Old Jun 28, 2001, 05:36 PM
Jensst is offline
Find More Posts by Jensst
Balsa Kamikaze
Jensst's Avatar
Germany, NRW
Joined Feb 2001
What cells are you using in your Sokols?
Hey Sokol pilots,
what type of cells and how many are you running in your Sokols to get a decent performance/flying time? Are 700ARs too big for the fuse?
_Jens
Jensst is offline Find More Posts by Jensst
Old Jun 28, 2001, 06:00 PM
Jeff Meyers is offline
Find More Posts by Jeff Meyers
Jeff Meyers's Avatar
Fayetteville, GA
Joined Oct 2000
Hi Jensst,
Most speed 400 Sokols are running on 7 and 8 cell 600 AE's.
I fly mine on 7 cells with a 6 volt speed 400.
Performance is great and run time is 3-4 minutes. Don't be disapointed with the time as it is a very busy 3-4 minutes.
I don't know how big a 700AR cell is so I can't help you there. You do want to keep the plane light.
Regards,
Jeff
http://home.earthlink.net/~jsmeyers/index.html
Jeff Meyers is offline Find More Posts by Jeff Meyers
Old Jun 28, 2001, 10:09 PM
jimmy6819 is offline
Find More Posts by jimmy6819
North Aurora, IL
Joined Mar 2000
I'm running 7 cell 600AE's too.....it has an Astroflight 020 7T brushless and I get 3-4 mins.
jimmy6819 is offline Find More Posts by jimmy6819
Old Jun 29, 2001, 01:01 PM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
There is a lot of room in the Sokol fuse, if you push the elevator servo behind the wing(like I did), but I am not sure if you can balance the plane with 7 x 700AR in it. I have to push the barttery all the way forward to get the balance right.
Brian
bhchan is offline Find More Posts by bhchan
Old Jun 29, 2001, 01:12 PM
Jensst is offline
Balsa Kamikaze
Jensst's Avatar
Germany, NRW
Joined Feb 2001
Did you guys ever notice a difference between the 600AEs and the green 500ARs, concerning performance and battery temperature?!
I can get zapped 600AEs ($2/ea.) and 500ARs ($2.20/ea.) over in Germany, so I have to make a choice about the cells.
_Jens
Old Jun 30, 2001, 12:59 AM
bhchan is offline
bhchan's Avatar
Joined Jun 2000
I flew mine with 7 x 500AR's on 6V 400 advanced. Also use the QRP racing sp400. The QRP 400 runa BOUT 15% higher rpm than the stock sp400.
Brian
Old Jul 12, 2001, 09:57 AM
speedster is offline
Find More Posts by speedster
301MPH!
speedster's Avatar
San Diego, California, United States
Joined Jan 2001
I use 8 cell 1000, speed 480 motor. I get 6 minute flights
speedster is offline Find More Posts by speedster
Old Jul 12, 2001, 10:36 AM
Ralph Weaver is offline
Find More Posts by Ralph Weaver
Ralph Weaver's Avatar
Indianapolis, IN USA
Joined Nov 2000
I'm using 6 Tadiran LiM cells. That's a 9V, 1600mah pack that weighs just over 100g or 3.5oz. Of course, I'm using a Astro 010 at 5A and the plane weighs about 10oz.
Ralph Weaver is offline Find More Posts by Ralph Weaver
Old Jul 12, 2001, 10:37 AM
Joined Nov 2000
_Jens
It was my understanding that zapping does not help the 600AE (or and "AE" cell).
Old Jul 13, 2001, 12:46 AM
dave morris is offline
Find More Posts by dave morris
dave morris's Avatar
orlando fl
Joined Oct 2000
Ralph, what kinda flight times do you get with that set up?
dave morris is offline Find More Posts by dave morris
Old Jul 13, 2001, 08:43 AM
Joined Nov 2000
15-20 minutes of normal flying.
What motors are you using in your T-Rex jetspud Mini Helis 17 Jul 22, 2005 12:11 AM
What engines are you using in your TT nitro conversions. wicked_n_raw Motorcycles 4 May 14, 2004 04:58 AM
What Battery are You Using in Your Tiger Moth? Dogsbd Parkflyers 10 Jun 17, 2003 09:43 PM
What batteries are you using in your GWS zero? sizam Parkflyers 8 Oct 02, 2002 11:19 PM
What batteries are you using in your Cutie Clu Electric Plane Talk 6 Nov 20, 2001 08:17 AM
