Old Nov 21, 2004, 05:25 PM
sukhoi26mx is online now
Find More Posts by sukhoi26mx
Scott Stoops
sukhoi26mx's Avatar
United States, CO, Longmont
Joined Mar 2002
Originally Posted by Rob Kelly
Yes, roll coupling with rudder is bad at anything less than full speed on mine. Too bad as this is one sweet build and great looking ship. It has some problems but it does great touch and goes, I'll take an Attitude any time.
Rob
Funny you'd say that I sold my Attitude and put the gear in the Stella. I couldn't get a stable hover/torque in the Attitude no matter how far the CG was back. To each their own I guess
Scott
sukhoi26mx is online now Find More Posts by sukhoi26mx
Old Nov 21, 2004, 07:31 PM
ronrandle is offline
Find More Posts by ronrandle
ronrandle's Avatar
Huntersville, NC
Joined Jul 2002
I finally had a chance to fly her today with heavier packs and what a diference the right CG makes
I was still able to hover virtually effortlessly and harrier's are a piece of cake. Snaps are easy and waterfalls are super tight.
Interesting info regarding the KE of Stella. For me I haven't really been able to keep it locked in for any length of time. I know it's not a foamy, and I don't expect it to fly like one, but I'd love to be able to do a nice slow harrier KE across the deck. Which of course, my foamies will do all day long.
The guys at the field today had their first look at it this morning and were totally impressed with the way it looks and flies.
So far it kicks the pants off of the other "3D" balsa planes I've built.
Ron
ronrandle is offline Find More Posts by ronrandle
Old Nov 21, 2004, 08:04 PM
citabria7 is offline
Find More Posts by citabria7
charlotte nc
Joined Nov 2002
I saw this plane today at the flying field........all I can say is that it is another GREAT plane from Bill !!!! and Ron did a super job building and flying it !!
Jack
citabria7 is offline Find More Posts by citabria7
Old Nov 21, 2004, 08:23 PM
ronrandle's Avatar
Huntersville, NC
Joined Jul 2002
Thanks, Jack. I went back to the field this evening and had even more fun. Got into some incredible KE spins thanks to your tutoring.
Ron
Old Nov 22, 2004, 12:17 PM
Rob Kelly is offline
Find More Posts by Rob Kelly
Brighton, CO
Originally Posted by daking
Ya, i am real fond of slow knife edge right across the deck then lead into a rolling harrier and then finish with a knife edge in same direction i was going. Just make's it really hard to start or finish with the knife if it roll's inverted on me !!
I did try a pattern knife edge( fairly fast with very little rudder ) and it's seemed ok that way. I just have my CG back too far for nice clean pattern.
Guess i will try to make a mix the next time i fly it. Atleast it will help.
Maybe a straight hinge on the rudder will help????
I built a new rudder/fin with a vertical hinge line and it really didn't help.
Rob
Rob Kelly is offline Find More Posts by Rob Kelly
Old Nov 22, 2004, 01:28 PM
Stevens AeroModel is offline
Find More Posts by Stevens AeroModel
Truss-Loc Monkey
Stevens AeroModel's Avatar
Colorado Springs, CO
Joined Feb 2002
Sorry if this is a duplicate but I haven't seen an answer from you as to which way the plane is rolling with or against rudder and as to which direction you are in slip left or right?
-Bill
I have a razor in there swinging a 12x8 gws prop. KE both way's has ton's of coupling.
1320 tp pack, AUW is about 13 oz's.
Stevens AeroModel is offline Find More Posts by Stevens AeroModel
Old Nov 22, 2004, 01:31 PM
Truss-Loc Monkey
Joined Feb 2002
Rob
That would actually work against you not for you.
Old Nov 22, 2004, 03:54 PM
Parkflyer is offline
Find More Posts by Parkflyer
Richmond, VA
Joined Apr 2002
With the left wingtip straight down, right rudder rolls left. If the wingtip is not straight down, it doesn't roll nearly as much.
Grant
Parkflyer is offline Find More Posts by Parkflyer
Old Nov 22, 2004, 04:31 PM
daking is offline
Find More Posts by daking
PRO BRO #157
daking's Avatar
Sterling hts, Michigan
Joined Jun 2003
-Bill
The plane roll's inverted on both side's of knife edge. I will build a mix the next time i fly it to see if it help's.
I thought about the straight hinge and yes, it would make it worse. The only way i see fixing the roll coupling is to (1) lower the stab (2) add some diehedral(spelling?).
Dont get me wrong, i love this plane!! This is the only flaw i have found.
Maybe put the stella elevator on the 480 groove and have the ultimat 3D/pattern ship??????
daking is offline Find More Posts by daking
Old Nov 22, 2004, 05:09 PM
Truss-Loc Monkey
Joined Feb 2002
I'd check your wing to see that it is straight. The dihedral is built into the wing via the taper. The top of the wing is flat with the bottom tapering up to create the dihedral...
one - your wing could be on upsided down.
two - bent wing if you invert your wing on a flat surface the top spar should lay perfectly flat across the table. If it bows up at the tips away from the table then your wing is bent - this would eliminate some of the dihedral and cause a condition where it would roll against rudder application.
Reducing the stab height will also cause more roll against rudder as it reduces the effective dihedral of the stab. (not what you want)
Just trying to help - sounds like you have a bit more roll coupling then I have ever experienced with this model.
-Bill
Old Nov 22, 2004, 06:46 PM
Ted U is offline
Find More Posts by Ted U
Ted U's Avatar
Norfolk Intl, Virginia, United States
Joined Jul 2002
Dihedral
Mine didn't fly very well after I added some polyhedral....
-Ted
Ted U is offline Find More Posts by Ted U
Old Nov 22, 2004, 06:56 PM
Scott Stoops
sukhoi26mx's Avatar
Joined Mar 2002
Holy Smokes. That picture just makes me cringe.
Scott
Old Nov 22, 2004, 07:04 PM
Truss-Loc Monkey
Joined Feb 2002
Is it safe to assume that your wing is a tad bit bent?
-Ted
Old Nov 22, 2004, 07:06 PM
Ted U is offline
Ted U's Avatar
Joined Jul 2002
I'm at the point where it was "just another plane"...Oh well. I've got another coming. Maybe the flag got shot down by an Iraqi SAM. I think I'll stick with a simpler scheme this time around.
-Ted
Old Nov 22, 2004, 07:08 PM
Ted U is offline
Ted U's Avatar
Joined Jul 2002
Nahhh. It just looks that way in the picture. Must be your monitor....I'm converting it to a DLG. Should be cool....
-Ted
Build Log Stevens Aero Stella: Building Thread (part 5) Ted U 3D Flying 245 Dec 22, 2014 09:51 AM
Stevens Aero Stella: Building Thread (part 4) SchiessCo 3D Flying 605 Aug 18, 2005 06:10 AM
Stevens Aero Stella: Building Thread (part 3) SchiessCo 3D Flying 553 Feb 01, 2005 08:50 PM
Stevens Aero Stella: Building Thread doc-e 3D Flying 633 Oct 24, 2004 05:52 PM
The Ultimate Slow Stick Help Thread - Part 2 Martin Hunter Beginner Training Area (Aircraft-Electric) 565 Feb 17, 2004 10:35 AM
