can learn something valuable from it. |
