Old Nov 04, 2004, 07:24 PM
mexico is offline
Find More Posts by mexico
mexico's Avatar
NJ
Joined Aug 2003
Originally Posted by mexico
ronrandle - my wattmeter came today and thanks to Jon I got some Deans connectors on it tonight. (Not as easy as it sounds.) I will test the E Flite 400 tomorrow night but I did get to quickly run the AXI 2212/34 on a Ph 10, APC 12x5 E Prop and an Etec 1200 3s1p 2nd Gen pack. Up to 3/4 throttle amps were very low - 4-6 amps. WOT 9.1 amps at I think 66 watts.
Just to compare the Lehner 1020/12 on a Ph 35, Kokum 3s1p 2000 (15C) and a APC 11x3.8 SF - WOT 27 amps and 260 watts (pack was not fully charged)
To ronrandle and anyone else that looked at my wattmeter numbers on the AXI 2212/34 last night - I was mistaken re: watts. It was not 66 watts. I am surpised no one jumped on me. I redid the test on both the AXI and an E FLite 400 (4200kv) on a D geared GWS GB:
AXI 2212/34 1/2 throttle WOT
11x3.8 SF 1.2 amps 14 watts 10.5 amps 102 watts
11x5.5 E 1.3 amps 15 watts 7.6 amps 80 watts
12x3.8 SF 1.6 amps 19 watts 12 amps 117 watts
12x5.5 E 1.5 amps 18 watts 9.5 amps 96 watts
E Flite 400 GWS D gearing 11T pinion ($55)
11x3.8 SF 6 amps 65 watts 12 amps 120 watts
11x5.5 E 3.7 amps 42 watts 10 amps 104 watts
12x3.8 SF 5.2 amps 57 watts 17 amps 160 watts
12x5.5 E 4.9 amps 53 watts 15 amps 140 watts
My Etec 1200 pack started off at 12.2 volts. By the end of the test it was down to 11.98 v (if that means anything)
Formatting got messed uo so I attached it as a Word doc as well.
Hope this helps someone
mexico is offline Find More Posts by mexico
Old Nov 05, 2004, 03:19 AM
james_28 is offline
Find More Posts by james_28
wizard of OZ
james_28's Avatar
N.S.W Australia
Joined Feb 2003
hey guys,
thanks for the support.
the nose is gone IMHO, i will have to cut out a new part(sorry for the lack of building knowledge) to support the aft end of the stick.
as mexico said i might get one of the cobri flush stick mounts, might make life easier.
i sure nocked her poor old nose off well, its in few peices.
BTW, sorry for the sympathy posts, always a habit when you mess up a great plane.
james_28 is offline Find More Posts by james_28
Old Nov 05, 2004, 09:28 AM
ronrandle is offline
Find More Posts by ronrandle
ronrandle's Avatar
Huntersville, NC
Joined Jul 2002
Mexico, those numbers look a little bit better. I'm still planning on my maiden with the RZ 350 because I know how it pulls around my other planes.
Thanks again for all the info.
Ron
ronrandle is offline Find More Posts by ronrandle
Old Nov 05, 2004, 12:34 PM
Ted U is online now
Find More Posts by Ted U
Ted U's Avatar
Norfolk Intl, Virginia, United States
Joined Jul 2002
Maiden this morning in 15+ mph winds....
Very stable, yet wild when you want it with throws. Vertical is probably 60 mph straight up- kinda crazy! I kept the CG a little forward for wind penetration and it did very well. A little too gusty to really ring it out, but just had to fly it. I hovered (if you can call it that with a cross wind moving it across the field) and under half throttle....Tumbles effortlessly. Man, my flag scheme looks even better in the air. It was literally blowing like a flag.
Hopeful for the winds to die so I can really have some fun. Another outstanding addition from SA! I love it already....
-Ted
Ted U is online now Find More Posts by Ted U
Old Nov 06, 2004, 12:19 PM
chimchim is offline
Find More Posts by chimchim
USA, IL, DeKalb
Joined Dec 2003
Ted,
Is your Lehner 1020/15 a metal can or carbon fiber? Also, can you tell me what the weight of the motor alone is?
Wishing for calm skies for you so you can take some video for us
Steve
chimchim is offline Find More Posts by chimchim
Old Nov 06, 2004, 01:15 PM
Ted U is online now
Ted U's Avatar
Joined Jul 2002
I think it's metal although it does have some texture so it could be CF. How's that for a absolute answer.
I've been hoping the Mrs. will tell me to go out and buy a new video camera some day....Then maybe she'll shoot some video.
Today was calm in the am, but I had other commitments....Now it's windy again.
-Ted
Old Nov 06, 2004, 02:47 PM
mexico is offline
mexico's Avatar
NJ
Joined Aug 2003
Steve and Ted - I believe the Lehners are metal and the weight is 62 grams
Old Nov 06, 2004, 03:10 PM
chimchim is offline
USA, IL, DeKalb
Joined Dec 2003
Ted and Mex, thanks for the answers. Was just reading in another thread about the Lehner weighing 1.6 oz. Just wondering if there are two different versions of this motor.
Steve
Old Nov 06, 2004, 03:18 PM
doc-e is offline
Find More Posts by doc-e
Live to fly!
doc-e's Avatar
United States, NJ, Fair Lawn
Joined Nov 2002
Steve
Steve,
There are several versions of the Lehner motors. See http://www.b-p-p.com/Lehner.htm
Doc
doc-e is offline Find More Posts by doc-e
Old Nov 06, 2004, 03:23 PM
Ted U is online now
Ted U's Avatar
Joined Jul 2002
Steve,
I think the 1020/15 is probably overkill for this size plane. I'm afraid I'm going to rip the fuse apart when it gets close to WOT. If I had unlimited $$$, I'd get a 1015/20 for the Stella...It's more of a 200 watt class motor, instead of a 300 watt class which I'm using as a 200....In fact, I'd be up for anybody who wants to trade me.
-Ted
Old Nov 06, 2004, 03:29 PM
mexico is offline
mexico's Avatar
NJ
Joined Aug 2003
There are 3 sizes offered at BPP 1010, 1015, 1020. The weigh 41, 52 and 62 grams respectively. I have a 1020/12 and like Ted I get a little intimidated by its power sometimes. I guess I could always use a smaller prop.
Ted what size prop do you run on the Lehner?
Old Nov 06, 2004, 03:38 PM
Ted U is online now
Ted U's Avatar
Joined Jul 2002
I'm running a 10x6 HD now with a 6 to 1 GB. I'm trying to decrease the amps in order to fly with my 1570 3S pack. I'll check the whattmeter later...When I flew it with the 11x7, I got 43 oz of thrust at 25-27 amps static, way too much for the cells. Of course, I only needed 1/3-1/2 throttle the entire flight.
-Ted
Old Nov 06, 2004, 03:47 PM
mexico is offline
mexico's Avatar
NJ
Joined Aug 2003
I have mine in an Atttude. I have an APC 11x3.8 SF on it with a Kokum 2000 15C pack. It pulls 27 amps. But like you, I fly at 1/2 throttle or less. Once in a while I get brave. Full down elevator with a blast of throttle is hysterical. Maybe I should try a 10x4.7 or even a 9x3.8 or 9x4.7 that I have laying around.
Old Nov 07, 2004, 10:29 AM
SRush99 is offline
Find More Posts by SRush99
SRush99's Avatar
Spring, Texas
Joined Feb 2004
Finally started on my Stella last night after finishing my son's "Miracle" EPP. I've got to say that of the 19 years of building kits, Stevens Aero is the best I've ever built !!
I'm still debating colors and type of film to use. I've heard of the "lite" covering materials but see that they a bit more difficult to use than the standard monocote, ultracote, etc. Anyone have recommendations? Is the weight difference really worth the extra cost and hassle?
By the way, Ted - your Stella is absolutely gorgeous. What covering did you use?
-Stuart
SRush99 is offline Find More Posts by SRush99
Old Nov 07, 2004, 11:07 AM
sukhoi26mx is offline
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
Here is a shot from yesterday's flying
sukhoi26mx is offline Find More Posts by sukhoi26mx
Build Log Stevens Aero Stella: Building Thread (part 5) Ted U 3D Flying 245 Dec 22, 2014 09:51 AM
Stevens Aero Stella: Building Thread (part 4) SchiessCo 3D Flying 605 Aug 18, 2005 06:10 AM
Stevens Aero Stella: Building Thread (part 3) SchiessCo 3D Flying 553 Feb 01, 2005 08:50 PM
Stevens Aero Stella: Building Thread doc-e 3D Flying 633 Oct 24, 2004 05:52 PM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
