Old Oct 25, 2004, 12:45 AM
tomerj is offline
Find More Posts by tomerj
tomerj's Avatar
Joined May 2002
Gallery
Dynaflite Super Decathlon build thread
Here is the one thread I could not find, so I may as well write it myself.
I finnaly decided to go ahead and build the kit I bought $#&*$ time ago, and Iit looks like I am going to post some photos in this thread.
The first two photos are of the box-o-stuff and what was in it. I then move to the tail assembly, all as described in the plans.
tomerj is offline Find More Posts by tomerj
Old Oct 25, 2004, 12:51 AM
tomerj is offline
tomerj's Avatar
Joined May 2002
Tail assembly complete
The keen looker will see that the photos where all taken the same evening. That is because there is not much work in between, and I did bathe the kids and had dinner in between.
Thail assembly photos, and the ruller in the photo is a 6" for reference. Yes, I do have planes that way less ready to fly...
The hand in the photo was put there on purpose: it whoes the lamination process used to create the elevator shape
And I had to stand on a chair in order to take the photo.
More photos shortly...
Old Oct 25, 2004, 11:17 AM
Derick Veliz is offline
Find More Posts by Derick Veliz
Derick Veliz's Avatar
United States, MA, Warren
Joined May 2002
Looks Great Tomer!
do you need help?
D.
Derick Veliz is offline Find More Posts by Derick Veliz
Old Nov 04, 2004, 06:09 AM
mRqS is offline
Find More Posts by mRqS
mRqS's Avatar
Venray, The Netherlands
Joined Oct 2003
Hi
Here you can see my "building diary" of Dynaflite Super Decathlon
http://rc.marekszulen.net
here is a Decathlon's subpage: http://rc.marekszulen.net/en/dyna-deca-en.html
Im on the engine mount stage. Today will put more pictures on site.
Good luck with your's bird!
greets
mRqS
mRqS is offline Find More Posts by mRqS
Old Nov 04, 2004, 10:03 AM
tomerj is offline
tomerj's Avatar
Joined May 2002
Hinjing the rudder and started the ribs
{mRqS - thanks for the link, very nice post}
Project progress: Jinged the tail control surfaces with a GP slot mchine. Don't like it. Also, you need a new larger set of blades than the ones in the box, and more $$. Ohhhh.... Ended up using the good old du-bro slotter.
Started doubling the wing ribs with the ply parts.
Old Nov 05, 2004, 06:48 AM
mRqS is offline
mRqS's Avatar
Joined Oct 2003
You starting the best part of building I see
Wings are easy to build. Just be careful with proper wash-out.
Yesterday I uploaded new pics with engine mount. I had to "invent" a special semi-soft mount to install my ZDZ-40 motor.
Now trying to mount a throttle and choke valve levers on Walbro carburetor.
greetings
Marek
Old Nov 06, 2004, 01:10 AM
ScaleBrad is offline
Find More Posts by ScaleBrad
115 inches of 'hog
ScaleBrad's Avatar
United States, FL, Orlando
Joined Aug 2004
I'm also (slowly) building this kit. Powerplant is "BennetBuilt" US 41cc gas. Only have tail surfaces and one wing half done. Sorry, not much help. I'm curious as to how you guys are going to tackle the starburst pattern for the covering.....
ScaleBrad is offline Find More Posts by ScaleBrad
Old Nov 06, 2004, 05:19 PM
mRqS is offline
mRqS's Avatar
Joined Oct 2003
I planned to use a Oratex or Solartex to cover first, so I would have to cut stars manualy.
Due to fact, that real Decathlons are high-glossy finished, I'll probably use oracover. In this fact, I can cut stars on the cutting plotter.
Here is my choosen scheme:
The other possibility is to not use starburst pattern.
something like this for example:
Old Nov 07, 2004, 05:07 PM
moter is offline
Find More Posts by moter
Texas..Bigger than France
moter's Avatar
Austin Texas, United States
Joined Jun 2004
What is the difference in Super Decathlon and a Citabria?
moter is offline Find More Posts by moter
Old Nov 07, 2004, 06:52 PM
mRqS is offline
mRqS's Avatar
Joined Oct 2003
Look here: http://www.amerchampionaircraft.com/newac/newmain.htm
Citabria has semisymmetrical airfoil, Decathlon symmetrical.
There are many other differences: engine power, wingspan, weight, propeller etc.
Citabria is not fully aerobatic.
Decathlon is fully aerobatic: +6, -5 g's
Old Nov 07, 2004, 07:07 PM
moter is offline
moter's Avatar
Joined Jun 2004
Thank you for the info
Old Nov 08, 2004, 07:56 AM
bp4rc is offline
Find More Posts by bp4rc
Houston, Texas
Joined Mar 2004
Brad,
Go to the web site given above for the full scale aircraft and see the standard star burst scheme. Not quite so complex and it is perfectly scale. I used it because the full scale I modeled had it and I liked the color combination.
PM me and I will send you some pictures.
Bedford
bp4rc is offline Find More Posts by bp4rc
Old Nov 08, 2004, 11:39 PM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
I have always loved this airplane! I'll be watching this thread!
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Nov 09, 2004, 02:19 AM
mRqS is offline
mRqS's Avatar
Joined Oct 2003
Yes, there is "something" in this babe
just updated my building site:
it is my version of avionics (modified one). If you want to use this version, I can send you a graphics file
here are my works with spinner and engine
greets
Marek
Old Nov 09, 2004, 11:40 AM
tomerj is offline
tomerj's Avatar
Joined May 2002
Navigation lights
Q1:
What is the best way to wire the navigation lights in the rudder / elevator?
Q2:
Also, can anyone point out the best source for the light locations / blinking speed / order / colors?
Thank you for the inspoiration, Marek...
Tomer
Build Log Dassault Super Etendard build thread GGRN Pusher Prop Jet Models 181 Nov 02, 2010 06:58 PM
Mini-Review Page Aviation 40" Super Cub Build Thread Bill K. Scale Kit/Scratch Built 268 Sep 03, 2009 09:55 AM
ultimate series super hornet build thread 6mmflyrc.com jazsop Pusher Prop Jet Models 0 Nov 05, 2005 10:32 AM
Dynaflite Super Decathlon power plant mRqS Giant Scale Airplanes 6 Sep 16, 2004 01:56 PM
Laird Super Solution Build Thread! boomerace Parkflyers 178 Oct 29, 2003 08:20 PM
