Old Oct 24, 2004, 12:11 AM
Willard is offline
Find More Posts by Willard
Joined Aug 2004
How do I tune my HH gyro?
I have a MS-044 HH gyro running stock brushed setup with GWS 50/100 ESCs on a 2004 DD dragonfly.
Could anyone tell me what to look for when trying to get the gain adjustment right?
I cant remember what the difference between hunting and wagging is. Is one caused by the gain being too high and the other being too low?
I started with gain around 90% and the tail would oscillate in a straight hover. I could hear the motor rapidly speeding up and slowing down as it kept overshooting its center, and then slowing to return to it and then overshooting the other way etc.
So I turned it down to about 50% and now when I increase or decrease throttle it doesnt hold: the heli will shift a few degrees witht the increase or decrease in torque.
I have been trying to fine tune it between the two but with limited success
Can anyone tell me a procedure or method for fine tuning the gain, and how to find a happy medium between these two behaviours? Should I start increasing gain again until the tail starts to oscillate, and then reduce it back down in small increments until this stops happening?
Thanks !
Will
Willard is offline Find More Posts by Willard
Old Oct 24, 2004, 01:15 AM
Mr.RC-CAM is offline
Find More Posts by Mr.RC-CAM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Increase the gain as high as you can, just short of wagging (best described as a nasty tail oscillation). If you have trouble with the tail holding after this, then you have a problem (T/R servo has poor centering or speed, control slop, mechanical throws too short, gyro mounting too stiff or too soft, etc.). Be sure all Tx Revo and Accel mix is disabled.
RC-CAM
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Old Oct 24, 2004, 02:29 AM
OzzieFlyer is offline
Find More Posts by OzzieFlyer
Melbourne Australia
Joined May 2003
if you have any vibration in the heli, that can throw your gyro as well off so it will tend to drift.
Make sure your heli is vibration free first (balance blades..etc)
Then turn the gain up a little each time until it starts to wag.
As soon as it wags, turn it down a fraction until it stops.
OzzieFlyer is offline Find More Posts by OzzieFlyer
Old Oct 24, 2004, 08:21 AM
Willard is offline
Joined Aug 2004
Thanks! I will try to fine tune it again this morning.
BTW, nice picture Mr.RC-CAM- Very seasonal!
Old Oct 24, 2004, 02:49 PM
Willard is offline
Joined Aug 2004
I have spemnt some time experimenting with the gain level this morning.
One thing I cant eliminate is when I turn the heli, when I let go of the stick to give the heli its new heading, the tail will 'bounce' around slightly before settling down.
Is this normal, I am thinking that maybe it is because I am letting go of the stick too quickly and the tails momentum is carrying it past the new heading and causes the wag?
anyone got any advice?
Old Oct 24, 2004, 03:33 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
It sounds like the gain is too high for YOUR installation. Everything must be perfect; good gyro, no tail slop, well behaved servo, optimzed throws, etc, etc, etc. Lowering the gain is just a coverup for weak areas, and only so much can be hidden if things are goofy.
RC-CAM
Discussion How do I get my Align RCE-500 in and out of HH mode? Dave K Mini Helis 1 Jan 14, 2007 09:51 PM
Discussion How do I tune my OS FP .40 *NEWBIE ALERT* pbjones81 Fuel Plane Talk 6 Jan 08, 2007 03:47 PM
How do I move my Zagi cg back? emaij Foamies (Kits) 3 May 29, 2001 01:10 PM
How do i make my own hot wire rig? PunkerTFC Electric Plane Talk 21 Apr 22, 2001 09:50 PM
Help! How do I retime my 6327 Graupner Speed 480 race motor for a gearbox. Joe Elston Electric Plane Talk 6 Apr 20, 2001 11:56 AM
