Old Oct 24, 2004, 09:35 PM
losinground is offline
Find More Posts by losinground
Registered abUser
losinground's Avatar
Roanoke, Va.
Joined Dec 2002
Up....down....up.....down......up....down.
What can I do to help the bobble effect of my corona in light winds? Even in very slight breezes I get caught in a stop the heli bob game with my corona. Will flattening the flybar help. I seem to fight the altitude of my corona..well no.. I surely fight the altitude of it more than any thing else. HELP!!!
Danny
losinground is offline Find More Posts by losinground
Old Oct 24, 2004, 09:45 PM
ChrisS is offline
Find More Posts by ChrisS
Really?!?
ChrisS's Avatar
Lost ...on the 3rd rock out
Joined Sep 2001
Symmetrical blades and collective pitch.....
ChrisS is offline Find More Posts by ChrisS
Old Oct 24, 2004, 09:53 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
flattening the flybar helps the nose up tendencies, rather than bobbing. that is more to do with translational lift more than anything in hover. this effect is true for all heli.
askman is offline Find More Posts by askman
Old Oct 24, 2004, 10:08 PM
darthdrk is offline
Find More Posts by darthdrk
My hobby is why Im broke
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
go with the 4-4 blade grips if you are using the 4-6
darthdrk is offline Find More Posts by darthdrk
Old Oct 24, 2004, 10:26 PM
Registered abUser
Roanoke, Va.
Joined Dec 2002
So in other words, nothing will help since it is a FP heli? I already have the 4-4 grips on. Just thought I would ask.
Danny
Old Oct 24, 2004, 10:34 PM
gregw is offline
Find More Posts by gregw
gregw's Avatar
Hong Kong
Joined Nov 2002
Any helicopter will need constant correction to maintain the same height due to changes in lift from wind. If your throttle stick still has "steps", then you NEED to get rid of them before you can achieve a smooth even flight.
For a Futaba tx, you just need to open it up, loosen the screw holding down the strip of metal against the cam on the throttle and flip it so that the smooth side of the strip is against the cam. You'll be amazed at the difference in control.
gregw is offline Find More Posts by gregw
Old Oct 24, 2004, 10:37 PM
Registered abUser
Roanoke, Va.
Joined Dec 2002
Been there , done that.
darthdrk is offline
darthdrk's Avatar
USA, TN, Millington
Joined Dec 2002
It could be your comphesation ability.I fly in winds sometimes up to 10 plus MPH. I dont advise this but the more you fly the better you get. With a CP machine, youre still going to be adjusting the collective to comphensate for the wind.
Old Oct 24, 2004, 10:57 PM
Orion_V is offline
Find More Posts by Orion_V
Heli Headcase
Orion_V's Avatar
Cliffside Park, NJ
Joined May 2003
Danny...
Had similar issues like that when I first started flying, as your flying skills progress, and as you get a better feel for your heli, this will decrease greatly. Its basically just practice - practice...and yes fixed pitch helis have a greater tendancy to do this. Don't worry, just keep at it and youll eventually get over it.
Orion_V is offline Find More Posts by Orion_V
Old Oct 24, 2004, 11:51 PM
luc is offline
luc
Find More Posts by luc
luc
I plant balsa sticks too
luc's Avatar
France
Joined Feb 2000
This has nearly completely gone on mine using the nice and flat carbon flybar sold by Matt. You may have to decrease movement of servos as the heli will respond faster.
luc is offline Find More Posts by luc
Old Oct 25, 2004, 12:26 AM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
You do get lot better at it as you practice. I find that good throttle response is critical too. good strong motor/battery combo is a must. I have flown in high wind upto mid 20s with corona, and good throttle control is must at least in low level hover. in most cases, I tend to do forward flight as heli is more stable in windy condition while it is moving rather than stationary.
Old Oct 25, 2004, 07:07 AM
Heli Mod Man is offline
Find More Posts by Heli Mod Man
---------Speed!!---------
Illinois
Joined Jul 2003
Yes, the flattened flybar will help.
I flew two days ago in 40 MPH wind (gusty wind). I had a hard time keeping on my feet! I am a very experienced pilot, though. However, that being said, I flew four 10 minute flights in that wind and had a blast! I was all over the place and fought the heli using full stick movement to keep on top of the buffetting. But, the heli will stand up to it.
I think a stock Corona can tolerate 25 MPH wind prettty easily.
Flatten the flybar. This will not totally eliminate the issue, but it will help.
Matt............
Heli Mod Man is offline Find More Posts by Heli Mod Man
Old Oct 25, 2004, 08:36 AM
Plummit is offline
Find More Posts by Plummit
SoCal
Joined Jul 2004
Matt............
I have stood in a measured 25 MPH wind and I have to disagree Matt. I don't feel a stock Corona has what it takes to negotiate those winds, especially if it's gusting.
I agree with others that say you will get used to the bobing effect. It used to bother me too, but when I started looking at it as a challenge to try to keep the Corona at a given height, it became fun and I got much better at throttle control!
regards
-Marc
Plummit is offline Find More Posts by Plummit
Old Oct 25, 2004, 10:12 AM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
I guess i can't say too much about stock setup as I never really had true stock setup. closest was with choppa crutch and rest stock, but I was pretty raw back then. what I can say is though steady wind is easier than gusts. I've flown in gust where whole heli gets shaken and tossed for few sec if you are hovering . (it was at least 25mph gust) and it is not too fun to hover. I fly my body facing side to the wind rather than into the wind. I find have much better control in this condition. I fly. back and forth perpendicular to the wind. works great and great practice. I find that I hav e most control. higher the wind, lower I fly and higher speed i fly. I get some protection from wind from houses that way since I fly in the street.
Old Oct 25, 2004, 03:06 PM
Illinois
Joined Jul 2003
regards
-Marc
That may be true. Admittedly, I haven't flown a stock Corona in quite a while. I do know that my tricked out Corona (Hacker on 3S lipos) required nearly full throttle to keep from being blown back in the wind. VERY challenging!
Matt..............
Up she goes...down she comes R/C~Mev Beginner Training Area (Aircraft-Electric) 7 Oct 16, 2004 03:34 AM
Balsarite (thumbs up or thumbs down?????) bigbear3721 The Builders Workshop 2 Aug 06, 2004 09:00 AM
Alert up thrust & down thrust 3D4ever Electric Plane Talk 15 Jul 27, 2004 11:47 AM
Up thrust; not down! jrb Power Systems 36 Oct 12, 2002 10:22 PM
Eco 8. Up and Down. Up and Down. Foxtrot Electric Heli Talk 7 Aug 13, 2002 12:15 PM
