She flies!!
Well, today must have been nice all the way up the East coast so I did what any responsible person would do and took an extended lunch to maiden Stella. First impressions are; 1. Nice stable plane that needed very little trim on the first flight 2. Only had a chance to run three packs through but the Razor 400 and Polyquest 3s850's were a perfect lightweight combo. Both batteries and motor were cool and flight times were in the 7-8 minute range. Solid vertical but not a rocket. 3. CG is a little aft of the recommended range with the lightweight packs and motor 4. Hovers very easily 5. Tumbles effortlessly 6. Flies a little faster than I expected 7. Landings are a non-event One thing I did notice was that I had a lot less rudder authority turning right, even with monster throws. I'm wondering if the 12x6 prop had something to do with that. Since I'm considering a new motor and battery combo to help with the CG, I'm thinking of going down to a smaller prop, say a 10x4.7, on a lower gearing. What do you experts think? Also couldn't get blenders to flatten out but I haven't dialed in all the down elevator that's available and that may have something to do with it. All in all, a perfect day for the maiden of an awesome plane. Ron |
What technique are you using on the Blenders? Get the max throw and be sure to use at least 1/2+ throttle during the transition. With over 3/4 throttle mine are stationary or climbing ![]() Congrats!! Scott |
Scott, I climb to a crash-proof height, nose over and full left aileron, cut power to 1/4. After a few spins, full down and full right rudder. I don't think I had enough throttle as the nose was pointing down and looked more like a bad knife edge spin.
11x5.5? I may just have to try that. |
![]() Try this. crash proof height, close the throttle, vertical line down, full left aileron for 3-4 rolls. Add full right rudder, full down elevator, a split second later add 1/2 throttle (it will look REALLY violent - and it is), and add approximately 1/2 right aileron. Modulate the aileron (probably be neutral to 1/2 right aileron), but hold the rudder and elevator controls constant. Scott |
Anybody see the new upcoming Razors? I'm liking the numbers on the bigger 1" diameter motors. Should be a great Stella or even Groove geared setup...
http://razormotors.com/ -Ted |
Orange County, CA
Joined Feb 2002
I just started building my Stella (this thread is about the Stella, isn't it?). The only problem I'm having is getting the parts out of the sheets. Seems like I got some hard balsa and the laser didn't quite cut through in a lot of places. Anyone else have this issue with their Stella?
This is my first SA kit, so far love the construction techniques. |
| Thread Tools | |
| Build Log Stevens Aero Stella: Building Thread (part 5) | Ted U | 3D Flying | 242 | Oct 24, 2012 01:37 PM |
| Stevens Aero Stella: Building Thread (part 4) | SchiessCo | 3D Flying | 605 | Aug 18, 2005 06:10 AM |
| Stevens Aero Stella: Building Thread (part 3) | SchiessCo | 3D Flying | 553 | Feb 01, 2005 08:50 PM |
| Stevens Aero Stella: Building Thread | doc-e | 3D Flying | 633 | Oct 24, 2004 05:52 PM |
| The Ultimate Slow Stick Help Thread - Part 2 | Martin Hunter | Beginner Training Area (Aircraft-Electric) | 565 | Feb 17, 2004 10:35 AM |
