Old Feb 18, 2002, 10:58 AM
All__talk is offline
Find More Posts by All__talk
Hairy E-Pilot
All__talk's Avatar
Ellensburg, Wa, USA
Joined Dec 2000
Best adhesive for sheeting foam wings?
Hello friends
Iím almost ready to do my first balsa sheeting job and was wondering what my options were for gluing down the balsa. Itís a gray foam (insulation board) wing with a 50Ē span, 9Ē cord, NACA 2412 profile, balsa leading and sub trailing edges (full span ailerons), and overlapping carbon tube spars, Iím going to sheet it with 1/16 balsa. 3M spray glue would be easy as it eliminates the need for clamping, but I donít know if it will bond as well as Probond or epoxy, especially where the skin meets the leading and trailing balsa edges. Whatís the best glue for the job?
All advice greatly appreciated
Gary
All__talk is offline Find More Posts by All__talk
Old Feb 18, 2002, 05:01 PM
Shawn Palmer is offline
Find More Posts by Shawn Palmer
Schumacher USA
Tampa FL
Joined Jul 2000
If I were doing a wing w/balsa leading and trailing edges, I'd go for either 77, or probond on the skin-to-foam contact areas, and shoot a little CA on the skin to balsa L/T edge contacts.
Shawn
Shawn Palmer is offline Find More Posts by Shawn Palmer
Old Feb 18, 2002, 05:30 PM
FANMAN is offline
Find More Posts by FANMAN
Always looking UP
FANMAN's Avatar
Lilburn, Georgia, USA
Joined Nov 2000
Just an alternative....
I used the ole white glue, aka Elmers, I used a brush, poked a few reservoir holes in the foam, and thinly spread the glue over the foam wings, then sandwiched both wings, back into their respective counterparts, stacked the ole phone books on top for 24 hours, and walla! Of course my wings were 1/32 sheet, 1/16 gets abit hard to fold
I have used 3M 77 and other spray adhesives, but against foam, in heat and cold, its not worth the risk to me, I have seen the spray glue give at times, foam is not very forgiving, however I am not saying my way is best.
After the initial sheeting, I would use epoxy for the LE and TE.....
FANMAN
FANMAN is offline Find More Posts by FANMAN
Old Feb 18, 2002, 11:24 PM
DaveW is offline
Find More Posts by DaveW
Folsom,Ca,USA
Joined Apr 2001
Hi,
On my one and only foam wing, I used water based contact cement on the advice of the kit builder ( Jet Hanger Hobbies F 86 )
Very easy and LIGHT. Also very unforgiving as it really is "contact" cement. Any contact is final.
No separation problems. Second owner had engine out and crashed it. Bad damage, but sheeting did not separate at all from foam in the wing.
I have tried epoxy, but was amazed at how much weight it added! So much I scrapped it and built a balsa wing.
FYI
Dave
DaveW is offline Find More Posts by DaveW
Old Feb 19, 2002, 03:10 AM
plinse is offline
Find More Posts by plinse
plinse's Avatar
Baden Baden, Germany
Joined Feb 2001
Be careful with CA and foam. CA can cause some kinds of foam to melt!!
We always use epoxy for foam-balsa-wings.
Eike
plinse is offline Find More Posts by plinse
Old Feb 19, 2002, 01:21 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Southern Sorhgum Contact Cement from Dave Brown.Best there is, never lets go, super sticky!
mrittinger is offline Find More Posts by mrittinger
Old Feb 19, 2002, 04:16 PM
ken troxell is offline
Find More Posts by ken troxell
rockville maryland
Joined Aug 2000
the very best....transfer tape...it is the easiest,lightest and most foolproof. Dodson Designs originated this. i used this method on many sailplane wings without a problem.
ken troxell is offline Find More Posts by ken troxell
Old Feb 19, 2002, 04:47 PM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
Sheet the wing with Southern Sorhgum Contact Cement and use Titebond to attach the LE and TE.
Pete
SchiessCo is offline Find More Posts by SchiessCo
Discussion Best adhesive for sheeting a foam wing? Valid8r The Builders Workshop 4 Sep 12, 2006 05:48 AM
Best adhesive for balsa over foam ? dvint The Builders Workshop 9 Dec 29, 2004 03:02 PM
Question what is the best airfoil for undercambered foam wings? duaner Foamies (Kits) 13 Aug 06, 2004 10:23 AM
Best adhesive for Blue Foam Hawker Foamies (Kits) 14 Oct 09, 2002 08:57 PM
Best filler for white foam (uk) ? BioHazard Beginner Training Area (Aircraft-Electric) 2 Oct 01, 2001 10:45 AM
